Jan, help with reboot)
This rule shows the uptime of the system
rule("@ {catch, 09:05} => log('Uptime %0.0f годин',(((ostime()-api.get('/settings/info/').serverStatus))/60)/60);fibaro.call(1038, 'sendMessage', fmt('Uptime системи %0.0f годин',(((ostime()-api.get('/settings/info/').serverStatus))/60)/60), -700919895)")
 how to take the uptime number and make a rule, if the uptime is less than 1 hour, then the log - the system rebooted! Well, or another simpler rule?
    When ER4 starts up it checks serverStatus and if uptime is less then 30s it posts a #se-start event.
    So,
    rule("#se-start => fibaro.call(1038, 'sendMessage', 'HC3 have restarted')")
    should work
    Hi
    Can one make one similar to fibaroExtra but for scenes but for HC3?
    Or . Is there another possibility than the conditions of HC3 as in HC2. Sint from HC3 so nasty and confusing.???
    Excuse the audacity in what you and others have already done.
    Well, scenes don't allow for code to be added as additional "files", like it is possible to do for QAs.
    That means that the code needs to be copied in to the actions code of the scene, making it a bit messy.
    Also, scenes are typically "short lived", meaning they are triggered, run, and terminate. That makes it a bit of overhead to setup extra
    functionality, like from a library, in the scene each time it starts up. QAs tend to run all the time except when crashing...
    You ask for conditions of "HC3 as in HC2" - do you mean picking up events like the conditions trigger of a scene?
    Can you show some example of what you want to achieve? (it may be possible to copy relevant part from fibaroExtra to include in a scene....)
    Yes, I would like to trigger and then start coding according to my vision.
    (it may be possible to copy relevant part from fibaroExtra to include in a scene....) I would do it, but it's so complex that I can't tell it apart.
    I imagine it like this. At the beginning of a script I enter all my conditions in a table that are relevant for my script and then I continue with the queries and actions.
    In my example. "myTrig" I enter all the values that I expect it to be like this. Then I compare the "myTrig" table to see if any line is the same as my lastRefresh. if so, the script runs.
    If that's for both HC2 and HC3, then that's a luxury for me.
    Of course I would be grateful for parts of the fibaroExtra code with the events processing but first of all the triggers.
    I've been using Google Translate and I'm not sure if it gets my idea across correctly.
    Thank you very much
    Ah, now I see that you have an HC2. Well, fibaroExtra is HC3 specific.
    The /refreshStates api was never up to the task on the HC2 - I evaluated it back then but stayed away from it as it was never consisted (didn't show all types of event I needed either).
    1 hour ago, jgab said:
     Then for the HC3.  I'm considering switching.  I'm already playing on a HC3 from a Friend.
    So,
    should work
    DOES NOT WORK! (((
    QA ER4  - version:v0.5fix80 (QA toolbox 0.25)
    Edited by fastvd
    So, first, is the rule triggering?
    _debugFlags.rule=true      -- log rules being invoked (true or false)
    Console log:
    [{"type":"se-start"}]>>'Rule:2[#se-start => ...
    or is it the sendMessage that doesn't work?
    For me the se-start works - just tested it and broke my 40 days uptime...
    Do you have a lot of stuff starting up on the HC3 so that the ER3 QA will start > 30s after the HC3 has booted? Then it could be a problem.
    7 hours ago, fastvd said:
    DOES NOT WORK! (((
    Oh, you do have a very old ER4 - that is the problem.
    Upgrade to latest.
    Use the updater QA to upgrade
    Console log:
    Upgrade to latest.
    _debugFlags.rule=true - YES
    where should i see it logically at start ER4, but as you can see on the screen - there is nothing like that (((
    ER4 , deviceId:1201, version:0.77
    Edited by fastvd
    The highlighted lines are the log that the rule is loaded/defined.
    The actual trigger of the rule should come later.
    Anyway, I have a hard time understanding why it doesn't work for you.
    Could you make this test.
    At the end of the QA file "EventRunner" add this debug line.
    It will log the boot time of the HC3 and the current time. This is what I use to see if diff is less than 30s and post the se-start event.
    @fastvd as tip perhaps handy?
    Remark: push is switched off because Fibaro wqs messing with it now I use Telegram for messages.
    If one of my QA's restart I recieve a message>> this I find important because if QA restart there is something wrong
    If I recieve multiple messages I know my HC3 is restarted >> this happends seldom.
    //Sjakie
    Pushed v0.78 of ER4. Best upgraded using the UpdaterQA.
    Some small bug fixes and the start of adding online documentation of functions.
    Running
    in main() will log all functions with some doc string (not all added yet)
    Thanks Jan!!
    Do I need DST in my rules or is it already in your ER?
    //sjakie
    Eh, no it's not added yet - forgot about it.
    Added it to my todo. Next release.
    Still need to run something like
    or you could do a rule like
    Running
    I see that i still are using the old EventRunner4 v0.5fix80 for all my EV4. I installed a version of v0.78/EV4 with the QA updater. Is there anything i need to pay attention to or can i just copy my rules into the main section as in v80 ?
    Edited by ChristianSogaard
    P
    Jan Ihave had this from you worked excellent!
    I have somethinsimular as @ChristianSogaard
    mu last update was November 2021 and my HC3 will be active again around December 2022 is't better to start with a fresh ER4?
    //Sjakie
    It should just be to copy. Future updates preserve the main file so your rules are not touched,
    //Sjakie
    If you are an older ER4 (ex fix 0.5vXY) I recommend to upgrade to the latest. It can be done with the UpdaterQA as it allows v0.5fixXY to be upgraded.
    It preserves the 'main' file and it should be backward compatible so it should work.
    I don't know why i'm impressed - because you always deliver amazing work, but I am ?. I upgraded 3 Eventrunner QA to the newest. And everything seems to work. Just need to remember to rename the OLD QA to EventRunner4 before the updater can find it?
    that's only for v0.5fixXY, for newer versions you can give them any name as they use a serial number in the QA code to recognise the right QA.
