    1 hour ago, FrankT said:
    @jgab need some help with IOSLocator.
    /F
    Output ZBS,   _deviceTable = "devicemap"
    Program starting as '"C:\Program Files (x86)\ZeroBraneStudio\bin\lua52.exe" -e "io.stdout:setvbuf('no')" "C:\Program Files (x86)\ZeroBraneStudio\myprograms\IOSLocator.lua"'.
    Program 'lua52.exe' started in 'C:\Program Files (x86)\ZeroBraneStudio\myprograms' (pid: 200800).
    C:\Program Files (x86)\ZeroBraneStudio\bin\lua52.exe: cannot open iOScredentials.lua: No such file or directory
    So, if you would like to test under ZBS you need to provide some configuration data.
    There is a HomeTable variable set to a son expression in the beginning of the file used for testing. However, I add my iCloud passwords to that structure and then check in the file and everyone will know my passwords - so instead I have a local file ioscredentials.lua that has the right HomeTable data.
    Anyway, do
    on line ~25 and make sure that the _deviceTable is set to a string. Then the iosLOcator will use whatever data you have in the HomeTable variable.
    define some places, and define some users. the user is the iCloud username (usually an email address), and the pwd is the iCloud password.
    Then it should work in ZBS and it will log the users it finds. Don't run it at _SPEEDTIME as it will spam the iCloud service and they may block you for a while...
    ...and when it works you can move the places and users to your HC2 HomeTable and run it live.
    Does anyone know how to change text color in the output tab in ZBS ? (the blue text is completely unreadable) :
    Perhaps this might help you:
    Found It earlier, but still don't know how to do it  :(
    know that it depends on it
    stylesoutshell = styles -- apply the same scheme to Output/Console windows
    It's a bit my fault.
    Look at line 142 in EventRunnerDebug.lua where I define the various LOG colors I use. There are also a code snippet to print out the colors supported by ZBS.
    If you come upon with a better color scheme please post it :-)
    So the html log colors are the ones in the LOG table, and are used when running on the HC2.
    In ZBS I exchange these colors "Cyan" etc. with the console codes in _LOGMAP.
    :) thanks
    Edited by domin12
    @jgab Thanks for pointing me in the right direction. I've been using IOSLocator since version 1.3, had my HomeTable with places and logins and all worked ok, but I didn't notice the chunk in the newer version of your program with "ioscredentials.lua ", my fault.
    /F
    @jgab
    the HUE implementation in ER, does it support :isOff?
    I have combine a binary plug with 2 hue devices like this
    but hue devices does not turnOn if i dont turnOff binary plug also. So if binary and hue is off then both will turnOn but not only hue.
    Edited by jompa68
    27 minutes ago, jompa68 said:
    @jgab
    Can you try something like this
    ..checks the status of the lamps every 10s. Turn on/off the lamp and see if you get changes?
    Oh, there is also a _debugFlags.hue=true you can set to get some info from it.
    Actually, this is a better test
    just one lamp and we log the full state (:values)
    No changes in debug when i turn off and on
    Sorry, my fault.  I needed to see what's in the table.
    The lamp is on in all logs? What values when turned off?
    Same value all the time.... but lamp does turn off and on :D
    Ah! Log changes when i restart scene.
    Ah, now I remember how it works :-)
    Ok, ER's internal status of the Hue lamps only change if the lamps states are changed with ER commands - e.g. fibaro:call(hueID,"turnoff"), hueID:off etc.
    Because the Hue bridge don't tell anyone when a Hue lamp change state with the Hue app or some button or whatever. The only way is to poll the bridge
    for possible Hue lamp state changes.
    It's quite easy.
    see if it works...
    Yes, because it re-reads the status of the Hue bridge
    /monthly_2019_03/image.png.94f4da594a885118769ad8a19b8ea7ff.png" alt="image.png.94f4da594a885118769ad8a19b8ea7ff.png" />
    Wrong syntax of Hue.monitor. New function for me. can check topic how it should be.
    Hue with a capital 'H' - e.g. Hue?
    this correct?
    10 minutes ago, jompa68 said:
    this correct?
    Almost.
    If you only have one bridge you can leave out the 'hue:' prefix. The default prefix is "Hue:", capital "H". The prefix is to distinguish different Hue bridges. You set _HueHubs to
    {{name='Hue',user=_HueUserName,ip=_HueIP}}, and you can have many bridges with different names.
    If it is only one id to monitor you can skip the table
    The first argument to define ( "huevrum" ) is the name of the device in the Hue system.
