/monthly_2019_03/image.png.33aad5f83d408c8dae33db87d1bb6f13.png" alt="image.png.33aad5f83d408c8dae33db87d1bb6f13.png" />
6 minut temu, jgab napisał:
msg.ESceneID=-1
this is what I'm looking for a couple of hours :) omg
THANK YOU for support
Edited by domin12
@jgab
I try to migrate to new version 2
I have following problem:
- error with reading file in ZBS if I use button >>  (execute), In case of button > (Start) it works ...
    3 minutes ago, petrkl12 said:
    @jgab
    Yes, you always have to run it in debug mode - that's how I can do the "magic" :-)
    I just pushed a new version of the HC2 emulator that is aware of EventRunner scenes and only log when the scene starts up the first time and not every time it gets a trigger.
    The log output is bit cleaner in that way.
    Also, in the emulator there is a line
    comment out that line as EventRunner scenes do their own logging of fibaro:* calls, or you will see double log messages of fibaro:* calls... It's used for standard H2C scenes.
    I don't see any result from ZBS:
    Debugging session started in 'E:\Development\ZeroBraneStudio\myprograms\Fibaro\FibaroDev\'.
    #[HC2]22:22:43, Thu Mar 07: HC2 SceneRunner v0.3 fix8
    #[HC2]22:22:43, Thu Mar 07: Reading configuration from H2C...
    #[HC2]22:22:43, Thu Mar 07: Writing configuration data to 'HC2.data'
    #[HC2]22:22:43, Thu Mar 07: Configuration setup, Globals:135, Scenes:62, Device:744, Rooms:19
    #[HC2]22:22:43, Thu Mar 07: Loaded scene:EventRunnerTools, id:10, file:'EventRunnerTools.lua'
    Debugging session completed (traced 0 instructions).
    #[HC2]00:22:43, Wed Sep 04: 09/04/19 00:22:43, End of time (4320 hours) - exiting
    Program completed in 52.83 seconds (pid: 19192).
    add
    %% autostart
    to the header?
    No, I don't have %% autostart in any scenes except main one (watch dog)
    Now it runs
    but another error:
    [228:1][DEBUG] 22:28:07: Thu Mar 07: Error loading rules:Err:fibaro:getGlobalValue("<ID>"), EventRunnerHue.lua:3194: Err:fibaro:getGlobalValue("<ID>"), Err:fibaro:getGlobal("<ID>"), HC2.lua:1239: Assertion failed: Expectedstring
    Now it runs
    but another error:
    If you want to start it without %% autostart you need to add a start command to the HC2.lua file (inside the main())
    if the ID of your scene is 20.
    fibaro:getGlobalValue expects a string as first arg. Set a breakpoint at 3194 and look at ZBS stack window where you came from and if the args are correct... I would expect that you are passing null instead of a variable name due to some other error.
    OK
    that error is in your code - I try to convert 2 my scene with same error ...
            local status,res,r2 = pcall(function() return fibaro._orgf[name](obj,id,table.unpack(args)) end)
    4 minutes ago, petrkl12 said:
    OK
    Well, I just protect the call with a 'pcall'. and return the error. The real error comes from the fibaro call being executed -- which looks like a fibaro:getGlobal/fibaro:getGlobalValue call somewhere in your scene.
    It points at EventRunnerHue.lua:3194
    I would set a breakpoint there, expecting that the variable name is... null?
    @jompa68
    Do You know how to turn off all lights in the home by telegram?
    it's interesting because I didn't have any problems with these scenes before ...
    I can try to convert third one :)
    aha, you have changed  _deviceTable to _homeTable ..., sorry
    Well, it can still be my fault :-)
    I think that you may fetch the name of a fibaro global from somewhere and store it in 'x'. It fails (silently) and you do fibaro:getGlobalValue(x), and x is null and you get the error.
    Where do you get the name of the fibaro global from? Another global? is that global read from the HC2 and initialised?
    no, my mistake
    Just now, petrkl12 said:
    no, my mistake
    Yay! not my fault (really :-) )
    Going to bed, the support opens tomorrow morning - keep questions coming.
    /J
    6 hours ago, domin12 said:
    @jompa68
    like this
    the magic is you use the same name as in your HomeTable
    2 godziny temu, jompa68 napisał:
    like this
    I added new cmd and using this function to turn all lights off
    another cmd function
    text in telegram
    Edited by jompa68
    Is it safe , this telegram magic - means talking to your fibaro ? if someone get your bot name, and send some command to my bot, is that situation will work?
    _______________
    ok, I already know everything..... There was no question
    Edited by domin12
