    12 hours ago, domin12 said:
    ok, will test it after upgrade, i'm still using old version _version,_fix = "1.15","fix12"
    o my..... so many things was happend here , how to quickly upgrade my old version ?
    trying move to new version, but after moving my rules got this error :
    ps. using HomeTable variable
     There should be no changes to your rules so the upgrade is not that difficult.
    It seems like you don't get to initialise your hometable and it becomes nil
    The hometable setup in beginning of EventRunner.lua is bit different.
    The variable pointing to your FibaroSceneAPI hometable variable is named '_homeTable' now...
    ...and you need to uncomment the line "local HT = type..."  in the beginning of your main()
    ..and then HT is used for the table (you can delete the inline HT example).
    Note that I call Util.defvars and Util.reverseMapDef on HT.dev as I have the device id's in the .dev "branch" of the hometable. There could be other branches in the hometable that is not nodes ending with device numbers (like the "other":"other" in the example) and calling defvars/reverseMapDef may cause some confusion.
    You are of course free to change it so it fits your hometable structure.
    Otherwise it should be no changes - except if you run the emulator and talk to node-red - then you need to update the node-red flow a bit.
    Let me know how it goes
     /J
    23 hours ago, petrkl12 said:
    it looks that it will be really clever :) without dependency on Fibaro:setGlobal and getGlobal ;D
    I see one potential problem and it's a automatic delete of log ...
    When it resets the log (every ~250 entry), it sets it back to the last 3-7 entries - it varies. Unfortunately, that means that the consumer can lose events if it doesn't read them fast enough... experiments seems give 1-2 lost events at every turnover if producer is twice as fast as consumer.... so back to square one.
    i have change it before, so the error is still the same
    Does this mean that my HomeTable structure is wrong?
    Do you have a ’dev’ key at the top level of your home table with all your devices?
    otherwise change defvars and reversemapdef to only get HT as argument and not HT.dev etc
    Exactly at the same moment in which you wrote the message. I understood what I did wrong, it looks like everything will be fine
    --update
    Works great
    /monthly_2019_03/image.png.189f343e1d6b663e9e5f2a4f9c8f007a.png" alt="image.png.189f343e1d6b663e9e5f2a4f9c8f007a.png" />
    how to put the percent symbol to this rule after moisture value
    I'm trying
    but as You probably know, it does not work.
    Edited by domin12
    You need a %% to print a % with string.format
    Thank You
    42 minutes ago, domin12 said:
    Thank You
    string.format has a lot of useful formatting directives.
    gives "%3.14"
    and you can do left and right adjustments with padding etc.
    it's a pity :(
    or you could clear log yourselves and setup some index that you will do it before .... but it will be maybe too slow ...
    Edited by petrkl12
    @jgab
    can you see why this is not working? Timer function does not work when using #VirtualSensor
    On 3/13/2019 at 2:30 PM, jgab said:
    Is this still a problem? I have tested and have no problem on the HC2.  If I in the emulator set "Hc2.remoteDevices(713)" it works from the emulator too.
    On the HC2 does its log the "fibaro:call(713,"setProperty",...)" ?
    I can see that VD slider popups to the value i set but then it goes back to what it was before.
    Looks ok in debug window (setProperty)
    When i set value with virtual sonos ID it works.
    Do you have some VD loop that sets it back? If you don't see any fibaro:* log in ER it must be someone else that sets the value? Some other scene?
    You have the right scene headers? power in the first and value in the second?
    I would make the test >0.5 in the first scene before deciding to publish - that way the second scene get fewer events.
    @jgab
    why this condition is also true for value=0 ?
    Edited by petrkl12
    36 minutes ago, petrkl12 said:
    @jgab
    Both rules trigger on 100:value, 101:value and 102:value
    The second rule is only true if the value (of the device that did the trigger) is equal to 1
    The first rule assigns 1 to the value property of 100,101,102 -- which is always true, and thus the right hand side will execute.
    Thanks, but it looks that second rule doesn't work and I don't know why ...
    Oh, {100,101,102}:value is the same as {100:value,101:value,102:value} and that is not equal to '1'
    To get the id that triggered the event do
    :dID selects the device id from the table that caused the rule to trigger and returns it, so that :value is applied to the right trigger
    It works :). Thanks
    I think there are a lot of new rules that could be perfect to describe in wiki.
    Edited by petrkl12
    still fighting with this...
    I assume the rule runs every weekday between 5 and7.30. Do you get the error every day or once a week or?
    I haven't been able to replicate it with a similar rule, so let me think about a better debug statement to capture the bug next time it happens.
