it looks that it will be really clever :) without dependency on Fibaro:setGlobal and getGlobal ;D
I see one potential problem and it's a automatic delete of log ...
Edited by petrkl12
    Yes, it's good because the consumer don't have to stress to free mailboxes for the producers.
    I manage to get 200+ messages with 15-20ms delay without "too many instances" (still can do burst of 9 messages). In the past (the benchmark table I did) we needed ~65ms delay to get 100 messages.
    We may have one global just to signal that there is a new event in the log - it may save some CPU (and unnecessary data structure allocation)for the main  instance. It doesn't have to be lock protected - enough that it changes value when the log should be retrieved and checked.
    On ‎2‎/‎21‎/‎2019 at 12:01 PM, jgab said:
    @jgab, got a problem when running HC2.lua and trying to create the HC2.data file.
    Program starting as '"C:\Program Files (x86)\ZeroBraneStudio\bin\lua52.exe" -e "io.stdout:setvbuf('no')" "C:\Users\F\AppData\Local\Temp\.C978.tmp"'.
    Program 'lua52.exe' started in 'C:\Program Files (x86)\ZeroBraneStudio\myprograms' (pid: 89276).
    Debugging session started in 'C:\Program Files (x86)\ZeroBraneStudio\myprograms\'.
    #[HC2]08:35:25, Thu Mar 14: HC2 SceneRunner v0.5
    #[HC2]08:35:25, Thu Mar 14: Reading configuration from H2C...
    #[HC2]08:35:25, Thu Mar 14: HC2 returned error '302 ' - URL: 'http://192.198.1.118/api/globalVariables/'.
    Program completed in 14.74 seconds (pid: 89276).
    Debugging session completed (traced 0 instructions).
    @FrankT
    check ip in HC2.lua, normally it starts with 192.168.x.x
    Seems like the emulator can't connect to the HC2. The first thing it tries to do is to read the global variables and it times out and you get an error. Guess it hangs for a while before you get the error?
    @jompa68 and @jgab
    I have set the ip and HC2_user and HC2_pwd
    _HC2_FILE = "HC2.data"
    _HC2_IP="192.198.1.118"       -- HC2 IP address
    _HC2_USER="xxx@telia.com"     -- HC2 user name
    _HC2_PWD="Hxxxxxxxx"            -- HC2 password
    --local creds = loadfile("credentials.lua") -- To not accidently commit credentials to Github...
    --if creds then creds() end
    -- Main, register scenes, create temporary deviceIDs, schedule triggers...
    function main()
      HC2.setupConfiguration(true,true) -- read in configuration from stored local file, or from remote HC2
      if not _REMOTE or _RUNLOCAL then -- If we are remote don't try to access resources on the HC2
        HC2.localDevices(true) -- set all devices to local
        HC2.localGlobals(true) -- set all globals to local
        HC2.localRooms(true)   -- set all rooms to local
        HC2.localScenes(true)  -- set all scenes to local
    ANd yes it may be a timeout, it hangs for approx 3-4 seconds.
    4 minutes ago, FrankT said:
    Can you paste
     into your browser as see if you get a json with your globals back?
    I’m worry only about potential regular cleaning of log ... some messages could be lost ...
    33 minutes ago, jgab said:
    Can you paste
    Tried it before posting the question to you, works ok without delay.
    Yes, I'm aware of that and will runs some tests to see what's happening when it rolls over. Maybe if the consumer reads often enough? Or if the producer could verify that it was read?
    Can you try this?
    In HC2.lua approx. line 551:  "local vars = api._get(false,"/globalVariables/")"
    If you comment out that line will it succeed with the rest?
    1 hour ago, jgab said:
    Can you try this?
    Commented out also line 552 -- --  for _,v in ipairs(vars) do rsrc.globalVariables[v.name] = v c1=c1+1 end
    but the same error
    [HC2]14:23:29, Thu Mar 14: HC2 SceneRunner v0.5
    #[HC2]14:23:29, Thu Mar 14: Reading configuration from H2C...
    #[HC2]14:23:29, Thu Mar 14: HC2 returned error '302 ' - URL: 'http://192.198.1.118/api/sections'.
    Program completed in 3.88 seconds (pid: 117700).
    pasting in a browser (Opera and Edge) worked ok again.
    Can you try this?
    I noticed when I write http://192.168.1.118/api/sections in the Browser it works ok, but when I copied the text
    from ZBS Output window and paste it into the browser it fails with Certificate error
    (Why HTTPS ?)
    Can you try this?
    I'm deeply sorry, my fault. Missed IP-adress !
    What i did write as answer after your first post. Good that it works now
    I was worried there for a while... :>
    Hi guys
    Can someone help me integrate miflora with ER  by using NODE RED.
    so far I have flow which produces a message and sends to ER, and it looks like :
    /monthly_2019_03/image.png.57bec3c227e412fd1d90c8d38af2916c.png" />
    in ER I created function based on telegram function :
     and the rule to see what is comming from nodered:
    but only what i see is
    [DEBUG] 15:14:00: Flora content:table: 0x86b2858
    how to get values for ex battery from this table ?
    i'm realy appriciated for any help
    Edited by domin12
    1 hour ago, domin12 said:
    Hi guys
    Hi, I pushed a new version of HC2.lua because I may have broken the POST command that node-red uses to post events to the emulator.
    Try that one and we take it from there.
    /J
    /J
    You know that the node-red has changed a bit with the emulator?
    /J
    Sorry, pushed wrong version
    Should be "0.5","fix2"
    1
    ok, will test it after upgrade, i'm still using old version _version,_fix = "1.15","fix12"
    o my..... so many things was happend here , how to quickly upgrade my old version ?
    trying move to new version, but after moving my rules got this error :
    ps. using HomeTable variable
    Edited by domin12
