9 minutes ago, jgab said:
Almost.
If you only have one bridge you can leave out the 'hue:' prefix. The default prefix is "Hue:", capital "H". The prefix is to distinguish different Hue bridges. You set _HueHubs to
{{name='Hue',user=_HueUserName,ip=_HueIP}}, and you can have many bridges with different names.
If it is only one id to monitor you can skip the table
The first argument to define ( "huevrum" ) is the name of the device in the Hue system.
In my HUE bridge the device i want to monitor is named LampaTV and located in room called Vardagsrum, so how should it be then?
Hue.monitor does not read the values from my HomeTable scene? And id(number) should be different than defined  n  HomeTable?
    A heads up.
    I have been busy working on a "Scene simulator" lately.
    It's a general emulator to run most types of HC2 scenes. However, my main reason for this is to change the EventRunner framework to run on the simulator.
    There are many benefits this will bring:
    -We can load and run multiple ER scenes that send events to each other. (I have already been able to find a bug in the publish/subscribe mechanism and pushed a new version of the old EventRunner.lua to GitHub :-) )
    -Emulated scenes can send and receive events to scenes running on the HC2 and vice versa...
    -We can have some (fake) devices that are handled by the emulator and still interact will real devices on the HC2 (same with globals)
    -An ER scene running on the HC2 can be told to stop processing the events and instead forward them to its copy running in the emulator...
    -The ER scene becomes more clean as a lot of setup moved to the emulator.
    -I can dispose of EventRunnerDebug.lua that was turning into a monster...
    -json and FibaroSceneAPI.lua is included in the emulator and don't need to be downloaded separately...
    -Oh, and ER will be bumped to version 2.0 :-)
    I'm still doing some tests but I have successfully run Supervisor, iosLocator, a light scene, and 2 publish/subscribe scenes in parallel - all pinging, subscribing, publishing at the same time.
    It's even possible to debug the publisher - consumer code that is the heart of the ER mechanism, set breakpoints and inspect variables, stepping etc.
    I have optimised the ER framework for the emulator so it doesn't do the millisecond polling. It can do it, the problem is if we run in _SPEEDTIME all the fans on my Macbook pro turns on max :-) Anyway, the performance is very good. The only thing that is not optimal is the socket server that receives incoming events from the HC2 (or node-red) as the current socket library requires polling the socket and  I don't want to drag in a dependency on another socket libraries (they tend to be OS native too)
    I will be back with a post on how to migrate... but it only effects the offline running of scenes. On the HC2 the framework behaves and looks the same...
    It doesn't matter in what "Hue" room it is. The name (LampaTV)  is unique (for the bridge)
    The Hue.define("LampaTV",nil,12004) looks up "LampaTV" in the bridge, and then creates a "fake" fibaro deviceID with 12004 that is "associated" with the Hue lamp "LampaTV".
    This means that we can do fibaro:call(12004,"turnOn") and other fibaro stuff, treating it as a dimmer switch...
    However, you need to assign the deviceID 12004 to something in your hometable, unless you want to use 12004 everywhere.
    The Hue.monitor, takes a deviceID and a time in milliseconds and starts a loop polling the state for the Hue device associated to the deviceID 12004 in this case.
    still error when trying Hue.monitor lines
    /monthly_2019_03/image.png.1569a990bdba1e31745084b0b088bb77.png" />
    some of the hue lines from my HomeTable scene
    Cold this morning, -18 :blink:
    Edited by jompa68
    Strange, below works for me. Is your _HueHubs correctly setup? What is the code around line 2137?
    Only -10 here :-)
    i have setup my HUE like this
    Function it stops on
    Edited by jompa68
    If you set _debugFlags.hue=true does the http request to the bridge look ok?
    you can post it if you change the hue username that is part of the url.
    Looks like payload is empty..
    When it reads the whole state in the beginning it’s empty. What does it log before it crash?
    nothing special, scene just restarts.
    /monthly_2019_03/image.png.3d0ee63f3bd115a339f0518c97f64728.png" alt="image.png.3d0ee63f3bd115a339f0518c97f64728.png" />
    So between 08:38:42 and 08:38:55 you restart the scene, right?
    It's strange that we don't get any log message before the "Hue connection error:_"
    All hue http requests go through this
    ...and it should log the message before the crash...
    You are running monitor on some deviceID when it crashes?
    Yes i do.
    16 minutes ago, jompa68 said:
    Yes i do.
    There are 2 self.monitor in the Hue section. Can you swap the second to this one so we can know what url it is monitoring?
    hope i got it right
    /monthly_2019_03/image.png.4a92b357c05fe547dcd282d93a2f89f7.png" alt="image.png.4a92b357c05fe547dcd282d93a2f89f7.png" />
    29 minutes ago, jompa68 said:
    hope i got it right
    Nja, I think you swapped the wrong one.
    It's the self.monitor that starts on line 1970 in the EventRunner.lua file on Githib.
    Updated to latest ER.lua but still same error.
    /monthly_2019_03/image.png.ec2075b402a5eb956311082397ba3d22.png" alt="image.png.ec2075b402a5eb956311082397ba3d22.png" />
    and you remembered to set _debugFlags.hue and apply the patch to self.monitor on line 1970? Because I don't see any log output.
    Yes all are set, sorry but it just stops...with that message.
    Can you run it in ZBS? Same error?
    If you can, break-point at line 1784 at entry of self.request and see what url you have?
    Next step, can you make minimal version of the scene with only the Hue rule that crashes and send it to me and I can see if I can simulate it?
    Must test that tonight. Working from other city today...
    No big deal with this, i can live without my new rule. Will convert to HC2 emu soon as possible.
