    2 hours ago, FrankT said:
    @jgab testing event_runner B14. Got this error :
    Program starting as '"C:\Program Files (x86)\ZeroBraneStudio\bin\lua.exe" -e "io.stdout:setvbuf('no')" "C:\Users\F\AppData\Local\Temp\.C16A.tmp"'.
    Program 'lua.exe' started in 'C:\Program Files (x86)\ZeroBraneStudio\myprograms\2B14' (pid: 21328).
    Debugging session started in 'C:\Program Files (x86)\ZeroBraneStudio\myprograms\2B14\'.
    Fri/Apr/12,12:55:55:[HC2 ] HC2 SceneRunner v0.7 fix2
    Fri/Apr/12,12:55:55:[HC2 ] Running speedtime
    Fri/Apr/12,12:55:55:[HC2 ] Local mode, will not access resources on HC2
    Fri/Apr/12,12:55:55:[HC2 ] Created Event server at 192.168.1.127:6872
    Fri/Apr/12,12:55:55:[HC2 ] Web GUI at http://192.168.1.127:6872/emu/main
    Fri/Apr/12,12:55:55:[HC2 ] Reading and decoding configuration from HC2.data
    Program completed in 1.20 seconds (pid: 21328).
    HC2.lua:687: attempt to index local 'rsrc' (a nil value)
    stack traceback:
        HC2.lua: in function 'loadConfigFromFile'
        HC2.lua:63: in function 'main'
        HC2.lua:204: in function 'startup'
        HC2.lua:3077: in main chunk
        [C]: in function 'dofile'
        BelysningER2_B14.lua:11: in main chunk
    Debugging session completed (traced 0 instructions).
    Could it be the structure of my HC2.data file?
    [{"devicemap":"{\"toa_dusch\":{\"takdimmer\":207},\"iOS\":{\"FranksiPad\":350,\"MargarethasiPhone\":138,\"samsungSM-T700\":203,\"iPhone10,6\":89},\"scene\":{\"TwoSpottarKoek\":45,\"LarmTelegramText\":304,\"TimeOfDay\":62,\"MarkisSovrum\":211,\"DoorBirdMotion\":178,\"MarkisTVrum\":213,\"ArmAlarmScene\":...……..
    And if that is the case what structure would HC2.lua expect?
    Unfortunately, the old eventrunner format is not supported. You have to create a new file by uncommenting HC2.copyConfigFromHC2(...) in HC2.lua in its main.
    It will read globals and devices from the HC2.
    Ok, thank you. Does work fine! Btw, what is the use of this statement  --dofile("HC2verify.lua")  in HC2.lua?
    Oh, it's just a file with test code that I run to see that there are no major errors in the emulator.
    Btw, I will fix so that it doesn't crash if the data file is in wrong format - thanks for spotting that.
    /J
    I have been busy restructuring most of the emulator. Have released v0.8 of the emulator.
    EventRunner is up to 2.0, B14
    -New emulator Web GUI with "main page" that have buttons for speeding the scene or jump 1 or 24 hours. Creating HC2.data file. Also scene triggers are available.
     that opens the Emulator GUI with a keyboard shortcut (Ctrl-Alt-E, or Option-Cmd-E on Mac). Also adds links to EventRunner and Emulator thread on the Fibaro Forum under the Help menu. Very useful actually.
    -The HC2.data format is new so please regenerate it (GUI or via HC2.lua main())
    -All resources start out as local/emulated (devices,globals etc). In your code you can enable them as "remote" (see below)
    -New functions available in _System.* to call the emulator from scene - see <
    -Emulator per default starts in "realtime" mode. If you want to speed call _System.speed(true) or use Speed button in web GUI
    -_System.* is callable from ER rules, which gives better control over how the emulation should run.
    Ex.
    Wrap _System.* calls in _EMULATED as they are not available on the HC2.
    Oh,
    • Thanks 2
    very nice :) Thanks @jgab
    I'm trying new version:
    I have this error in HC2.lua:974: attempt to index local 'd' (a string value)
    in this row:  for _,d in pairs(list) do if filter(d) then d._local=tp end end
    I assume you are doing a HC2.setLocal or HC2.setRemote that causes it.
    How does the call look like?
    and have you generated a new HC2.data file?
    I have this:
    No, so I did it,
    Now it works
    42 minutes ago, petrkl12 said:
    I have this:
    If you set a breakpoint there what is d? Looks like the data file is corrupt...?
    Now it works. I had old structure of data file.
    56 minutes ago, petrkl12 said:
    I have this:
    @jgab
    with %autostart it works without any problems
    but without %autostart scene is not possible to run - I have tried all options  - speed, 1 hour, 24 hours
    In one scene on HC2 I have got this error:
    [DEBUG] 19:39:09: Error loading rules:fibaro:get(nil)
    In ZBS it works ...
    In previous version it also works...
    Edited by petrkl12
    1 hour ago, petrkl12 said:
    @jgab
    If it doesn't have autostart it either need to be started by a sourceTrigger of type 'other' or with a trigger declared in the header.
    The "main" GUI page list sourceTriggers of type value or global declared in the header of registered scenes. And you can start a scene by setting their values to cause a sourceTrigger to be posted - like in my recorded youtube video.
    Otherwise, you can go into the "Scenes" tab in the Web GUI and press the "startScene" button for the scene. It will generate a 'other' scene trigger. You can also in son give an argument to startScene.
    In ZBS it works ...
    This is tricker... Seems like you call fibaro:get with a nil value - typically a variable that is not initialised (HomeTable?).
    Do you have any idea what rule it is that causes it?
    OK but there is error - Aborting: Server not started yet - because main scene doesn't work
    This is work. Thanks
    Maybe could be prefect to add button for run scene in main page.
    I don't have idea. It's interesting that it runs in ZBS and in previous version. Issue is that error message is not too much specific (ie. number of row)
    Edited by petrkl12
    Yes, maybe a start/stop button in the main page for registered scenes.
    ...I think I know why and it was all my fault - did you turn on logging of fibaro:get and getValue? _debugFlags.fget=true ?
    Anyway it was a bug in logging code that I fixed. Pushed a new version of both HC2.lua and EventRunner.lua
    See if it works for you.
    If this is the reason I'm not sure why it worked on ZBS...
    /J
    still error but with better description :)
    [DEBUG] 21:05:36: Error loading rules:fibaro:get(Koupelnaprizemi.Vypinacuzrcadla,"TCPPort"),/opt/fibaro/scenes/228.lua:3206: attempt to compare nil with number
     row 3206:   if id < 10000 then return fibaro._get(obj,id,...) else return fibaro._idMap[id].get(obj,id,...) end
    Edited by petrkl12
    Looks like Koupelnaprizemi.Vypinacuzrcadla is nil?
    unfortunately I’m away on a trip and will not be able to to any tests until Saturday.
