No, I guess that problem will be with reading of value from TCPPort
    Maintenance release of EventRunner.lua, HC2.lua, and HC2Plugin.lua
    EventRunner has a patched setTimeout that allows for times longer than 74 days... and better error handling on calling fibaro:get/call on null deviceIDs and other small fixes
    HC2.lua only minor fixes
    HC2Plugin.lua uses loop-back 127.0.0.1 to get to the server, allows to connect when no network present.
    Have been chasing this but can't replicate it unless the deviceID really is nil. I have added more checks in the code.
    Is it still a problem?
    /J
    It wasn't nil -  it was string but it was OK in previous versions.
    So I had to add conversion tonumber() into every get and call commands -  now it works
    Hi jgab,
    I started with your Event Single scene but be patience with me.
    I have some minor probs to understand
    --There are 5 curtains to close , can I change on in close? and prefereable 5 sec in between to close OR can I add the "curtain close scene"? No idea how
    -- if the curtains are closed (should be nice)
    Than to open I think I need to add the time of tghe day to prevent pendeling of the curtains >> I do not know how
     -- Trigger rules
      Rule.eval("myLightSensor1:lux < 60 => myCurtainFront:on")
      -- I prefere 5 sec break to imitate "hand"closure of curtains
      Rule.eval("myCurtainFront:isOn => myCurtainSideBicycle:on")
      Rule.eval("myCurtainSideBicycle:isOn => myCurtainSideCar:on")
      Rule.eval("myCurtainSideCar:isOn => myCurtainBack:on")
      Rule.eval("myCurtainBack:isOn => myCurtainBackSide:on")
     -- this will conflict with above how I can add GV timeofDay
      Rule.eval("myLightSensor2:lux > 105 => myCurtainFront:on")
    2 hours ago, Sjakie said:
    Hi jgab,
    Ok, wait is easy, this will close them in sequence with 5secs interval
    Could also do something like below but then you need to repeat it for the second sensor rule.
    If you only want it to happen once in the morning and once in the evening you can do
    05:00..09:00 is a test only true in that interval, once(<expr>) is true the first time the expression is true and then need to be false before it can become true again. Effectively limiting the rule to be true once between 05:00..09:00 if sensor1 is less than 60.
    Shouldn't the last test be something closing the curtains?
    I need to understand it. Its  complicated at this moment. I was working with GV mostly now I must get rid of that way of thinking. Yours is more flexible you can change any line in what you want!
    on = close off is open?
    I installed ZeroBrane and that is more clear to work with as in HC2 (as long it will not give an error, hahaha
    :on and :off translates to fibaro:call(Dev,”turnOn”) resp “turnOff”, so it depends on what your devices react on.
    Hi jgab,
    I  start to understand (I hope)
    please check if you want this is my 2nd scene later I will join them together.
    If luxlevel < 3 light on in steps of 5 seconds.
    than depends is PresentguestBeneden is ligyht goes on yes/no (no guest light on)
    But in case light is not switched on still give the command together with other lights to switch off?
    In my opinion the easiest way oris there a better way.
    Remark: I changed the GV in a device ID (presence of guest boven/ beneden.
    Please correct me?
    btw Zerobrane is not showing that terrible red dot if  you copy and paste!!!
    Thanks in advance
     Rule.eval("myLightSensorBuAchter:lux =< 3 => myVerlFietsenhok:on")
      Rule.eval("myVerlFietsenhok:isOn => wait(00:00:05); myVerlVlag:on")
      Rule.eval("myVerlVlag, PresentGastBeneden:isOff => wait(00:00:10); myVerlGastAchterdeur:on")
      Rule.eval("myVerlVlag, PresentGastBeneden:isOff => wait(00:00:10); myVerlBeeldBuiten:on")
      Rule.eval("myVerlVlag, PresentGastBoven:isOff => wait(00:00:15); myVerlSerre1x:on")
     Rule.eval("myLightSensorBuVoor:lux > 3 => myVerlFietsenhok:off")
     Rule.eval("myVerlFietsenhok:isOff => wait(00:00:05); myVerlVlag:off")
     Rule.eval("myVerlFietsenhok:isOff => wait(00:00:20); myVerlGastAchterdeur:off")
     Rule.eval("myVerlFietsenhok:isOff => wait(00:00:25); myVerlBeeldBuiten:off")
     Rule.eval("myVerlFietsenhok:isOff => wait(00:00:30); myVerlSerre1x")
    If I run the EventRunner I see 20 light blue lines in debug, I hope it will be executed tomorrow.
    One was red but after some time I found out that => 3 causes that error, changed iyt in only > 3
    How to write
     Rule.eval("23:15 => myVerlVlag:off")
    I tried wit @  n all are wrong
    thanks in advance
    How to write
    thanks in advance
    You mean in the debug window on the HC2?
    Light blue and rules being defined and there is usually one red line in the beginning too ("Slow mailbox watch:...") that can be ignored.
    Other red lines are usually errors in rules.
    I don't understand the "I found out that => 3 causes that error, changed iyt in only > 3" . can you elaborate?
    Ok, '=>' is used for defining a rule (<test> => <actions>), >= is the comparison test, like 7>= 3....
    Rules that should happen on a specific time is written with '@'
    will turn off device 'myVerlVlag' at 23:15 in the evening.
    12 hours ago, Sjakie said:
    Hi jgab,
    I don't understand, can you elaborate..?
    Please correct me?
    Are any of the variables fibaro global variables? I assumed that 'PresentGastBeneden' is a device?
    You can also easily use global variables in rules if you need to (prefix with '$')
    ZeroBrane is not showing the dot which is a problem... my HC2 emulator tries to inspect the code for a dot and log a warning.
    Thanks in advance
    I think what you want to do is
    The sixth rule will trigger every time 'myLightSensorBuVoor' reports a lux value larger than 3. To avoid that and only trigger once do
    That means that 'myLightSensorBuVoor' needs to go below 4 before it can trigger on a value greater than 3 again.
    Good morning,
    Understand the comment.
     Rule.eval("once (myLightSensorBuVoor:lux > 3 => myVerlFietsenhok:off")
    gives an error
    /monthly_2019_04/image.png.54a25ff528667f186a8297b6cd0e2333.png" alt="image.png.54a25ff528667f186a8297b6cd0e2333.png" />
    1 minute ago, Sjakie said:
    Good morning,
    gives an error
    You are missing a ')' after the 3 to close the parenthesis.
    Are any of the variables fibaro global variables? I assumed that 'PresentGastBeneden' is a device? >>>>>>Was a GV but in reality its a push button
    How too?
    $TimeofDay,Morning
    Thanks in advance
    How too?
    $TimeofDay,Morning
    Thanks in advance
    So, you can set and get globals easily,. They have to exists or you get an error. Note that they always return strings but it works to compare a number with a string in rules.
    Hi, is there a bigg diference in or using GV or trigger from device? I asume device trigger is faster and less load for the HC2?
    If you have a switch or pushbutton it's better to trigger directly on them changing state, then to first set a GV and then trigger on the GV.
    You can also trigger rules when GV change values
    will trigger the rule whenever you change the value of the GV 'TimeOfDay' to "Morning". Ex. if you do it from a VD, (or from another rule)
    Thought so, thanks for now I gonna make some triggers and have the intention to go "live" today.
    Have a nice day!
    The installation instructions for EventRunner was terribly out-of-date and have been updated. I will improve it over time (and maybe do another video)
    At least it is correct now with the introduction of the HC2 emulator.
    At least it has become much easier to install now with less files to depend on, just HC2.lua... :-)
    aha good, a few of your download links did not work either.
    Perhaps a good idea for newbies like me to add a few more examples of how to trigger and to execute. I was lost in all the scenes after reading 49 pages here on the forum, hahahaha
    You know I started a few months ago with event runner but it was to complicated for me. So I started with converting block scenes in LUA.
    I regret the way I did if I had more currige to continue with event runner my life should have been more easier.
    As far as I see it now, a few things are running now with event runner.
    Heater and announcement still to solve and after that all my scenes are in event runner I will also move my arm/ disarm
    My compliments for this excellent tool and for sure I will come back to you with other questions or minor problems.
    Thanks again
