Hello jgab,
In my heater scenes I use something listed as below to execute its basically two parts, one call http to set my thermostat and two a spoken message by Sonos to inform us what is done.
I amm unable to put it in the Event runner for that I need your assistance.
Perhaps I must add it as a scene? but I do not know how.
Please advice
    --aanroepen http request
local http = net.HTTPClient()
function call(url)
  http:request(url, {
      options = { method = 'GET' },
      success =function() fibaro:debug(url.." ,done.") end,
      error = function(errorcode) fibaro:debug("error=" .. errorcode) end
call("http://192.168.1.101/data.json?heater=0&setpoint=167&thermostat=0")
--end http request
------Sonos
  -- 249 is the Virtual Device ID
-- 28 is the Process button ID
local sid, bid = 249, 28
-- Create TTS params object
local params = {
  -- TTS Message
  message = "Hallo en goede morgen, Saartje zet de verwarmingsthermostaat naar thuis 21,7°C",
  duration = 'auto',    -- Duration: "auto", xx seconds
  language = "nl-nl",    -- Language: fr-FR
  volume = 50            -- Volume
local _f = fibaro
local _x ={root="x_sonos_object",load=function(b)local c=_f:getGlobalValue(b.root)if string.len(c)>0 then local d=json.decode(c)if d and type(d)=="table"then return d else _f:debug("Unable to process data, check variable")end else _f:debug("No data found!")end end,set=function(b,e,d)local f=b:load()if f[e]then for g,h in pairs(d)do f[e][g]=h end else f[e]=d end;_f:setGlobal(b.root,json.encode(f))end,get=function(b,e)local f=b:load()if f and type(f)=="table"then for g,h in pairs(f)do if tostring(g)==tostring(e or"")then return h end end end;return nil end}
-- Make a request to the remote to process params object instantly
_x:set(tostring(sid), { tts = params })
_f:call(sid, "pressButton", bid)
    46 minutes ago, Sjakie said:
    Hello jgab,
    Please advice
    It's easy to mix Lua and event rules. Just make Lua functions and call them from rules - best of both worlds :-)
    I'm not familiar with the Sonos VD you use so I may have done something wrong. I tend to run Sonos and integration towards other systems with Node-red.
    Hi jgab,
    sometimes I see a few lines now much more with Server not started yet
    /monthly_2019_04/image.png.37fb0b4a0006ae13fa7038f915b14a7d.png" alt="image.png.37fb0b4a0006ae13fa7038f915b14a7d.png" />
    That happens if the scene is not started yet (EventRunner scenes starts with %%autostart or manual start). I would recommend that your EventRunner scenes have %%autostart - EventRunner scens are expected to run continuously.
    If you have device or globals triggers in the header of the scene (%%properties etc), the HC2 will try to start the scene even if it has not started. EventRunner detects that and logs a warning.
    In your example, the scene receives triggers between 20:15:15 and 20:23:56 while it is not started yet. Then at 20:24:25 you start the scene, and it will start to process triggers...
    In theory I could make ER scenes "autostart" when they get their first trigger but I like to have better control when to start them. Maybe an configurable option in the future.
    So, in practice you can ignore the warnings - it's just that the scene is receiving triggers but has not been started up yet.
    Good mornig jgab,
    This is not working what I am doing wrong?
     --TV
       Rule.eval("mystekkerStoelSjaak:power > 3 => mystekkerTV:on")
         Rule.eval("stekkerStoelArleta:power > 3 => stekkerTV:on")
      Rule.eval("mystekkerTV:power < 25 => stekkerTV:off")
    thanks
    11 minutes ago, Sjakie said:
    Good mornig jgab,
     --TV
    thanks
    Have you declared  'power' as %%properties for the devices in the scene header?
    If you set _debugFlags.triggers=true do you see the incoming sourceTrigger with propertyName='power' ?
    Good mornig jgab,
     --TV
    %% properties
    14 value
    16 value
    18 value
    48 value
    54 value
    mystekkerTV             = 16
    mystekkerStoelSjaak     = 14
    stekkerStoelArleta    = 18
    Good mornig jgab,
    I changed value in power no difference
    Devices you want 'power' events from need to look like
    Also, power events are notorious for arriving in batches... I would expect you need to do something like
    The list in debug is only ding and dong
     --TV aan >> Licht aan
       Rule.eval("mystekkerTV:power > 100 & myCurtainFront:isClosed => myVerlEetkamerPlafond:on")
    gives error(I am doing it wrong )
    The "Ding Dong" you can remove :-)
    It's only
    No "set _debugFlags.triggers=true"
    The rule doesn't work as there are no :isClosed command defined.
    What are the Fibaro:call and fibaro:getValue commands to control your curtains? Can you use "turnOn" and "turnOff". If so you can use :isOff, :isOn.
    Open, close works
    on off does not work
    set value 100 is open
    set value 0 is close
    For me wierd I do not see any trigger is listed
    /monthly_2019_04/image.png.911c02c1ed9fc8f3d0dc6624519fdf15.png" alt="image.png.911c02c1ed9fc8f3d0dc6624519fdf15.png" />
    since 1.30 hour no incomming events.
    Let me go back a vew revisions to see where it was going wrong, my previous version shows immediately incomming events
    Hi jgab,
    I am lost, I saw in comming events now none I open a door started my fountain nothing is listed?
    /monthly_2019_04/image.png.196390b45d21d29d63ba03fc951aadd3.png" alt="image.png.196390b45d21d29d63ba03fc951aadd3.png" />
    2 hours ago, Sjakie said:
    Hi jgab,
    Hi, I posted you a version of the scene (complete with the framework)
    I made some updates to support open/close/isOpen/isClose.
    There were some other syntactical bugs in your script.
    Anyway, have you tried to run it in the emulator?
    That is a good way to catch bugs and test your logic.
    Ex. I set _System.speed(true) to run it faster than realtime to see if timers run at the right time....
    Ex. At the end of the scene I simulate some trigger to trigger the rules. That is a way to see if you get what you expect
    ...These steps only work if you run offline emulated.
    Why you didn't get any triggers I can't tell. Sometimes it seems like scenes need to be re-saved to make the HC2 register the triggers (you have a lot of trigger!)
    mmmh what shall I say, at first thank you very much for your excellent support. Do I have a lot of triggers? I dunno.
    One off my manager say that humans are lazy an pointed to me>> he is right!
    There for I have home automation to make my life easy (at least after some time)
    When I adjust my chair or the TV and light switch on, no handy or phone needed. So at the moment before I started with ER almost everything was working well without any interference from me.
    If Tv is on and curtain closes TV light goes on if not normal light goes on, Kitchen I am not happy with but must think what  to do with it.
    After some relax we go to bed and and all goes out and complex will be armed according who is present. The outside lights have their own scedule.
    I am on the way to become a happy camper espacially with your help.
    Next project will be what you mentioned and I saw on Gompa's video Node red for voice control of theTV and others.
    In ZeroBrane
    xecution error:
    cannot open HC2.lua: No such file or directory
    Program stopped (pid: 4964).
    Debugging session completed (traced 0 instructions).
    Program completed in 10.79 seconds (pid: 4964).
    remark:
    I switched all HC2 scenes on manual (except arm/disarm) to avoid some wierd behaviour.
    Now I am curious what will happen later on today
    For the heater its not okay the http is giving an error and the sono is giving the message while it is afternoon.
    Question I am using GV for time because if HC2 the exact time is missing the GV is catching it up. So if ER mis the exact time what happens or Er cannot miss the rule that should be nice than I can work with fixed times
    That is why you see tow triggers
    Thanks in advance
     --Avond
      Rule.eval("$Dagdelen=='Avond' & $Stookseizoen=='Ja' & LocatieGezin:ison &  deurnaarSerre:isSafe => httpGet('http://192.168.1.101/data.json?heater=0&setpoint=171&thermostat=0')")
    function call(url)
      http:request(url, {
    --call("http://192.168.1.101/data.json?heater=0&setpoint=171&thermostat=0")
      -- 279 is the Virtual Device ID
    local params = {
      -- TTS Message
      message = "Hallo, Saartje zet de verwarmingsthermostaat naar comfort avond 22,1 °C",
    local _f = fibaro
     Rule.eval("@14:10 => httpGet('http://192.168.1.101/ data.json?heater=0&setpoint=167&thermostat=0')")
    /monthly_2019_04/image.png.bc700cc4ef68c87aa850332456d1ab70.png" alt="image.png.bc700cc4ef68c87aa850332456d1ab70.png" />
    In ZeroBrane
    xecution error:
    remark:
    Thanks in advance
     --Avond
    function call(url)
      http:request(url, {
    local params = {
      -- TTS Message
    local _f = fibaro
    Well, you have not used the code I posted where I wrapped the httprequest in a function named httpGet - then it's not surprising that you get errors....
    ...and  the Sonos that become a speak(...) function.
    To run in ZeroBrane is really simple if you follow the instructions. Put your s scene (EventRunner.lua) and HC2.lua in the same directory and set ZeroBrane's working directory to the same directory as where you put those files.
    Writing code is never easy...
    ER never "miss" a time, however, the execution of a rule can be a second or two delayed if the machine is busy.
    I would still advice from starting them manually. Develop on the PC until you are sure that the scene behaves the right way. Then deploy on the HC2 and let it run.
    One reason for this is that when you get more than one ER scene you can do some interesting inter-scene communication and there is a Supervisor scene that can keep
    track of the ER scenes (Keep-alive pings) and restart them on failure etc.
    There are "strategies" to do rule catchup if the scene is restarted - let's get to that when you get the basic up and running.
    Sorry jgab,
    I copied and past the http changed the time and error>>>>>>>>>>>>in the "old"lua I am sorry!
    In the latest file it will accept the same rule!
    If I go and push your link download Event runner.lua  and HC2.lua it will open! If I save in notepad it give me warning some signs will be .....
    Sorry to be a pain in the rear end
    Both files are visible in Zero
    this is zeroBrane giving me
    Execution error:
    HC2.lua:1147: File load error: cannot obtain information from file `runner.lua' in C:\ZeroBraneStudioEduPack\myprograms
    [33mThu/Apr/25,15:41:50:[HC2 ] HC2 SceneRunner v0.8 fix12[0m
    [33mThu/Apr/25,15:41:50:[HC2 ] Local mode, will not access resources on HC2[0m
    [32mThu/Apr/25,15:41:50:[HC2 ] Created Event server at 192.168.1.184:6872[0m
    [32mThu/Apr/25,15:41:50:[HC2 ] Web GUI at http://192.168.1.184:6872/emu/main[0m
    [35mThu/Apr/25,15:41:50:[HC2 ] No HC2 data file found (HC2.data)[0m
    [35mThu/Apr/25,15:41:50:[HC2 ] Configuration from file, Globals:0, Scenes:0, Device:0, Rooms:0[0m
    I did it again and copied from github hehe its running
