All-in-One Scene: How to do it Better
cag014
11 minutes ago, Sjakie said:
//sjakie
nothing happens
Yes, but have you added a true/false at the the end
It looks like the plugin should react to that.
Jan,
yes this I add no result the Logitech HUb stays on green led
If I press in preview  sgtart or stop >>>green led fickers and device will be switch on or off
in HC2 it was working very good
with changeActivityState
  • On 4/16/2021 at 10:50 PM, Sjakie said:
    Jan,
    Could you open developer/network in browser and to see what command sent when you press in preview mode?
    Is this what you wanted to see? Play and stop:
  • Looks like it uses "play", "stop" commands....
    Did you try (where "play" and "stop" are strings?)
    @Sjakie
    Another idea,
    try to create block scene with the Logitech, convert to LUA  and see what is the command there....
    Edited by cag014
    That I already tried also but  I can not select any main or child device of Harmony in block scene
    please try to use it as follow
    fibaro.call(<Harmony Device ID>, "changeActivityState", "true")
    fibaro.call(<Harmony Device ID>, "changeActivityState", "false")
    Again please note that true and false are strings, not as you executed previously
    fibaro.call(<Harmony Device ID>, "changeActivityState", true)
    fibaro.call(<Harmony Device ID>, "changeActivityState", false)
    @cag014 and JGab,
    This did the trick hehehe thankssssssss!
    This will boost the waf!
    Thanks again and have a nice weekend,
    //Sjakie
    Any AOQ advantages or disadvantages when updating from 5.050.13 to 5.070.42?
    I think no. I can't see the Satel alarm systems's icons. Maybe the RAM usage better.
    Edited by SmartLifeSystems
    I want to turn off automation section by fibaro double switch. I mean the light bulb turns off automatically for no movement, but if you turn on and off the wall switch for 5 seconds 3 times then turn off the automation for an hour. Am I right:
    - one variable of the last on/off (lastOn)
    - variable counter
    - variable automation
    - on the trigAll I check the lastOn, if it is more than 5 seconds then the counter = 0, otherwise +1. Also, if the counter is more than 3 then automation = !automation
    That's right, is there an easier way?
    Since I have more than 10 such devices, I want to first consult with experts)
    I think it will be to complicate  and hard to maintain in the future. You must to find another way to set automation off.
    for example I have same option in my bedroom, to stop automation I use s follow:
    If motion sensor breached and lights turned off manually withing 10 seconds, it means stop automation for 2 hours. Very easy to set condition for that.
    Another way is perhaps to use AOQ Remote. You can turn ON/OFF automation from the phone with no counters and global variables at all.
    Could you please explain what is the reason to turn OFF automation for an hour? Might be there is another solution for that.
    Edited by cag014
    For example, the guests are already in the corridor, the lights are on, and they are not going yet, talking.
    Because they do not move, the light turns off and you have to wave your hands.
    Or soldering in the garage and not moving for a time.
    And I think the easiest way it's swich on/off/on this switch for disable automation.
    Otherwise I need to have a phone or remote control in my hands.
    So, instead of waiving your hands , you need to turn off - > on the switch 3 times within 5 seconds ?
    May be you can increase the delay time during normal hours (like 8:00-22:00) and to set shorter delay over the night?
    Another "smart" option is to add motion sensor and then you can know if the person entering or leaving the place and to control the lights accordingly (I'm using that in my parkway and garden to control the outside lights )
    In any case your solution looks fine as well.
    Edited by cag014
    Hello Cag,
    I need to reduce the number of messages I get.
    It is sending me
    I dont have a device with 681 anymore Also 682 is dead but that belongs to same device .
    So I have more notifications of "non" excisting devices.
    With API I cant remove them either because they are not excist.
    How to solve?
    //Sjakie
  • 12 hours ago, Sjakie said:
    Hello Cag,
    It is sending me
    How to solve?
    //Sjakie
    What do you mean by I don't have the device? Did you remove it from the system?
    Please verify that this device not exists in your system (not seen on UI anymore)
    All-in-One receives dead notification from the system and reacts accordingly, meaning the device is still in the system and keeps your controller busy with dead traffic.
    Cag,
    I have more dead not excist anymore devices.
    If I add or re-add first I remove from system than add
    So I think those devices are from stone age.
    //Sjakie
  • 1 hour ago, Sjakie said:
    Cag,
    //Sjakie
    You must to remove them from the system somehow. You can remove manually from UI
    Cag, thanks
    In swagger you can delete devices I did yesterday but it reports error device not found! I will contact support.
    I have one wall plug shows 3 devices, Binary sensor and 2 Multi level sensor>>>>>3 times a warning (one for each device) can this be reduced into one?
    //Sjakie
    My smart implant give notification dead (13 devices!!) and direct after its awake again 13 devices.
    It are 26 ting ting.......... and offcourse panic attac
