    The way to activate a rule at 07:00 or sunrise if sunrise comes before 07:00
    rule("@min(sunrise,07:00) => log('Wake up')")
    To activate a rule at sunset or 22:00 is similar
    rule("@min(sunset,22:00) => log('Go to bed')")
    Sometimes you use max(...) if you want to select the later time.
    Hi @jgab
    What's the best way to post or start a rule every full hour during the day. With the truefor loop you can set something to start every 60 min but not exactly at a specific time.
    I thought something like this but unfortunately it doesn't work.
    Every hour between 07:00-23:00
    Hi @Sjakie
    Thank for your response!
    I tried this with a 10 sec interval but I think it's a bit the same as with @truefor. It starts the interval from the moment the rule is activated. I would like it to start exactly at 10:00, 11:00 etc. Instead of 10:20, 11:20 etc.
    Hi If you test a rule you must give the rule the possibility to start!
    If yo chofes 10 second the rule should not activate after save but 10 seconds later
    you will notice it work.
    save this rule before 20:30
    Ah that will be it. I'll test it when I get back home.
    Thanks!
    It's correct that the time loops (@@) starts immediately so @@01:00 will run every hour but the exact when in the hour depends in when it started.
    The good news is that @@ is drift free, so it will run exactly every 3600 seconds in this case.
    If you want it to run exactly on the hour you can do
    or factor out the action
    (I just realised that there is no good way to do integer division in ER4 - will probably introduce the // operator in next version)
    If you are not so picky about the exact second, but want it to run in the first minute of the hour you can use the date() function that is a bit like unix cron - and the cron in HC3 scenes
    Here we set _debugFlags.rule=false, or you will get a log every minute when trying the rule - a bit annoying..
    Another way is to list the hours explicitly in the @ command.
    Ex-
    rule("@{00:00,01:00,02:00,03:00,...} => ...")
    Unfortunately, it's a bit tedious to list 24 times - and we are not allowed to use ...
    What we can do is generate the list to @
    A time constant is translated to number of seconds since midnight, 01:00 becomes 3600, 02:10 becomes 2*3600+60*10 (that is also why we can easily do math with time constants in ER)
    So, our HOUR list needs to contain {0, 3600, 7200, ... }
    Jan, can we do this also with a Global Variable?
    or is it
    We could also do this to generate a on the minute and on the hour event
    or is it
    I don't think I understand.
    First line you post an event (in 11 minutes)
    Second line you trigger on that event and set a global to 'Yes'.
    So, what do you want to do 'also with a Global Variable' ?
    Jan I need 30 minutes after $Lichttoestaan == 'Yes' another GV $Lichttoestaan = 'Nee'
    I want to do it without post
    a kind off $Lichttoestaan == 'Yes',+/00:11
    Edited by Sjakie
    You could do
    That would always set it back to 'Nee' after 30min.
    But you need to be careful as it will always wait 30min and set the var to 'Nee', even if you toggle the var before (set it to 'Yes' and 'Nee')
    Hi @jgab, @Sjakie
    Thanks both for your solutions!
    The last solution is the clearest read to for me and quite flexible to schedule at other exact times as well.
    I find the method with the post difficult to read and do not yet understand well enough how to apply it. Still have a lot to learn.
    Hi @jgab
    I am still struggling to apply it so that it is executed for a particular section. I am trying this but this is not working.
    Under the fibaro.EM.SECTION = nil:
    In the section:
    The minute event you setup so that it's always posting events on the minute.
    Then you enable/disable the other rules that trigger on that event
    This works great now! Thanks again for your support.
    Jan what's better to use in ER
    Rule.eval([[$Test='A' | $Test='B' | $Test='C' | $Test='D' =>
    or
    Rule.eval([[!$Test='E' =>
    It should be == if you want to test for equality. = is assignment.
    Rule.eval([[$Test=='A' | $Test=='B' | $Test=='C' | $Test=='D' =>
    You mean that the alternative would be
    Rule.eval([[!$Test=='A' => ..
    Rule.eval([[!$Test=='B' =>
    Rule.eval([[!$Test=='C' =>
    The first is a bit faster as the it only needs to trigger one rule.
    Jan, yep sorry was in a hurry.
    Getting error
    ! has higher priority than == so you need parenthesis around it
    or you use ~=
