Hi @jgab
I have two sections and two profiles, "Home" and "Away". These two each call their own set of rules.
This all works fine.
Now I would like to use a third profile "Quests". This section contains an extra rule set compared to Home. So I would like when this profile (Quests) is selected to activate both the "Home" and "Quests" sections. I was thinking of doing this as follows.
But unfortunately now only the Home section is addressed if Quests profile is active.
Do you have a solution for this?
Jan, thanks.
I see this error but I have no clue what, where to find
Rob,
If you change 'Quests' in 'Away' it should do what you want
    18 minutes ago, Sjakie said:
    Jan, thanks.
    Rob,
    Add this to your main()
    and you will hopefully get a better error message,
    Hi Sjakie,
    Do you mean this?
    Then (I think)  when I switch to profile Quest it enable Away and Home and not Quests. I want to enable both Quests and Home sections when selecting profile Quests.
    Jan, it does not give additional info for this error.
    @Rob sorry I mi understood I thought Quests = Home + Away
    Perhaps more smart to put in Quests what you have in Home too, I had also something similar but splitter it after wards
    @Sjakie
    That's a solution but then I must duplicate and maintenance all the rules twice... I don't like that ?
    Other solutions are welcome.
    How does the rule
    look like?
    No, that's not the rule that creates the error.
    Could you go into fibaroExtra in the QA and around 2131 replace the post function with
    it makes an extra check that an event is really posted - that seems to be the error you have (someone posts(nil))
    20 hours ago, RobLu said:
    Hi @jgab
    enable('Home',true) will enable Home and disable all the other. Then enable('Quests') without the second 'true' will enable 'Quests' but not disable the others, so Home is still enabled.
    Wow what a powerful tool that Eventrunner is. It works great! Thanks again for your support Jan!!
    @jgab
    I have problem with new version of QA Updater v.0.67:
    ./include/main.lua:121: bad argument #1 to 'for iterator' (table expected, got string)
    10 hours ago, petrkl12 said:
    @jgab
    Sorry, it was a bug in the data format. If you do a refresh now in QAUpdater it should parse the version file correctly.
    It works now, thanks
    Jan after refresh
    Wiers if I refresh again the error disappeared
    Edited by Sjakie
    I have these two rules triggered from the Global variable "DayControl"
    these rules control the
    Some time i have special light set on the LEDs, that i won't have the DayControl overrules, but start following the DayControl when turned off.
    How should this be created in EV4?
    another issue it with around 100 LEDS it is way too slow to read all the
     from the zwave network
    any guidance or help would be appreciated -  but it should run in EV4.
    rule([[$DayControl=='NAT' =>
    fibaro:setGlobal(baths, colorvalue.Normal)
    fibaro:setGlobal(rooms, {2,64,0,16};)
    fibaro:setGlobal(common, colorvalue.Low)
            rooms.baths:color=colorvalue.Normal;
            rooms.rooms:color={2,64,0,16};
            rooms.common:color=colorvalue.Low;
    rule([[$DayControl=='Wake-up' =>
            rooms.rooms:color={64,64,0,16};
            rooms.common:color=colorvalue.High;
    •    Turn on special color
    o    Set Matrix Color to eg {255,255,255,16};)
    •    After “Turn Off special Color”
    o    Set Matrix Color to fibaro:getGlobalValue(baths)
    •    When “DayControl global variable” Change ->
    o    If existing Matrix Color = special color is set(ls different from last DayControl color set) -> Don’t change color
    o    If color = Normal color (Set from last DayControl Change Color) change color to new DayControl Color
    Edited by ChristianSogaard
    P
    Good morning Jan,
    I have some difficulties to get it work.
    From Joep Verhaeg his P1 monitor QA I want to use some values
    This comes from QA 1840 as String variable it is listed in >>Variables (but not listed in Global Variables) >>> daystart_power_import_t1_kwh
    how to use in ER?
    Thanks in advance,
    Edited by Sjakie
    22 hours ago, Sjakie said:
    Good morning Jan,
    how to use in ER?
    Thanks in advance,
    You mean that it's quickAppVariables - listed in the Devices>>Variables ?
    "Energie_Verbruik_T1" etc?
    quickAppVariables can be accessed with $$ infront of them
    Ex.
    In general, your rules has some syntactic errors (keep an eye on the ending semicolons)
    fibaro.setGlobal I assume that you mean fibaro.setGlobalVariable ?
    It's the bath variable that is normal or special?
    I would set a variable to remember that the color is set to special and then in the DayControl rule check for that.
    Ex.
    and the rules that set specialColor and unsets specialColor updates the variable.
    I don't understand the
    "another issue it with around 100 LEDS it is way too slow to read all the
     from the zwave network"
    Every time the color changes for the led it's stored in the HC3 so when you do fibaro.getVariable(X,"color") it's fetched from the HC3 and goes very fast.
    On 8/27/2022 at 9:57 AM, Sjakie said:
    Good morning Jan,
    how to use in ER?
    Thanks in advance,
    or is it the 'daystart_power_import_t1_kwh' that is quickAppVariable or globalVariable?
    Not so easy to guess from your explanation...
    Ex.
    Hi Jan  Thank you for providing ideas and fixes :-)
    I have chosen to go a little other direction.
    I shared a little of my HTab used in EV4.
    Perhaps you can show how within EV4 remove an entry from this local HTab ?
    Example
    • remove 1000 from rooms.all in local HTab
    • ADD 1000 to rooms.all to local HTab
