hi jgab
When I run ZB, I get an error
    Pull down the latest version of EventRunner4Engine.lua
    For a few minutes yesterday I managed to push a faulty version and you must have pulled it down at that moment...
    /J
    I looked at the repository and the 'missing then' bug was still there - to be sure I have pushed a new version of ER4 v.0.84 with the fix
    Jan it does't update.
    work
    thank you
    Sorry, misspelled tag. It should work now.
    hehe I started to doubt on myself :)
    Yep all are updated now, thanks!
    Jan is something like this possible?
    If having QA with 2  buttons can I trigger on button?
    On 7/14/2022 at 12:24 PM, jgab said:
    Yes, you need to put the loop that loads the rules after you define the HT table, otherwise it's not available when they are defined.
    Actually, maybe it's better to put the loop at the end of QuickApp:main() so your main rules load before the modules' rules.
    I really like this way to structure Eventrunner.
    Today i have only one EV4 instance with more that 100 rules
    Hi @jgab
    I get after a while an Error in ZB, version 0.86.
    14 minutes ago, RobLu said:
    Hi @jgab
    That error comes from code used to update the running QA from the TQAE/ZB web interface.
    There are very special conditions when that should be used (you need to download the QA from the HC3 and push back updates - it's a bit of a wireline act...)
    - and I haven't looked at that code for a long time - it may be broken. So I don't recommend that "work flow".
    I would recommend enabling the proxy feature and upload real QA when it feels finished.
    Hi @jgab
    I would like to create a log notification after every profile switch between "Home" and "Away".
    In the code below the log is only executed at the start of the Eventrunner. At a switch of the profile it is not executed anymore. Is there a possibility for this? The repeated log statement is executed after switching profiles, but I want only ones.
    The problem is that you want to run something (e.g. log) when an section becomes active. But the enablement of a section just makes rules active - it doesn't trigger them. For that it needs some event or device changing state.
    If you just want to log when the profile changes make a rule that trigger on profile event - like your last rules.
    If you want to run specific stuff in each section when they are active, post an event they can trigger on.
    Thanks a lot this is the best way to do it!
    Now it has also become much clearer to me how the Events/triggers work. I had already adapted my code with a .start() this also works.
    Which method do you prefer Event or starting a rule with .start()?
    .start() will run/trigger the rule when the rule is defined. Once.
    will trigger the rule when it's defined and if device 77 is on, the action will be carried out. Without .start() the rule will trigger first when device 77 changes state the first time.
    .start() does not always work. Ex.
    will not work because when the rule is run, there is no event #foo, so the left-hand side that checks if there is the event #foo will fail and the action will not run.
    By defining your own events, like #foo above, you can control when to trigger a rule by posting the event.
    In fact it's a programming model, and you can see the rules as "subroutines" that can be called by posting a triggering event.
    And events can carry values, like #foo{x=8}
    Ex.
    Learning to structure your code with events is very powerful.
    Ex. if you have some stuff that needs to be done at night
    Here we have a routine that should be done at night (turning on lamps)
    It will be done 1 hour after sunset, or when we press button 1 on our keyfob if we want to make "Night" earlier.
    (we could add rules that make sure we don't execute it more than once each day)
    Thanks @jgab for the great explanation! I'm going to apply it in me code, this structure is also much clearer to read
    Long time ago i created these rules, but i never got them working the way it was intended.
    My issue was that i needed a post(#bad), post(#rooms) and a post(#Common_groups) to trigger the rules. So i guess i need to build the rules based on time. So it triggers on 00:00, Sunrise, 22:30
    But with this way my structure will be on time - and not on my defined Zones
    Wondering if there is some obvious way to make these rules clean and structured based on Zones/rooms?
    @ChristianSogaard,
    I do it a tad different
    I hopen it will also work with the new HUE V2api????
    I have Time Off the Day (TOD)  in Global Variables.
    Wake-up, morning, afternoon, early evening, late evening, bedtime, sleep
    If TOD changes all color settings will be changed (lights are still off but numbers can be changed)
    fa living room has as basic setting TOD
    Adapting brightness and colors if:
    -tv-on
    -tv-off
    -reading
    -after 22:30
    -after 23:30
    3 hours ago, Sjakie said:
    @ChristianSogaard,
    -tv-on
    -tv-off
    -reading
    -after 22:30
    -after 23:30
    Do you have any logic checking when sunset comes before "early evening"  ? Like in the fall/winter when the sun goes down earlier
    Lets say you want to turn on a light at 21.00 but if sunset if before 21.00 you turn it on at sunset
    Edited by ChristianSogaard
    P
    In my HA the light switch on with correction for month and clear sky or by manual closing off the curtains.
    I hope it will clear a bit  if not let me know
