    8 hours ago, Sjakie said:
    I am surprised that fasted is having so Manny dead devices.
    I was expecting that all my devices should be dead but I have zero dead devices.
    Note:
    My HC3 is in the livingroom, all my devices are boxed (not connected) or must my device status becomes dead for the becomes true?
    If they are not connected I guess they are not listed with api.get("/devices?interface=zwave")
    ...or do you say that they show up in the HC3 GUI as dead/live?
    17 hours ago, fastvd said:
    the rule is cool, but it would be good if it issued only on a rooted device (Parent)... otherwise, in such an edition, it ALL pours...
    This filter and only keep devices with root parent, visible and enabled.
    19 minutes ago, jgab said:
    a have error
    I put this function at the top of the main tab, where all the functions are additional.. and it also gives me an error (((
    /monthly_2022_09/image.png.93cd85e933758b5c95407c426be435f6.png" />
    No, you need to put it inside main(), in the beginning
    I understand...I did!
    11 hours ago, fastvd said:
    a have error
    Jan, excellent now I see a Hugh list of dead devices.
    Thanks for this awesome tool.
    Question is summer/winter time already standard in ER so I can remove mine from main in all QA's?
    No, what is the code you are using now?
    Jan, can you show how to correctly write the function and the rule about dead devices?
    Jan this code you provide long ago
    Jan, may I bother you with iCall question?
    iCall version v0.11 id=1998
    I see in iCall 2 events for next Friday so far so good
    How to import in ER QA id=1906?
    1998  sends "events" to  1906 and in 1906 I see events received
    Rule.eval([[@07:30 =>
    list all events of this day
    Thanks in advance
    inside function QuickApp:main() - like on ~line 48 in your screen shot.
    no matter where I put this code - it gives an error!
    please tell me clearly where to insert it!
    Sorry, you are in the right place (QuickApp:main() )
    but there was a spelling error. It should be fibaro.utils.reduce - with and 's'
    Yes, the error is gone...thanks.
    BUT: the rule does not filter only parent devices
    on the screen we see the parent device with ID 1090 (I always put parent in the name at the end of _Z )...and after 1090 we see a message about the unavailability of children 1091 and 1092
    /monthly_2022_09/image.png.88e56ebff1550684afe0df7d116b2616.png" />
    or I don't understand how to use use the new function with the old rule...
    can you comprehensively show how this connection should work?
    The function that creates the 'allZWaveDevice' variable  only takes devices that have .parentId==0 or .parentId==nil. What is the .parentId for 1091 and 1092?
    1090
