Jan, hehe somewhere a weird font, rules copied from Excel, sorry.
I started to type manually and suddenly it filled the GV with values.
Jan, how can I combine in one email?
I tryed {20}:email ={log(..............), log(.............)};  did't wolk.
    You can combine them in one log statement. A small problem is that in the HC3 log it will appear on one line but in the email you get a newline between the lines.
    Thanks, finished my energy consumption now in HC3 awaiting for Sunday if the proper numbers will be reported.
    Nice weekend
    On 9/2/2022 at 9:24 AM, jgab said:
    Yes, but doesn't this work?
    Our waterNormal will only be false if the sensor been safe for 15min.
    When the sensor is breached the waterNormal is immediately true
    Then we have another rule that looks at waterNormal and sends a message when it's been true for 30min.
    If the sensor is safe less than 15min it will not change waterNormal and thus not trigger a new message.
    Shouldn't you send a message if sensor been safe for >15min? Like "water high"?
    time appeared and sorted out your rule in my head...roughly speaking, this rule:
    rule("trueFor(00:15,waterUp:safe) => waterNormal=false").start()
    will constantly update the status of the variable...and only when, roughly speaking, it DOES NOT break the cycle of the bottom for 30 minutes, then the rule WORKS!
    while I just have a float and I play 1 and 2 min... there are no DUPLICATE messages!
    THANK YOU MAESTRO!
    On 8/28/2022 at 3:23 PM, ChristianSogaard said:
    I think this way should be easier for me to manage
    Hi @jgab
    I have a huge HTab, containing all my devices so naming in Eventrunner are easier. (at least most og the time) - structure is different and below is just one section..
    for creating a memory funktion for the light in my matrix switches - i need two functions.
    One that can ADD a number, eg 1000 to rooms.all to local HTab
    And One that can remove 1000 from rooms.all in local HTab
    With this - i can maintain the list and only add color changes to the number in the list.
    Would you show the light for me ;-)
    10 hours ago, ChristianSogaard said:
    Hi @jgab
    I see that you define the table with local HTab so I assume that you declare it later with Util.defvars(HTab) and that in rules you have access to
    rule("log('all rooms:%s',tjson(rooms.all))")
    If so, you can do
    Jan, I want 2 or zero decimals in
    How to do?
    the following question: how to use ER4 to receive, say, a message about the unavailability of the device in a telegram? p.s.: it seems that there is a place to put a check mark on the website so that the notification goes out, but firstly, it is not convenient to check the box on every device, and secondly, there are no third-party messengers!
    Edited by fastvd
    How to do?
    log('#C:yellow#$Zenergie_Elec_Verbr_Week kWh %.2f',$Zenergie_Elec_Verbr_Week);
    Jan, thanks!
    I have another one:
    How to get sunset and sunrise in hh:mm in debug?
    Pushed v0.87.
    Some new features.
    The log function will print tables without having to convert to json.
    Ex.
    previously we did
    Now we can do
    If tables are pretty printed or not is decided by the flag
    Secondly, a new property, :isDead.  (I thought I already had it but it may have disappeared between ER3 and ER4)
    Ex.
    Lastly, we can assign debug tags to rules
    Ex.
    It works a bit like fibaro.EM.SECTION.
    We can also assign a tag to a single rule with
    2 minutes ago, Sjakie said:
    Jan, thanks!
    I have another one:
    there is also a function HMS(time) that gives you "HH:MM:SS"
    Jan, Excellent!!!
    Is there a way for a lazy person as I am:
    extract in ER list of all devices
    or in case I forget to add to list dead devices to report new devices?
    well..the rule of IsDead
    ..thanks.
    and now how to get a log that the connection has been restored?)))
    Edited by fastvd
    4 hours ago, Sjakie said:
    Jan, Excellent!!!
    ..thanks.
    58 minutes ago, jgab said:
    the rule is cool, but it would be good if it issued only on a rooted device (Parent)... otherwise, in such an edition, it ALL pours...
    I just now saw that I have so many devices offline...
    came up with the idea of a morning daily mini report so to speak...
    let's say that at 9 o'clock in the morning they came in a telegram:
    1) if all devices are online - yes and say that all DEVICES are online, if not, then give a list of devices
    2) if there is an opportunity to check the battery charge level, it would be great to include this in the morning report as well
    3) also throw how much energy was consumed or produced
    4) if there are any binary sensors that, let's say, like mine: they measure the water level, or, like mine, they measure whether my septic tanks are not full - so report (I have a report on septic tanks, water level, lake water temperature and temperature air comes every day)-VERY comfortable
    how nice to implement it? start least with AVAILABILITY!
    MY morning reports:
    rule([[once(@ {catch, 09:00} & 08:59..09:01 ) =>
      || $WaterLevel=='UP' >> fibaro.call(201, 'sendMessage', fmt('Temperatures: water in the lake %s °C, outside %s °C' , tempOzero:value, tempStreet:value), - 653771009);
     fibaro.call(201, 'sendMessage', fmt('Water level: CATASTROPHIC'), -653771009)
      || $WaterLevel=='NORM' >> fibaro.call(201, 'sendMessage', fmt('Temperatures: water in the lake %s °C, outside %s °C' , tempOzero:value, tempStreet:value), - 653771009);
      fibaro.call(201, 'sendMessage', fmt('Water level: NORMAL'), -653771009)
      || $WaterLevel=='DOWN' >> fibaro.call(201, 'sendMessage', fmt('Temperatures: Water in the lake %s °C, on the street %s °C' , tempOzero:value, tempStreet:value), - 653771009);
     fibaro.call(201, 'sendMessage', fmt('Water level: BELOW normal'), -653771009)
    rule([[once(@ {catch, 09:00} & 08:59..09:01 & $SeptOE=='ok' & $SeptBanya2=='ok' & $SeptBanya=='ok' & $SeptOhorona =='ok') =>
       fibaro.call(201, 'sendMessage', fmt('The level in all septic tanks is normal'), -653771009)
      rule([[once(@ {catch, 09:00} & 08:59..09:01 & $SeptOE=='bad' ) =>
          fibaro.call(201, 'sendMessage', fmt('Reminder: the level in the septic tank of O.E.'s house is high'), -653771009)
       rule([[once(@ {catch, 09:00} & 08:59..09:01 & $SeptBanya=='bad' ) =>
       fibaro.call(201, 'sendMessage', fmt('Reminder: high level in the septic tank of the main septic tank of the BANI' ), -653771009)
       rule([[once(@ {catch, 09:00} & 08:59..09:01 & $SeptBanya2=='bad') =>
        fibaro.call(201, 'sendMessage', fmt('Reminder: high level level in the septic tank of the spare septic tank of the BATHROOM' ), -653771009)
       rule([[once(@ {catch, 09:00} & 08:59..09:01 & $SeptOhorona=='bad' ) =>
        fibaro.call(201, 'sendMessage', fmt('Reminder: high level in the SECURITY septic tank' ), -653771009)
    how to display a list of all DEAD devices?
    I am surprised that fasted is having so Manny dead devices.
    I was expecting that all my devices should be dead but I have zero dead devices.
    Note:
    My HC3 is in the livingroom, all my devices are boxed (not connected) or must my device status becomes dead for the becomes true?
