10 hours ago, cag014 said:
I am trying to understand your definition and that's what looks like you did
{true and '&alwaysZero:value=0' or '&alwaysZero:value>0')
First of all, the entire statement should be in double quotes and not parts of conditions.  When using or conditions the statements between should be within brackets {} or {}.
The and conditions used in the same brackets {... and ... and ...} or {.... and ... }
Another question, what do you mean just by true?
Please tr as below
("_55","startScene", "{&alwaysZero:value=0} or {y &alwaysZero:value>0}"
By the way in case your property is value you can skip that
("_55","startScene", "{&alwaysZero=0} or {&alwaysZero>0}"
Still don't understand where/why you are using Boolean true?
May I suggest shorter option
("_55","startScene", "{&alwaysZero>-1}"
Thanks. Really, I forgot brackets. But it's still don't work - scene not launching at selected time
Also about my way: I use lua variables on the top of the script because looking them in the user variables section is annoying because a lot of code has to be scrolled. It's really easy to change one variable on the beginning of the script from true to false and change huge part of logic.
As I understand this code:
{0,"$blank",{
  timeSlot="9:40~9:41",
  trueAct={
    {"_55","startScene"}
...should launch scene 55 (which is enabled and launch mode set to "manual") at 9:40 but it don't
    {0,"$blank",{
      trueAct={
    Yes, it makes the change easy. but what equals to true? You must have some variable to compare!
    Regrading timeslot, your format just sets the timeSlot range between 9:40 to 9:41
    To execute trueAct please define 09:40~ or true09:40
    timeSlot="09:40~"
    or
    timeSlot="true09:40"
    Dear @
    i am on V15.2, trying to add Jsalve hcl while this HCL on slave mode,
    but i am getting below error all the time.
    HCLxxx={user="xxx",passwd="xxxx",ip="172.16.10.12"},
    i am 100% sure from ip connectivity and credentials.
    what could be the problem?
    thanks in advance
    It means user, password or IP are incorrect
    please make sure you can access HCL at browser using same credentials
    i am sure from user and password, and connectivity status.
    have anything todo with HCL3 being in slave mode?
    I really love your all-in-one scene, it is brilliant!
    2) I would like to run the following command only if the luminance is less than 100. How to include this?
    {0,"`motionSensor`,`luminanceSensor`",{state="true",timeSlot="07:00~23:30",trueAct={{"`lightBathroom`","turnOn",""},{"`lightBathroom`","turnOff","","={`motionSensor`:valueModified>3|`motionSensor`:value=false}"}}}},
    Thanks so much in advance!
    Patrick
    Sorry, but never tested on HCL at slave mode.... might be this is a problem.
    By the way if HCL at slave mode, why you need access directly to HCL? You can control HCL devices at master, right?
    Patrick
    Have sent an answer in private message...
    to monitor the network connectivity between master and slaves.
    On 12/25/2022 at 1:19 AM, cag014 said:
    Please backup your working code 😀
    Let me know if it works and looks better. Your feedback appreciated.
    Hi cag014,
    I appreciate your work in making AOQ more perfect and easier to use, but the "Major "face lifting" for debug information (feels and looks like code)" is a step too far for me in order to comprehence what I see. Things like "if not" and the new signs are unclear. Please add some documentation on what I see now.
    Edited by Rover
    On 11/17/2022 at 6:15 PM, cag014 said:
    API commands slow execution... could be your LAN or HC3 is a little bit overloaded/busy.
    It could be that at this particular point of time the connection is slow (just for a short period of time)
    You can set the response time in USER Global Parameters
    slaveApiTime= 600 ''
    in addition, it could be set for each system in user_data file
    home={user="xxx",passwd="xxx",ip="xxx", slaveApiTime=600
    The default value is 600 msec.
    The idea is to provide heads up, that something is not normal.
    Questions:
    Do you have dead devices in the system?
    Do you have devices that located far away from the hub or blocked by the walls (or another obstacle) that cause unstable Zwave communication?
    It could explain the warning....
    You can see also an updated table with response times
    Hi cag,
    This problem is alive for me continiously. Every devices is working correctly, but random I got a warning messages from the AOQ.
     The response time is very high.
    I don't understand what is the problem. I wrote a message for the FIBARO support. For some weeks his watch my HUB, but can't find any problem.
    The FIBARO support send me another HUB, but the problem is alive.
    What do you think? What is the problem.
    When this problem is alive, after some time the HUB is crashed and rebooting.
    @SmartLifeSystems
    That means that your hub responds too slow. Could be that some device slows down your hub. It could be from many reasons like device sends too much information or physical location of the device causes poor communication.
    Is it happening all the time? I mean when you restart the hub, is works properly (at least for a while?)
    What about your RAM and CPU loads?
    When this happening, could you try to access any device via API and see if the response is slow also...
    7 minutes ago, cag014 said:
    @SmartLifeSystems
    "Is it happening all the time? I mean when you restart the hub, is works properly (at least for a while?)" - Yes, every time. The problem is randomly, and I can't attached any event.
    "or physical location of the device causes poor communication." - I haven't new device, and what I only change is the HUB and the AOQ updates.
    No information in the history tab, and I send more log file for the Fibaro support, but hes can't find anything. What the Fibaro see, only some API problem.
    Edited by SmartLifeSystems
    More information. When the AOQ's warning API message alive, I can control my devices until the hub is crash, but the AOQ don't working.
    That's strange, AOQ shows a warning only everything else should work, unless refresh State API does not received...
    Could you please change slaveApiTime to 5000. It should stop the warnings and let's see if AOQ continues to work.
    topActive   = 15 --number (0-30) of top active slave devices. 0-disable. Default 10
    topZwave    = 15 --number (0-30) of top active master devices. 0-disable. Default 10
    slaveApiTime= 5000 -- max. hub response time (milliseconds), warning shown if greater detected.
    dbgInfo     = true -- display line and action states condition according to dbgTrueState/dbgFalseState
    dbgTrueState= true -- display line, action states and executed command when condition is true
    dbgFalseState=true -- display line and action states when condition is false
    @SmartLifeSystems
    DO you have any idea when your hub started to crash? What SW version you are on?
    BY the way, did you add or change any QA devices or scenes?
    Do you use
    emulating HC2 devices on HC3?
    Edited by cag014
    57 minutes ago, cag014 said:
    @SmartLifeSystems
    Do you use
    I don't remember the version number, but the first crash was in september.
    Since than I have made only some QA that change global variables.
    I don't know if it has significances, but those days in the Satel Integra alarm system, the system has benn separated into more particions. However it was also then when in the HUB softwere update happened.
    I changed the slaveApi time to 5000, but the problem is started, when I restart the AOQ.
    Now is the problem continiously. I restart the AOQ and after some minutes again started the problem.
    1. Wow, your CPU load is very high, it explains slow reaction of the hub.
         I suggest to shutdown QA, scenes one by one to find out who causes that load.
         Here as an example of my CPU load
    Edited by cag014
    On 1/16/2023 at 8:26 PM, Rover said:
    Hi cag014,
    The debug information is the same, just added if before condition statements and then after.
    When the condition failed added if not and the command shown with strikethrough. Means If not then skip the command. Like in the real code.
    The main change that the same triggered line doesn't display again and again and again.... but all commands related to this line are shown below. Easy to spot the chain of commands.
    for example
    When the same line repeatedly displayed, I find it's hard to follow the flow of the commands... too many same info to read
    Edited by cag014
