I think, the $24clock lines don't working. In the bug window I see, the line is run, but don't work the command.
    Could you please post the line
    Have verified that and it works just fine.
    {"$24clock",{state="02:40", trueAct={"`light`","turnOn"}}},
    Edited by cag014
     Hi cag,
    This is my line:
    {0"$24clock",{state="value=15:41",onClock=true,trueAct={{"`leilaWP`","+setConfiguration,12,1,0",""},{"`leilaWP`","+setConfiguration,11,1,0",""}}}},
    In the attached pictures, you see, the line is working, but don't do the command.
    That is true every $24clock line.
    21 minutes ago, SmartLifeSystems said:
     Hi cag,
    This is my line:
    OK, I see the "turnOn" command working fine. The "setHeatingThermostatSetpoint" and the "+setConfiguration" command don't working.
    On 10/1/2022 at 8:28 PM, cag014 said:
    @Rover
    Please try attached version. Should support push notifications on all HC3 versions
    In 13.8 Pushover works, in 14.0 Pushover does not work.
    Have found the problem in transferring arguments.
    Working on that
    @SmartLifeSystems
    Fixed the bug, please try it.
    @Rover
    The code for push notification exactly the same as in 13.8
    Edited by cag014
    4 minutes ago, cag014 said:
    @SmartLifeSystems
    @Rover
     I think some lines from the end is withered.
    Yes, my bad.
    Have updated the file, please download again (from the same previous post)
    Edited by cag014
    4 minutes ago, SmartLifeSystems said:
    Looks like working fine.
    Thanks cag!
    Thank you for taking time to test the code
    Edited by cag014
    @Rover
    Have verified again and again, push notification works.
    As far as I remember you have an issue with push on 13.8 as well.... maybe this is the same problem that you fixed before
    18 hours ago, cag014 said:
    @Rover
    Hi Cag,
    Pushover works now in 14.1 ?, it looks indeed as a parameter transfer problem.  trueAct={"`Pushover`", '+Send_Pushover,json[["Pushover test","0","gamelan","DingDong"]]'},}},
    Pushover is not the standaard iOS push notification, but a service packed in a QA.
    I did not fix the push notification but i have bought a new iPhone. With the old iPhone 6 Plus with iOS 12 there is a push notification from AOQ problem, but with the iPhone 14 Pro Max with iOS 16 push notification from AOQ works ?.
    Edited by Rover
    Hi cag!
    What is this warning message?
    33 minutes ago, SmartLifeSystems said:
    Hi cag!
    API commands slow execution... could be your LAN or HC3 is a little bit overloaded/busy.
    It could be that at this particular point of time the connection is slow (just for a short period of time)
    You can set the response time in USER Global Parameters
    slaveApiTime= 600 ''
    in addition, it could be set for each system in user_data file
    home={user="xxx",passwd="xxx",ip="xxx", slaveApiTime=600
    The default value is 600 msec.
    The idea is to provide heads up, that something is not normal.
    Questions:
    Do you have dead devices in the system?
    Do you have devices that located far away from the hub or blocked by the walls (or another obstacle) that cause unstable Zwave communication?
    It could explain the warning....
    You can see also an updated table with response times
    Edited by cag014
    Hi cag014
    Firs of all for a new AOS release - hopefully AOQ and AOR will follow with the new features.😀
    I do like the debug information shown on the console, but sometimes is too much and too hard to find what I need to monitor.
    May I ask you to have same debug options for every line?
    Let me explain -
    I want to see the line when the conditions are false, an easy way to see if my conditions are OK. But from other hand, I have some trigAct ad loops and they just filling-in my entire  console history... I mean every change on value in trigAct and have loops of 1 minute.  So I want to be able just for those lines to set dbgCmdFalse and dbgFalseState to set to false. Now I will see only when they are executed....
    Another idea , is to set global dbgInfo to false and just for specific lines to defined as true. Now I will see only these lines. I think this is very useful for debugging.
    Is anyone of All-In_One users finds that useful also?
    Thank you for your good work.
    Edited by AR27690
    15 hours ago, AR27690 said:
    Hi cag014
    Let me explain -
    Sounds as a useful debugging option.
    Done for AOQ and will be released soon.
    Will update AOS and AOR as well.
    • Thanks 2
    To all attached AOQ version that includes debugging settings in jM lines. Please read below how to use
    1. Debugging levels
    (Boolean true or false).
    There are 5 global debugging levels available
    dbgInfo -- enable/disable all global debugging levels below
    dbgTrueState -- display
    and executed command when all conditions are true.
    dbgFalseState -- display
    when conditions are false
    dbgInitState -- display not executed commands (conditions are false) during initialization
    dbgCmdFalse -- display command when command’s conditions are false
    When dbgInfo set to false, all global debug levels are set to false also regardless their setup.
    By default every jM line inherits global definitions of debugging levels.
    Moreover, debugging levels could be redefined for every jM line inside the line itself.
    The levels defined in jM line are override global levels for the specific line.
    However inline defined dbgInfo will set all levels to defined value (true/false) for this line regardless global definitions.
    For example:
    1. The global levels defined as following
    dbgInfo =false
    dbgTrueState =true
    dbgFalseState =true
    dbgInitState =true
    dbgCmdFalse =true
    Since global dbgInfo in this example is false, all debug levels will be set to false, that means no debug information displayed for all jM lines.
    To set all debugging levels to true for the specific jM line, add dbgInfo=true.
    JM={ {“motion”,{state=”true”,dbgInfo=true, trueAct={“light”,”turnOn”},falseAct={“light”,”turnOff”}}}, }
    To set specific level for the specific line, add [required level]=true.
    JM={{“motion”,{state=”true”,dbgInfo=false, dbgTrueState=true, trueAct={“light”,”turnOn”}}},}
    dbgInfo =true
    dbgTrueState =true
    dbgFalseState =false
    dbgInitState =true
    dbgCmdFalse =false
    Levels above are valid for all jM lines.
    To set additional level for the specific jM line, add [required level] = true.
    JM={ {“motion”,{state=”true”,dbgFalseState=true, trueAct={“light”,”turnOn”},falseAct={“light”,”turnOff”}}}, }
    To remove specific level for specific jM line, add [required level] = false.
    JM={ {“motion”,{state=”true”,dbgTrueState=false, trueAct={“light”,”turnOn”},falseAct={“light”,”turnOff”}}}, }
    To ignore all debugging levels, add dbgInfo=false.
    JM={ {“motion”,{state=”true”,dbgInfo=false, trueAct={“light”,”turnOn”},falseAct={“light”,”turnOff”}}}, }
    In addition, during initialization in previous version (bugs???)
    1. action states (like trueActState, falseActState ...) haven't been validated
    2. devices that have been activated during init (like turnOn, turnOff, setValue...) and their state on previous jM line haven't been validated again.
    So please note that some changes could be seen during initialization.
    Let me know if it works OK.
    Edited by cag014
    1. Debugging levels
    For example:
    dbgInfo =false
    dbgTrueState =true
    dbgFalseState =true
    dbgInitState =true
    dbgCmdFalse =true
    dbgInfo =true
    dbgTrueState =true
    dbgInitState =true
    dbgCmdFalse =false
    In addition during initialization in previous version (bugs???)
    I think you have to set the global debugging parameters in the AOQ parameters?
    What is the default value of the debugging parameters (value if not defined globally)?
    Edited by Rover
    If global not defined then is nil, means false. with one exception for dbgInitState, if not defined then set to true.
    What do you think it should be set to if not defined?
    By the way, for shortcut lovers, you can use shortcut for each level in jM line (case sensitive)
    dbgInfo -> dIf
    dbgTruestate -> dTs
    dbgFalseSTate -> dFs
    dbgInitState -> dIs
    dbgCmdFalse -> dCf
    for example - instead
    you can use
    JM={{“motion”,{state=”true”,dIf=false, dTs=true, trueAct={“light”,”turnOn”}}},}
