8 hours ago, cag014 said:
Interesting.... what do you see on webEye? Is this line green or yellow?
Can you please post the line from debug console  when this command executed?
For how long All-in-One runs continuously.
Another question... I think sunsetHour is after 19:00, correct?
By the way it could happen when you start the program (after making some changes) during initialization the timeSlot ignored to set correct states.
To avoid execution on startup please add to the line as following
{0"`hallMS`",{state="value=true", initOnStartup=false , timeSlot="m=9~12;1~2;$sunsetHour~19:00",trueAct={{"`hallLight`","turnOn","","{`hallLight`:value=false}"},{"`hallLight`","turnOff","","={`livingroomMS`:value=true|`hallLight`:value=true|`hallMS`:lastBreached>60|&HallLight:value=Automatic}"}}}},
Yes, interesting, because until this moorning this line is working correctly.
Here what I see the webeye. On the secound picture the timeslot values are green. But I setted the month beetween september and february.
/monthly_2022_05/image.png.50b464b7056aa35a36cf7ae540200147.png" />
Edited by SmartLifeSystems
    I meant the line in the table... if it's out of timeSLot it should be yellow.
    Edited by cag014
    If it's out of timeSlot in the line the timeSlot is green.
    No... it should be yellow.
    See in my previous post, the line with your timeSlot  definition is yellow
    • 3 weeks later...
    Hi  @cag014,
    There was a strange happening by the idea that a global parameter was not valid, while he is there:
    What could be the case?
    @Rover
    You are using outdated version 11.8
    Please update to the latest 13.1 and let me know if it works
    Edited by cag014
    On 5/25/2022 at 1:25 PM, cag014 said:
    @Rover
    I saw version 13 but not 13.1  . How can I see if it works if I have got an error not on initiation but on normal operation?
    Please follow
    Let's see if the error occurs...
    Edited by cag014
    Guest Benrive
    Hi @cag014,
    How long? It shows that I have already joined work after a few months.
    I hope all goes well.
    I have many problems due to the conditions of my house, I lose the connection of some devices frequently.
    Do you know if you are going to update Zwave monitor for Hc3?
    I have to buy a Zwave Stick, do you recommend any specific one?
    Greetings and thanks for everything always.
    I usually buy on amazon
    Edited by Benrive
    22 hours ago, cag014 said:
    Please follow
     Hi cag014 sorry the offtopic, did you see my lasts messages.
    very thanks
    13 hours ago, Benrive said:
    Hi @cag014,
    Currently I'm updating AOR for Zigbee support and have asked by Fibaro team to publish All-in-One at Market place... (some documentation required)., but meanwhile you can rely on Top active devices at AOQ.
    You can see this table at the end of the HC-WebEye table.
    This table shows number of activities/reports of Z-wave devices in your system (even if they are not part of jM lines) and shows total activities on Z-wave.
    By hovering on the master device name in the table you will see the menu of all slave devices and number of Z-wave activities of each of them.
    Could you please post the snapshoot of the table after few hours to see if there is some devices that could be configured differently to avoid Z-wave "bombarding".
    For example see below Top active table... as you can see Fibaro Motion Sensor sends to many unnecessary Lux reports  (in my case I don't used at all), so I need to reconfigure the Lux slave device to reduce Lux report.
    I do believe using this tables we can make your system better.
    Edited by cag014
    @cag014 Did you saw my messages?
    very thanks
    Guest Benrive
    Of course, with those tables I can improve the secure system.  I have devices that send humidity reports every few seconds.  but the problem is that I don't know how to change this, I try to change the spool time but it's still the same.
    Edited by Benrive
    You need to configure every device and to change reports time (or limits)
    The pool time determinates how often HC3 pools the device.
    What humidity sensor you have?
    Guest Benrive
    Hello @cag014.
    I have aeotec Multisensor 6 powered by usb.
    I have changed the advanced configuration in "device excluded from pooling" and in the parameters I am trying to change the limits, parameters (40 to 45), but I am seeing that I change the parameters, they are not updated on the device.
    I just created a post about this.
    Solved It
    @cag014,
    I could solve it, I'm going to change the parameters to see how they report me. I had humidity reports every few seconds.
    I think that was driving me crazy zwave network.
    I'll tell you the results, but I think it will be a great advance, I have 6 of these sensors.
    Thank's
    Edited by Benrive
    • 3 weeks later...
    Hi @cag014,
    Since a few weeks I have a problem with my doorbel because of not triggering a jM-line by changing of a local parameter in AOQ. Most likely it has started by the update to version 13.1. I cannot see what the previous AOQ version was.
    If I change the local AOQ parameter to a global HC3 parameter the problem has been gone.
    16 hours ago, Rover said:
    Hi @cag014,
    You're absolutely correct... thank for finding the bug.
    please try attached version
    This version includes
    1. Added an option to use icon number or icon name in setIcon command.
    2. Added setKeyword command to change user keyword value on the fly.
    trueAct={"$userKey","setKeyword","10"}
    @Rover
    Is it works now?
    10 hours ago, cag014 said:
    @Rover
    Is it works now?
    No, I got an initiation error:
    [21.06.2022] [10:21:09] [ERROR] [QUICKAPP386]: QuickApp crashed
    [21.06.2022] [10:21:09] [ERROR] [QUICKAPP386]: main.lua:136: attempt to index a nil value (global 'debugHttp')
    Oops, my bad....
    You need to define this global in AOQ Parameters definitions
    debugHttp   = {["GET"]=false,["POST"]=false,["PUT"]=false}
    That could help you to view http commands sent by AOQ in case you need to use it somewhere... (scene, browser and etc.)
    or download attached version (fixed to set default if not defined by user)
