    Interesting ...
    Here the latest beta release, says public release????
    Guest Benrive
    3 minutes ago, cag014 said:
    Interesting ...
    an error, the developers will have it.
    Guest Benrive
    Hello @cag014.
    I already have the update that carries the zigbee beta, but I don't think it supports the device I want to buy Aqara Cube.
    /monthly_2022_04/image.png.2f71ca36032debb2cf5a4e356542cfcf.png" />
    13 hours ago, Benrive said:
    Hello @cag014.
    I think there is no support for Zigbee  remote controllers yet...
    Here the primary list of supported Zigbee devices (Alpha release)
    Edited by cag014
    On 3/29/2022 at 11:44 PM, cag014 said:
    By looking on your lines I think it's a good idea to add an option to use $geoUser keyword as part of the global variable name, so then the line could be very simple like:
    Current version doesn't support that , but will make the changes in AOQ and post it for test.
    @Benrive
    As promised, here a version that supports key words variables as part of global variable name.
    In addition this version supports ZigBee devices also.
    Please try to use jM line above and let me know if it works.
    26 minutes ago, cag014 said:
    @Benrive
    Hi cag,
    I got the next message. My Alarm system is a Satel Integra.
    6 minutes ago, SmartLifeSystems said:
    Hi cag,
    $actDay is not part of global keywords and probably defined as user keywords! Did it work on previous version?
    There is $actDate global keyword....
    Yes. That's my wrong! Sorry!
    I repaired now.
    Guest Benrive
    18 hours ago, cag014 said:
    @Benrive
    Hey @cag014,
    I just replaced the 3 change lines of the GPSxxx variable with the new one incorporated, much simpler by concatenating GPS and userName.
    I inform you when I have the first change of state that it works. Sure good.?
    Thanks for adding the zigbee part, but I don't have any devices yet.
    I wanted to buy try the aqara cube but it is not supported at the moment.
    As soon as I can try something from zigbee I'll let you know.
    Thank you for your great work
    The Zigbee devices are very cheap comparing to Z-wave, so I suggest if you about to purchase more devices, take a look on Zigbee. (even at AliExpress)
    Guest Benrive
    On 4/11/2022 at 12:49 PM, Benrive said:
    Hey @cag014,
    Hello @cag014.
    works perfectly.
    thsnks
    Guest Benrive
    Hello @cag014.
    I have many problems with this line, no matter how much I change the times, it is getting worse and worse.
    when the status is true the lock open “unsecure”. (Cerradurapuerta), it takes about 4 seconds to open It’s well.  after that time I want turnOn “Salabrepuerta” for about 3 or 4 seconds and after that time “SalAbrepuerta” turnOff.  The problem is that the unsecure part makes it perfect but then it can take up to 10 or 15 seconds for “SalAbrepuerta “ to TurnOn and it does so in just 1 second.
    some delay I do not understand or I am not using it well
    1 hour ago, Benrive said:
    Hello @cag014.
    As I understand the problem with the timing is to turnOff the SalAbrePuerta after it turns ON, correct?
    It could be better idea to use WHEN conditions or to split that  to few more lines for this action.
    1. using WHEN
    {0,"`EntAbrePuerta`",{state="centralSceneSupport=1.Pressed#2",
    trueAct={{"`cerraduraPuerta`","unsecure"},{"`SalAbrePuerta`","turnOn", "When {`cerraduraPuerta`:value=unsecured"},
    {"`SalAbrePuerta`","turnOff","5","When {`SalAbrePuerta`:state=true"}}}},
    1. Split the lines (might be these devices used somewhere else differently, so lineState could be used
    {0,"`EntAbrePuerta`",{state="centralSceneSupport=1.Pressed#2",trueAct={{"`cerraduraPuerta`","unsecure"}}},
    {0,"`cerraduraPuerta`",{ lineState="if {`EntAbrePuerta`:centralSupport=1.Pressed}", state="unsecured", trueAct={"`SalAbrePuerta`","turnOn"}}},
    {0,"`SalAbrePuerta`",{lineState="if {`EntAbrePuerta`:centralSupport=1.Pressed}",state="true", trueAct={"`SalAbrePuerta`","turnOff","5"}}}
    Edited by cag014
    Guest Benrive
    1. using WHEN
    ok, I'm going to try the options you give me and I'll let you know. Although there is an error in the status update of the danalock lock, it doesn't always update or it doesn't do it right.
    For this I have the Global LockStatus variable.  What I do to give the correct state is to force it to close “secure” and update the variable to 1 when the door is closed and there is no movement for 2 minutes.
    when I send unsecure I update the variable lockststus to 0.
    I'm going to test what you're saying by substituting the status of the lock for that of the lockstatus variable.
    I'll try tomorrow and let you know
    thanks
    Guest Benrive
    thanks
    Ok, It's better but a i have a question witch a conditions.
    {"`SalAbrePuerta`","turnOn","when {&GPSMariAsun:value=2}{&GPSBenja:value=2}{&GPSSofia:value=2} and {`cerraduraPuerta`:value=false}"}
    I need the condition it's
    When (&GPSMariAsun:value=2 or GPSBenja:value=2 or GPSSofia:value=2 ) And (`cerraduraPuerta`:value=false)
    It's true when cerraduraPuerta:value=false and any of the GPS variables = 2
    What am I doing wrong?
    You can see the webeye. All conditions are considered OR.
    /monthly_2022_04/image.png.41d97385787421c69390ca1733b33ea1.png" />
    Edited by Benrive
    The "and" condition should be inside the brackets. Any additional condition in brackets is "or" state.
    Since {`cerraduraPuerta`:value=false}"} is the common "must" condition I suggest to add lineState, but since I don't have your entire line it could be wrong.
    lineState="if{`cerraduraPuerta`:value=false}", {"`SalAbrePuerta`","turnOn","when {&GPSMariAsun:value=2} or {&GPSBenja:value=2} or {&GPSSofia:value=2}}
    Another question Why use use WHEN condition? It should be "IF", isin't?
    Please post entire line and if you can expalin what exactly you need to achieve I can provide some other options...
    Guest Benrive
    Hi @cag014,
    The complete line
    This is the sequence that's driving me crazy, there's really no way for the door opening behavior to be effective.
    For one thing, I use a variable instead of the state of the lock (because it fails a lot). &LockStatus
    I use a line with TrueAct to change the state of the variable.
    cerraduraPuerta is a lock danalock
    To make sure of the state I use a timeLoopAct line every 10 minutes to update the variable.
    I use When because it must wait for the lockstatus variable to have that state.
    I change its state when it is detected that the lock is True or False.
    I use a separate line simply for better understanding
    Edited by Benrive
    I'm wondering why you're using +value for
    Is it means property value is not available for cerraduraPuerta? Interesting...
    Could you post API data of cerraduraPuerta when it's closed and one when it's open?
    Edited by cag014
    Guest Benrive
    yes, it is because it does not support it and in this way I can know more or less if it is true or false although the status fails a lot.  It is something that I imagine they will fix in future Danalock updates
    Danalock Locked
    Danalock Unlocked
    Edited by Benrive
    Looks like property value does exists... and no need to use +value.
    As I understand you have an issue when the lock is open or close, I mean it takes uncertain time, correct?
    Another observation, there is a property call secured. When the lock is open the secured=0. When lock closed secured=255.
    May be, just may be this property could help you. I mean may be during the lock/unlock process the value of secured changed till reaches the final result  ( or 255), worth to try.
    Edited by cag014
