Guest Benrive
12 hours ago, cag014 said:
Agree.
Since you probably made some changes on the code, so to reduce your efforts for an update, please change marked lines in your QuickApp code
function QuickApp:updateStatus()
    local val,vTime=0,0
    for i=1,#jUser do
    val,vTime=fibaro.getGlobalVariable(jGlobal[i])
    self:updateView(jLbl.id[i], "text", jLbl.icon[i]..jLbl.fColor[i]..jUser[i].."</font>")
    self:updateView(jBtn[i], "text", jStatus[tonumber(val)+1]..os.date("  (%d %b %H:%M)", vTime))
No changes in other lines in the code
Let me know if it's OK
Perfect....
/monthly_2022_03/image.png.bd5a48d09cb0a2524cd98b2347dbca4a.png" />
Update:
I am doing tests and I have put a condition, so that the color of the name matches the state. I feel powerful. hahahaha
Red = 0 Leave Home
Orange =  1 Coming Home
Green = 2 In Home
The new lines, I don't know if it's the most effective way, but it works and I'm happy.
    local val,vTime=0,0
    for i=1,#jUser do
        if fibaro.getGlobalVariable(jGlobal[i])=="0" then
            self:updateView(jLbl.id[i], "text", jLbl.icon[i]..jLbl.fColor[1]..jUser[i].."</font>")
        if fibaro.getGlobalVariable(jGlobal[i])=="1" then
            self:updateView(jLbl.id[i], "text", jLbl.icon[i]..jLbl.fColor[2]..jUser[i].."</font>")
        if fibaro.getGlobalVariable(jGlobal[i])=="2" then
            self:updateView(jLbl.id[i], "text", jLbl.icon[i]..jLbl.fColor[3]..jUser[i].."</font>")
Edited by Benrive
Guest Benrive
Hi @cag014,
I had to change many things, but I think I have achieved it.
I had the biggest problem in the states, because they are different devices and have different label states.
I've also included a new state [5], "Update State" , for when the button is pressed it appears until the new state changes.
The variables are 2 door locks and a water tank (which notifies me when it is full).
please take a look
/monthly_2022_03/image.png.ca91f410bcf61f035f6945c781c4b524.png" />
Edited by Benrive
Guest Benrive
Hello @cag014,
I'm trying to substitute truAct for trueActstate on some lines to simplify them.
I want to replace this for example:
functional version.
New version witch use trueActstate ,
I have tried, following the examples of AOQ Avancer User , to place State before and also after trueActState , but in both I get an error.
This is the error that jumps me using as I have put now.
Guest Benrive
Edited in previous post
Edited by Benrive
    14 hours ago, Benrive said:
    You have an extra Curve bracket (before if) , should be
    Guest Benrive
    ok,ok
    What a fool I am, and I was checking him several times
    Guest Benrive
    ´Hi @cag014,
    Is it possible to group global variables? For example, I want that when all variables GPSxxx = 0 ( Leave home ), the door lock is closed if it is not closed.
    I have almost all the lines with a per person condition, when you can't really tell who is the one who opens the door.
    To simplify and have a condition when all are = 0 or 2
    13 hours ago, Benrive said:
    ´Hi @cag014,
    No, but you have several options to simplify the line
    1 - check every XXX minutes if all users left home (the `ddor` and lock action just as an example)
    {3,"$timeLoop",{state="inLoop", timeLoopAct={"`door`","lock",  "if {&GPSSofia:value=0 and &GPSBenja:value=0 and &GPSMariAsun:value=0}"}}},
    2- Since you already have QuickApp to update GPS data, you can define global which sums the value of all users in QA and use it in AOQ line
    In Presence QuickApp update this global value like following:
        local val,vTime,total=0,0,0
        for i=1,#jUser do
        total=total+val
        fibaro.setGlobalVariable("GPSAll", tostring(total))
    Now you can use the global in jM line
    {"&GPSAll",{state="0", trueAct={"`door`","lock"}}},
    Note:
    when all users at home the GPSAll value =6
    On 3/30/2022 at 11:05 AM, Benrive said:
    Hi @cag014,
    please take a look
    Looks OK, is it works properly?
    Edited by cag014
    Guest Benrive
    Sure, what an easy way to find out. There is nothing like the imagination to not mess up sometimes
    Thank's
    Guest Benrive
        for i=1,#jUser do
        total=total+val
    Note:
    I think Yes, It looks good, when you press until the update is done, see how it says "Updating" in the label of the button.
    I pass you the file with all the modifications and added the part of GPS All.
    Now I'm thinking that this same variable could activate the alarm mode.
    Look how it turned out in the end
    To all All-in-One users...
    Fibaro has released a new beta version that supports Zigbee devices on HC3
    For a while I have worked on the AOQ to make a necessary changes to support Zigbee.
    The new version will be released in few days, so
    Go and order Zigbee devices, they are cheaper that Z-wave and work fine on the system.
    Guest Benrive
    oh my good!!!.
    It's great news, I was looking forward to it as there are some devices I'm looking forward to trying such as Aqara cube.
    Hi
    If I use HC2 All in One ver. 7.2 dan I get the line.
     Item ID debugTag not found in the system.
    2 hours ago, parip69 said:
    Hi
    debug command is not available in AOS (as you can see in user guides...) debugTag is not available in HC2
    It supported for AOQ (debug, trace, error and etc...)
    I am about to release a new version of AOS, do you think "debug" command is necessary?
    Edited by cag014
    Not necessary, but you can write some things into the consoles when testing and see the condition of the lines immediately.?????
    If the effort is too great then you save yourself the work it is such a great achievement what you have done there.
    Edited by parip69
    Guest Benrive
    Hi All,
    Everyone makes problems, but few people read. Look how strange it is that there are only 2 of us.
    Amazing
    New version will include same debugging levels like HC3 (debug, trace, error, warning )
    Guest Benrive
    5 hours ago, Benrive said:
    Hello @cag014.
    This is getting interesting... counting down the days for the new version ( And Zigbee release )
    Do you have anything in mind to be able to have a beta version of Zwave Monitor in HC3?
    I use this scene, which simply tells me the HOPS, but gives little more information.
    I have very thick walls and sometimes the nodes go from HOPS 1 to 4 for no apparent reason.
    Scene:
    -- File    : RoutingInfo-V3.lua
    -- Version : 0.1.1 -  {11.03.2021}
    -- (C) {jwi}
    What version you have on HC3 ?
    The latest release 5.102.xx (beta) should accept Zigbee devices.
    Once I'll release the new version for Zigbee, will convert Z-wave monitor for HC3
    Guest Benrive
     5.101.19
    But I have no pending updates?
    Do you know if the Aqara Cube device is supported?
    I want my daughters to hallucinate with it.
    This is great news, for those of us who have some network coverage problems
    Thank's
