7 hours ago, cag014 said:
Oops, my bad....
You need to define this global in AOQ Parameters definitions
debugHttp   = {["GET"]=false,["POST"]=false,["PUT"]=false}
That could help you to view http commands sent by AOQ in case you need to use it somewhere... (scene, browser and etc.)
or download attached version (fixed to set default if not defined by user)
In 13.4 the local parameter problem has gone.
Thanx for the repair @cag014.
  • 2 months later...
Hi cag!
I have a problem. Yesterday i updated the new beta version and the push notifications don’t working with this beta.
What do you think?
Thanks!
    can you send push notification somewhere else, i mean not in AOQ
    Yes i know, but I have more than 100 push notifications in the AOQ. :(
    Have verified and looks like there is a bug in this version - push notification doesn't work.
    I suggest to go back to previous version.
    Thanks your answere! I tryed the previous version, but the bug is left over.
    I think, I have to wait for the next version.
    Edited by SmartLifeSystems
    I think have found what is going on....
    Now the push notification uses user ID only and doesn't support  mobile ID anymore
    Could you please change that in AOQ and see if it works.
    For example if you're using to send push to user admin, change the mobile ID to 2 (and same for other users)
    I have added to use users IDs long ago, so it should work just fine.
    Edited by cag014
    Have fixed the error by using push for userID and simplePush for mobile.
    According to the ID (user or mobile) AOQ automatically sends correct type of notification.
    No changes in user_data required.
    Let me know if it works...
    BTW do you use interactive notification in AOQ?
    Edited by cag014
    Hi cag, the push notifications working fine, very big thanks! But I got a new bug.
    In the bug window, I got a bug message. This line is wrong, but the prev version that's working. I back the v13, and the bug is stayed. What do you think? What is the problem?
    Here is the line and the in the picture the problem.
    {5, "`leilasRoomTemp`",{state="value>&LeilasroomThermostat",timeSlot="m=9~12;1~4;21:30~05:15",timeLoopAct={"`leilasRoomThermostat`","setHeatingThermostatSetpoint,&LeilasroomThermostat","","{@`leilasRoomThermostat`:heatingThermostatSetpoint>&LeilasroomThermostat}"}}},
    While using in condition statement to compare value of the device no @ sign required. Like that
    Only when you need to retrieve the value of the device  in formula or message the @ sign is required.
    @`leilasRoomThermostat`>heatingThermostatSetpoint
    for example:
    trueAct={"","tts","the set point of room thermostat is @`leilasRoomThermostat`>heatingThermostatSetpoint"} (no comparation in the line)
    Use that line
    {5, "`leilasRoomTemp`",{state="value>&LeilasroomThermostat",timeSlot="m=9~12;1~4;21:30~05:15",timeLoopAct={"`leilasRoomThermostat`","setHeatingThermostatSetpoint,&LeilasroomThermostat","","{`leilasRoomThermostat`:heatingThermostatSetpoint>&LeilasroomThermostat}"}}},
    Edited by cag014
    for example:
    Use that line
    Thanks cag, I understand! The line is working fine.
    Where can I find the latest version of AIO and a manual?
    Thx @cag014
    Thx @cag014
    At download
    for HC2
     for HC3/HC3 lite and Yubii
    for PC/MAC
    If you have an issue with notification (HC3 platform)
    Please download file
    Is 5.120.10 without issues with AOQ?
    No issues on my side... everything works
    Hi cag,
    What happened here? What is the meaning of (disarmedpoort)? The only device in $Achterpoort is really armed after the arming, so there is no failing arming.
    Edited by Rover
    On 9/25/2022 at 3:56 PM, Rover said:
    What are the names of the alarm zones you have?
    Might be you have alarm zones called Achter and Achterpoort? It could explain this problem
    Please try version below
    Let me know if everything works fine...
    Edited by cag014
    Hi cag,
    Yes your suspection was true: there is also a zone Achter.
    V13.7 executes the armAlarm statement in zone Achterpoort correct now, but breaching the sensor in zone Achterpoort does not trigger an alarm, while another (same type of) sensor in another zone does the triggering correctly.
    BTW: v13.7 initiates the AOQ much faster than v13.4 ?
    2 hours ago, Rover said:
    Hi cag,
    Is the same sensor defined in both zones?
    No, both zones &Achterpoort en $Deuren (not the zone $Achter) have one different Fibaro D/W sensor. Breaching $Deuren works, but breaching $Achterpoort does not work. These two devices are not defined in zone $Achter.
    Edited by Rover
