7 hours ago, Rover said:
No, both zones &Achterpoort en $Deuren (not the zone $Achter) have one different Fibaro D/W sensor. Breaching $Deuren works, but breaching $Achterpoort does not work. These two devices are not defined in zone $Achter.
My bad ?, in the testing of v13.7 I have forgotten to set back the &Achterpoort zone for triggering on state="value=breached". Sorry for bothering you with this, cag.
Hi cag,
When I  disconnect the power of two HC3 devices only defined in my AOQ1 and not in AOQ2, both AOQ1 and AOQ2 crashed with messages:
[29.09.2022] [17:19:19] [ERROR] [QUICKAPP386]: main.lua:2103: Wrong parameter: 'simplePush'. Available parameters: email, push
[29.09.2022] [17:20:49] [ERROR] [QUICKAPP387]: main.lua:2103: Wrong parameter: 'simplePush'. Available parameters: email, push
Edited by Rover
    18 hours ago, Rover said:
    Hi cag,
    What devices?
    What SW version you run on HC3?
    Edited by cag014
    5 hours ago, cag014 said:
    What devices?
    I had disconnected a Fibaro Smart Implant and a Fibaro RGBW2 on HC3 v.50.070.42.
    Edited by Rover
    My HC3 currently at Fibaro Service and should arrive back to me on Sunday by end of day.  Is this version 50.070.42 is the latest ?
     Using Yubii or HC3L I don't see any problem with the latest version 5.120.10
    Now I understand, when device disconnected the AOQ tries to report about dead device, since last upgrade the push notification doesn't support mobile devices, only user ID (email).
    Please update HC3 version or change mobile ID to user ID in global parameters
    pushNote    = {true,"2"}  -- if true, auto alerts interactive/push notification will send
    See
    See
    I will update HC3 version to v5.120.10. But I am missing an overall inside in the latest status of pushing, interactive or not. And what is the impact for AOQ and AOS?
    Edited by Rover
    Currently I don't see any impact on AOQ or AOS and all push notifications are work properly (including interactive push).
    But I am trying to fix the problem and send notification considering the version number. I believe in one hour I'll post a new AOQ for you.
    @Rover
    Please try attached version. Should support push notifications on all HC3 versions
    41 minutes ago, cag014 said:
    @Rover
    Hi @cag014, should everyone upgrade to the latest version? In the marketplace it’s an older version…
    I post here the version for users to test to verify there are no some bugs and then upgrade the download center.
    Meanwhile, yes you can download this version and try it.
    I believe on Monday I'll release that (if no issues reported)
    Thx @cag014, I'm currently implementing AIO ?.
    Q: Any idea how to use TTS with SONOS speakers? Any directions welcome.
    Unfortunately, I do not use SONOS for TTS.
    I'm using Android tablet and Android mobile TTS solution.
    May be that could help for SONOS
    thx @cag014
    Sorry for all my questions, but I'm new to this, learning everyday and the weather is bad here so I have some time ?
    Q: I've implemented this in AIO.
    {0,"`allLivingMotion`",{state="value=true",trueAct={"`allLivingLights`","turnOn"},falseAct={"`allLivingLights`","turnOff","400"}}}
    • Is there a possibility to restart the 400sec every time when the MotionSensors are breached
    • Can we add LUX condition to this scene
    Before I was using a LUA script from @SmartHomeEddy which worked perfectly, before that I used Advanced Lighting Control (ALC) (UHAS) on my HC2 from @Sankotronic
    Declarations
      conditions = { {
          id = 78,
          isTrigger = true,
          operator = "==",
          property = "value",
          type = "device",
          value = true
          id = 263,
          isTrigger = true,
          operator = "==",
          property = "value",
          type = "device",
          value = true
      operator = "any"
    Actions
    -- This scene turns on one or more lights:
    --    when Lux level is below a certain level (see DECLARATIONS) and
    --    shows the Lux level of one ore more Lux sensors and
    --    turns off the lights after a certain time (maxTime),
    --    unless there is motion from one or more Motion sensors
    -- Please enter the right ID's (if more than one, seperate by ",") and the prefered maxTime for the lights to stay on
    local light = {2662-- ID's of the lights to turn on
    local motion = {78263-- ID's of the Motion sensors to check if they are breached
    local lux = {80265-- ID's of the Lux sensors to (only) show the lux level
    local maxTime = 1*500 -- Maximum time the sensor should be safe before turning off (n*60 where n is minutes)
    local sleepTime = 5 -- Time in seconds between each check of the Motion sensor (default = 5)
    local debug_TAG = "Woonkamer licht" -- Tag for the debug messages
    -- Below here no changes are necessary
    for i in pairs(light) do -- Turn on the lights
      fibaro.debug(debug_TAG,"Turning on (ID " ..light[i] ..") " ..fibaro.getName(light[i]) .." for " ..maxTime .." seconds")
      fibaro.call(light[i],"turnOn")
    for i in pairs(lux) do -- Show the lux level of the Lux sensors
      fibaro.debug(debug_TAG,"Current Lux level " ..lux[i] .." " ..fibaro.getName(lux[i]) ..": " ..fibaro.getValue(lux[i],"value"))
    local safeTime = 0
    while safeTime < maxTime do -- Loop until maxTime is reached
      fibaro.sleep(sleepTime*1000)
      safeTime=safeTime+sleepTime
      fibaro.debug(debug_TAG,"Counting up safeTime " ..safeTime .." to maxTime " ..maxTime)
      for i in pairs(motion) do
        if fibaro.getValue(motion[i],"value"then -- Check if Motion sensors are breached
           fibaro.debug(debug_TAG,"Reset by Motion sensor " ..motion[i] .." " ..fibaro.getName(motion[i]))
           safeTime = 0 -- Reset safeTime to zero
    for i in pairs(light) do -- Counted down to maxTime, turn off the lights
      fibaro.debug(debug_TAG, "Turning off " ..light[i] .." " ..fibaro.getName(light[i]))
      fibaro.call(light[i],"turnOff"
    Edited by Sjekke
    Hi @Sjekke ,
    Hmmm... latest and final version of UHAS with ALC is just about to be published. Previous beta versions was using Very Smart Lights (VSL) so I guess you meant you used VSL? Raising this comment just to be clear since access to UHAS with ALC is at this moment restricted just to few people that helping me mostly with writing manual since it is equally big job as writing all those 80+ VD's and 40+ scenes.
    1 hour ago, Sankotronic said:
    Hi @Sjekke ,
    Hi @Sankotronic, you are right ofcourse. I mean VSL.  I hope you port UHAS to HC3 very soon ?
    2 hours ago, Sjekke said:
    thx @cag014
    It restarted by default every time when the sensor is breached again, no issue there.
    Please note that 400 seconds counting starts when the sensor goes back to safe mode and not from the moment when it's breached.
    Yes, you can add any condition you need.
    For example, assuming you have device called allLightsLux then
    {0,"`allLivingMotion`",{state="value=true",trueAct={"`allLivingLights`","turnOn", "if {`allLightsLux`:value <80}"},falseAct={"`allLivingLights`","turnOff","400"}}}
    Hi @cag014, I already moved some scenes to AIO and they are working perfectly. But since I like as minimum scenes as possible, do you think we can nest both scenes?
    {0,"`allLivingMotion`",{state="value=true",trueAct={"`allLivingLampLights`","turnOn"},falseAct={"`allLivingLampLights`","turnOff","600"}}},
    {0,"`allLivingMotion`",{state="value=true",trueAct={"`allLivingHueLights`","turnOn","if{$24clock:value=$sunsetHour~04:00}"},falseAct={"`allLivingHueLights`","turnOff","600"}}},
    I explain I have 4 lights in my living room > 2 are controlled via a Fibaro Wall Plug and 2 HUE lamps.
    jS2n={
    --== Living Room
    livingRoomTVBox=478,livingRoomBlind=188,livingRoomMotionFront=263,livingRoomMotionBack=78,livingTVLight=62,livingDressorLight=26,livingRoomLeftHue=567,livingRoomRightHue=566,
    --== Office
    officeBlindBig=191,officeBlindSmall=195,
    --== Combinations
    allBlinds="`livingRoomBlind`|`officeBlindBig`|`officeBlindSmall`",
    allLivingMotion="`livingRoomMotionFront`|`livingRoomMotionBack`",allLivingLampLights="`livingTVLight`|`livingDressorLight`",allLivingHueLights="`livingRoomLeftHue`|`livingRoomRightHue`",
    What would be my ideal scenario.
    • light can always turnOn when motion is detected
    • 1 light may always switch on when motion is detected, but only when LUX is lower than 50Lux
    • The 2 HUE lamps can only be switched on when motion is detected, but only between sunset and 04:00 at night
    • All lights should turnOff after 600sec unless there is motion detection.
    Thanks for your help, this helps me learning!!
    Edited by Sjekke
    On 10/1/2022 at 8:28 PM, cag014 said:
    @Rover
    Hi cag,
    I have tried v13.8 with HC3 still on v50.070.42.
    {"&Test",{state="Start",initOnStartup=false,trueAct={"Push","sendPush,2","iPhone 6"},}}, delivered no push message at the iPhone when &Test become Start.
    &Test:Global[Start] => sendPush,2(Rover) 'Push','iPhone 6')
    But using a Block Scene producing a push message when &Test become Start works.
    Edited by Rover
    16 hours ago, Rover said:
    Hi cag,
    Strange, works perfectly on my system...
    Could you please post the block scene?
    Edited by cag014
