4 minutes ago, cag014 said:
If global not defined then is nil, means false. with one exception for dbgInitState, if not defined then set to true.
What do you think it should be set to if not defined?
By the way, for shortcut lovers, you can use shortcut for each level in jM line (case sensitive)
dbgInfo -> dIf
dbgTruestate -> dTs
dbgFalseSTate -> dFs
dbgInitState -> dIs
dbgCmdFalse -> dCf
for example - instead
JM={{“motion”,{state=”true”,dbgInfo=false, dbgTrueState=true, trueAct={“light”,”turnOn”}}},}
you can use
JM={{“motion”,{state=”true”,dIf=false, dTs=true, trueAct={“light”,”turnOn”}}},}
At the moment I do not get any debug messages, just the init state messages. Also if i set dbgInfo =true in the AOQ parameters (where was a question), no debug messages are to be seen.
I think it should be set to if not defined as it was before, so all debug messages visible.
Shortcuts are nice.
12 hours ago, Rover said:
I think you have to set the global debugging parameters in the AOQ parameters?
What is the default value of the debugging parameters (value if not defined globally)?
@cag014
I think there is something wrong when global level is not defined at all.
Wow, during initialization, I noted a huge difference to previous versions. Indeed trueActState (probably others too) are considered and action are not executed. I so  few other commands executed after   jM{} states validation... is shown. I assume these lines are affected by other lines that executed commands during init stage and some devices states have been changed.
Edited by AR27690
    @AR27690, @Rover
    Guys, you're absolutely right, something strange going on when not defined.
    Attached version includes redefinition for levels to true (as suggested by @Rover) if not defined at all
    Another change per user's request, when conditions failed then instead of "-> no actions" shown "" sign. Seems like it makes it easy to identify lines where conditions are not met.
    Again, let me know if it works
    Thanks for your time and patience
    Edited by cag014
    • Thanks 2
    11 hours ago, cag014 said:
    @AR27690, @Rover
    initial: works!
    dbgInfo checked: works!
    Yes, works here also....
    Hi @cag014 I downloaded AOS 8.6 to try and find whatever is causing a random 503 error and I'm running this scene as is (without any changes) just to monitor and to identify z-wave “dead” and/or NACK occurrences.
    Please see below the output:
    I don't see any reported problems. Is my interpretation correct that no errors have thus far been reported or am I missing something?
    Please wait a while m I would say couple of hours at least,
    Please note - The table refreshed every 5 minutes (by default) or you can refresh it manually by pressing button Refresh (in AOS it appears instead of Clear button)
    HI cag,
    I have a question for you. I have a line.
    {0"`gardenTemp`",{state="value>17",timeSlot="m=10;06:30~21:28",trueAct={{"`livingRoomThermostat`|`livingRoomThermostat1`|`diningThermostat`|`bathRoomThermostat`","setHeatingThermostatSetpoint,21","","{&LivingroomThermostat:value>19.5}"},{"&LivingroomThermostat|&BathroomThermostat","setGlobal","21","{&LivingroomThermostat:value<>21}"}},falseAct={{"`livingRoomThermostat`|`livingRoomThermostat1`|`diningThermostat`|`bathRoomThermostat`","setHeatingThermostatSetpoint,22","","{`diningThermostat`:heatingThermostatSetpoint<>22|&LivingroomThermostat:value<>19.5}"},{"&LivingroomThermostat|&BathroomThermostat","setGlobal","22","{&LivingroomThermostat:value<>22|&LivingroomThermostat:value<>19.5}"}}}},
    Everything when the AOQ is restarted, the falseAct line is runing, but the timeSlot is --timeSlot="m=10;06:30~21:28"--
    What do you think, what is the problem?
    1 hour ago, SmartLifeSystems said:
    HI cag,
    The time slot ignored during initialization - to set the device in the correct state.
    You can disable initialization by setting global or command to false - like that:
    1. initOnStartup=false
    2. ,falseAct={{"`livingRoomThermostat`|`livingRoomThermostat1`|`diningThermostat`|`bathRoomThermostat`","setHeatingThermostatSetpoint,22","","{`diningThermostat`:heatingThermostatSetpoint<>22|&LivingroomThermostat:value<>19.5}", false},{"&LivingroomThermostat|&BathroomThermostat","setGlobal","22","{&LivingroomThermostat:value<>22|&LivingroomThermostat:value<>19.5}", false}
    That's interesting situation... is anyone has an idea what will be better, to ignore timeSlot or not?
    Edited by cag014
    @SmartLifeSystems
    My bad... there is another option to avoid falseACt{} execution by defining specific initAct{} table. In your case something like that:
    initAct={"","debug","No action taken"}
    Edited by cag014
    2. ,
      2 hours ago, cag014 said:
      @SmartLifeSystems
    How can I put this initAct table?
    As I understand you don't want to execute falseAct{}, right?
     I do, but only in timeSlot. This line it worked in the past.
    There is no change on execution of trueAct or falseAct{} tables on startup
    The initialization done also at the beginning of the timeSlot (every beginning). Maybe that's the reason that you saw the initialization....
    Anyhow, I do suggest adding false parameter at the end of each command in falseAct{} table. It means, that on startup, the initialization won't work (as you need) and at the beginning of the  timeSlot  initialization will be executed for this line (in your case falseAct). Exactly what you need
     falseAct={{"`livingRoomThermostat`|`livingRoomThermostat1`|`diningThermostat`|`bathRoomThermostat`","setHeatingThermostatSetpoint,22","{`diningThermostat`:heatingThermostatSetpoint<>22|&LivingroomThermostat:value<>19.5}", false},{"&LivingroomThermostat|&BathroomThermostat","setGlobal","22","{&LivingroomThermostat:value<>22|&LivingroomThermostat:value<>19.5}", false}
    Edited by cag014
    Since there are many options to avoid initialization, on startup ignore timeSlot (as delay time ignored too).
    By ignoring timeSlot, the code sets the devices to  "known" state.
    Edited by AR27690
    Hi again,
    Bug fix
    • LED status does not display
    • "when" statement defined in action state does not work             trueActState="when {`wallSW`=true}"
    • When statement includes or conditions, only passed condition displayed.
    New features
    Now inside statement no need to define value for all types of devices. Previous "{`wallSW`:value=true}"  Current   {`wallSW`=true}. Any other property should be defined as before
    • added $newSw and $newBeta  availability values true/false
    • added $initMode (true/false) . During initialization $initMode=true, so you can perform actions accordingly.
    • added extra debug level:  dbgCmdTrue ("dCt"). Now if dbgTrueState=false, the executed commands still could be seen using dbgCmdTrue=true
    • added an option to set timer, means you can set/change same timer in different lines by different devices. Very useful if you've few sensors which controls the same devices. Like to turn off lights
      for example:
    {"`motion1`,{state="true", trueAct={"`lights`,"turnOn"}, falseAct("`lights`,"turnOff", "timer1,300"}}}, means when motion1 back to safe, turn OFF the lights after 300 seconds.
    {"`motion2`,{state="true", trueAct={"`lights`,"turnOn"}, falseAct("`lights`,"turnOff", "timer1,300"}}}, means when motion2 back to safe, turn OFF the lights after 300 seconds. Re-set the timer
     Now the lights will turn OFF by the last sensor that back to safe.
    You can define as many timers as you need, but keep the syntax timerXXXX,(seconds). You can define names also like timerGPS,100
    Use proper names for timers to keep it easy to remember.
    to cancel the timer, set the timer to zero. timerGPS,0 - will cancel the timer and the command won't be executed.
    Major "face lifting" for debug information (feels and looks like code)
    Please try it before release.
    Please backup your working code 😀
    Let me know if it works and looks better. Your feedback appreciated.
    Edited by cag014
    Hi! I'm trying to run scene several times a day with checking one singe condition but nothing happening:
    quickCondition = true
    quickConditionStr = (quickCondition and '&alwaysZero:value=0' or '&alwaysZero:value>0')
    {0,"$blank",{
    timeSlot="18:10~18:15, 19:30~19:31, 20:40~20:41, 21:07~21:08, 22:00~22:01, 23:30~23:31",
    trueAct={
    {"_55","startScene", quickConditionStr}
    What I'm doing wrong?
    Edited by hellower
    I am trying to understand your definition and that's what looks like you did
    {true and '&alwaysZero:value=0' or '&alwaysZero:value>0')
    First of all, the entire statement should be in double quotes and not parts of conditions.  When using or conditions the statements between should be within brackets {} or {}.
    The and conditions used in the same brackets {... and ... and ...} or {.... and ... }
    Another question, what do you mean just by true?
    Please tr as below
    ("_55","startScene", "{&alwaysZero:value=0} or {y &alwaysZero:value>0}"
    By the way in case your property is value you can skip that
    ("_55","startScene", "{&alwaysZero=0} or {&alwaysZero>0}"
    Still don't understand where/why you are using Boolean true?
    May I suggest shorter option
    ("_55","startScene", "{&alwaysZero>-1}"
    Edited by cag014
    Looks just great!!! More understandable.
    Have user the timer option - thanks solved some issues with my three motion sensors in hallway.
    Any chance to have same option in AOS (for HC2 )?
    Hopefully you have condition to turn OFF the hallway lights (If that what I think you do) only when all sensors are safe "{'ms1','ms2','ms3'=false}".
    Using timer solves the issue of using delay when one of the sensors back to safe.
    Working on that (including same debug view)
    Edited by cag014
