    22 hours ago, SmartLifeSystems said:
    Hi cag! How can we use in the AOQ the winter/summer time? I have one line, but in the summer time it works it uppside down, because in summer time the timslot end time is before then the start time. In Hungary the sunset hour now 19:06.
    Here is the line:
    {0"`hallMS`",{state="value=true",timeSlot="$sunsetHour~19:00",trueAct={{"`hallLight`","turnOn","","{`hallLight`:value=false}"},{"`hallLight`","turnOff","","={`livingroomMS`:value=true|`hallLight`:value=true|`hallMS`:lastBreached>60|&HallLight:value=Automatic}"}}}},
    Yes, looks like daylight saving time causes an issue.... but you can add the number of hours to $sunsetHour. In your line I think you've added one hour so
    {0"`hallMS`",{state="value=true",timeSlot="$sunsetHour~?$sunsetHour+3600?",trueAct={{"`hallLight`","turnOn","","{`hallLight`:value=false}"},{"`hallLight`","turnOff","","={`livingroomMS`:value=true|`hallLight`:value=true|`hallMS`:lastBreached>60|&HallLight:value=Automatic}"}}}},
    In any case have added $timezoneOffset keyword to solve the problem for future use were the entire timeSlot could be shifted according to the time zone + DST.
    Pls pay attention that $timezoneOffset includes your standard time offset from GMT/UTC and should be part of your timeSlot definition.
    For example in Hungary the standard time zone offset is +1 hour and I believe now is +2 hours.
    So now your line should be like following:
    {0"`hallMS`",{state="value=true",timeSlot="$sunsetHour~?18:00+$timezoneOffset?",trueAct={{"`hallLight`","turnOn","","{`hallLight`:value=false}"},{"`hallLight`","turnOff","","={`livingroomMS`:value=true|`hallLight`:value=true|`hallMS`:lastBreached>60|&HallLight:value=Automatic}"}}}},
    Please download attached version for that
    Let me know if one of the solutions works for you ( should see the time after calculation on the table at debug window)
    Since the new version supports both solutions I suggest to use it..
    Edited by cag014
    On 3/24/2022 at 10:55 AM, Benrive said:
    Hello @cag014.
    I have this error, I have copied the complete code of the last AOQ main that you gave me but it keeps coming up.
    Because it can be?.
    It comes out after I modified the user_data but I really don't know what it is due to,
    Line 578 was commented out, it lets me continue but I imagine it will be necessary.
    The new version 12.1 should fixed the problem
    On 3/25/2022 at 9:45 AM, Benrive said:
    No, I have 2 HC3s, the ones that have given us so much trouble.  What I would like is to be able to see the variables in the yubii App, just as I can see a light or a sensor and know when its last state change was.
    This my variables.
    I explain them:
    GPSBenja,GPSMaria,GPSSofia It is a numeric variable that can have 0,1,2.
    They all work with geoaction.
    I have 2 locations, one for 400 meters and one for 150 meters
    value 2  less than 400 meters  ( In home )
    value 1 between 150 and 400 meters
    value 0 less than 150 ( In home ), It won't let me put less than 150 meters in fibaro location
    I don't know if putting less in AOQ with $geoRadius would work.
    This line for example  when state=enter
    I don't know if it is possible from the App to change the state, for example, in case geofending fails, I can change the state since I use it as a condition for the fingerprint door opener to authorize the opening of the door.
    It only opens if GPSStatus of any of us is = 2
    Have wrote the QuickApp, here how it looks
    By pressing the button of any user, global variable will be changed to value 2 accordingly.
    In QuickApp you have user, global and status tables. You can change it per your needs and pls update the QuickApp icon (currently shows question mark )
    Please redefine your local global as system's global variables and remove it from local table in AOQ. No need to change the jM lines (AOQ automatically will find them)
    To add more users update tables accordingly and create new buttons in QuickApp
    BUT by looking again on your explanation I am a little bit confused
    value 2 and value 1 both means "in home" ?
    Could you please post exactly what label you want on the buttons?
    For example in my case I have defined two location 150 and 800, now
    value=0: over 800 : left home
    value=1: less then 800: approaching home'
    value=0: less then 150: at home
    That's how it shows in QuickApp below
    Make sure to update user's access to include the new QuickApp in Yubii app.
    Please let me know if you need any help regarding the code.
    Edited by cag014
    Guest Benrive
    Thanks, this is what I needed. Thanks.
    But I don't understand how the variable being outside and inside is value 0?.
    I have changed it with your instructions and now it would be like this.
    enter location 800m value = 1
    Leave 800m value = 0
    enter 150m value = 2
    It's true?
    Any way to put an icon next to the label?, or a green, orange or red dot.
    A way to make it more visual
    Edited by Benrive
    Guest Benrive
    Hello @cag014
    I'm trying to get the button to have 2 states, depending on the variable, but something about this is failing me.
    What do you mean by outside and inside? The Geofencing sends to values "enter" and "leave" for every location
    So when you enter range 800 it means you're approaching. When you leave 800, it means you left .
    You might need to add jM line with state="leave" and update the global to 0.
    This is a button and no way to use HTML to set color or icon, but you can add label over every button and then you can set colors and icons
    Something like that (an example for one user)
    Yes, the fibaro.getGlobalVariable() function returns string not a number so
                if fibaro.getGlobalVariable(jGlobal[i]=="0") then
    should work fine
    @Benrive
    Let me know if you want to use labels and I will rewrite the code.
    Guest Benrive
    I have seen my error, and I have changed everything in this way.
    It's ok now?
    Yes Please, It's amazing
    Edited by Benrive
    It's ok now?
    Attached QA version with labels.
    The icons are actually emoji that you can find on the web. You have two options to set them:
    1. Just copy/paste emoji inside the string like that
    "<font color=red><font size=5><sub>?</sub></font></font> ",
    2. Use Unicode value of the emoji
    "<font color=red><font size=5><sub>&#127968</sub></font></font> "
    Here two links for emoji
    The font color of the user name is set by standard HTML definition
    "<font color=orange>"
    Here a link for color names
    Guest Benrive
    thanks, I have the Family hallucinating.  I will now add my youngest daughters.  I am enormously grateful to you
    Edited by Benrive
    Looks fabulous ....
    Guest Benrive
    Just now, cag014 said:
    Looks fabulous ....
    Not without your help and thanks to you.
    My daughters give you a round of applause ???.
    Tomorrow I will try to make one for the other 2 variables LockStatus and DepositoFull.
    Let's see how it goes. ?
    Let me know if you need help with that also...
    By the way may I suggest to simplify your lines using trueActState() instead of writing same condition several times. More connivance way  when need to change location in the future.
    By looking on your lines I think it's a good idea to add an option to use $geoUser keyword as part of the global variable name, so then the line could be very simple like:
    Current version doesn't support that , but will make the changes in AOQ and post it for test.
    Guest Benrive
    Yes, I wanted to ask you if there was any way to simplify as many actions with the same condition.  But since I ask you so many questions, in the end if something is working I prefer to ask you what doesn't work or I don't know how to do it.  I think sometimes I can be too heavy and I don't ask you some things.  Tomorrow I will try to use Trueactstate, it will be very useful for me because I have many conditions in almost all JM lines.  I'll also make the switch to use GeoUser as part of the variable.  All these changes will come in handy to lower RAM consumption.  Thanks
    The use of geoUser doesn't work yet... I will release that probably tomorrow.
    Guest Benrive
    Yes I know .  I'll save that for when you get it.  No hurry .  Thanks
    Guest Benrive
    Another Question,
    Is it possible to see the date and time of the last status change for each geouser in the virtual object?. In this screen?.
    16 minutes ago, Benrive said:
    Another Question,
    Yes, of course
    Were you want to display that? On the label next to name or on the button next to the status?
    Here is an example displaying the timestamp on both fields (label and button)
    Were you prefer to see that?
    Guest Benrive
    I think it’s better in button.
    Agree.
    Since you probably made some changes on the code, so to reduce your efforts for an update, please change marked lines in your QuickApp code
    function QuickApp:updateStatus()
        local val,vTime=0,0
        for i=1,#jUser do
        val,vTime=fibaro.getGlobalVariable(jGlobal[i])
        self:updateView(jLbl.id[i], "text", jLbl.icon[i]..jLbl.fColor[i]..jUser[i].."</font>")
        self:updateView(jBtn[i], "text", jStatus[tonumber(val)+1]..os.date("  (%d %b %H:%M)", vTime))
    No changes in other lines in the code
    Let me know if it's OK
    Edited by cag014
