Vor 6 Stunden sagte Benrive:
Unfortunately, it didn't work. The 508 is a light.
Thanks in advance.
Guest Benrive
6 hours ago, parip69 said:
Thanks in advance.
Hello @parip69,
It doesn't work, because we have set a range of hours where an action must occur in order to work, what you must do is define when you want it to turn on and when to turn it off. One solution would be this
Try This.
Guest Benrive
On 3/13/2022 at 1:19 AM, cag014 said:
I am currently on vacation... will be back on Mar-23
Hello @cag014
I hope you are enjoying your vacation.
By the time you come back, tell you that I have already solved the geofending problem.
I deleted the user and created it from the Fibaro Login website so that it would have a FibaroID. This way it works perfectly.
I have created 2 Location for 400m and 150m so I can make sure and get much closer to what I want to control.
To rest that you have well deserved for sure
6 hours ago, Benrive said:
Hello @parip69,
Try This.
Hi
Unfortunately a syntax error with the timeSlot.
I just want to turn on one light in a timeSlot otherwise turn it off again.
Guest Benrive
7 hours ago, parip69 said:
Hi
Can you send a screenshot of the error?.
I have tested it on a light of mine and it works correctly.  also send me a screenshot of the device on the device screen please
Hi.
The syntax error was with the Hc2 The Hc3 is not an error but did not work as desired.
Wrote a script and that in 5 minutes I just wanted to try.
Thanks for the effort.
Guest Benrive
2 hours ago, parip69 said:
Hi.
Ok, I only have Two Hc3. Sorry
    Yes, when you use several times true and false inside timeSlot on HC2 it fails with syntax error... thanks for finding that!
    Have fixed the error and will be part of AOS next release.
    Meanwhile you can use the old (traditional) syntax
    You have stated that
    In order to fix the bug on HC3, could you please explain what doesn't work as desired?
    Edited by cag014
    Guest Benrive
    On 3/9/2022 at 1:57 PM, Benrive said:
    On 3/9/2022 at 12:50 PM, cag014 said:
    What do you mean from Yubii? Is it means the variables will be in Yubii?
    I would like to be able to see in yubii app on iPhone, the status of each one of us
    Hello @cag014, welcome back from your vacation.
    I hope you have a good vacation and you can disconnect, I am not working due to a complicated operation on one eye but I think they make me work even more. ?
    When you can, could you give me an example, I wouldn't know where to start to be able to see the variables from the App on iphone.
    In other way.
    Yesterday GeoAction worked wonderfully when my wife came home, but this morning when she left she has not detected it, nor has she obviously been able to change the variable to 0
    I have like 5 Jm lines to verify if it works, then obviously I will leave only the necessary ones.
    And test for it.
    EDIT: 24/03
    Now solved, at the moment anyway i think yubii geofending and iphone doesn't work very well
    Edited by Benrive
    Hi.
    In the HC2 it works with the old syntax. In the HC3, it's also trying to work with all the attempts. Thanks
    The syntax of the HC2 is not the same as the HC3?
    Edited by parip69
    8 hours ago, parip69 said:
    Hi.
    Should be the same, but as I said - bug has been found and next release of HC2 will be the same
    Guest Benrive
    Hello @cag014.
    I have this error, I have copied the complete code of the last AOQ main that you gave me but it keeps coming up.
    Because it can be?.
    /monthly_2022_03/image.png.19ee75bf53b344072fde51022b16a3c1.png" />
    It comes out after I modified the user_data but I really don't know what it is due to,
    Line 578 was commented out, it lets me continue but I imagine it will be necessary.
    7 hours ago, Benrive said:
    Hello @cag014.
    Because it can be?.
    Yes, I have seen this error also  after last update... but it happens only after restarting the system not by changing the user_data file
    Will fix that, meanwhile you can keep that remarked... this line shows the LED statuses (nothing serious)
    Guest Benrive
    Hello @cag014
    could you give me an example of how to see the status of the variables in Yubii?  I understand that with a virtual button nail but I would not know where to start.  Also in my case all the variables are created in string inside a global variable in AOQ.
    2 hours ago, Benrive said:
    Hello @cag014
    Do you mean Yubii  App on phone
    Guest Benrive
    No, I have 2 HC3s, the ones that have given us so much trouble.  What I would like is to be able to see the variables in the yubii App, just as I can see a light or a sensor and know when its last state change was.
    This my variables.
    I explain them:
    /monthly_2022_03/image.png.75718b358aaf868e1b53c867cffa2e36.png" />
    GPSBenja,GPSMaria,GPSSofia It is a numeric variable that can have 0,1,2.
    They all work with geoaction.
    I have 2 locations, one for 400 meters and one for 150 meters
    value 2  less than 400 meters  ( In home )
    value 1 between 150 and 400 meters
    value 0 less than 150 ( In home ), It won't let me put less than 150 meters in fibaro location
    I don't know if putting less in AOQ with $geoRadius would work.
    This line for example  when state=enter
    The other variables are for sending push .
    DepositoFull  is a Dehumidifier tank  numeric 0= empty 1= full
    It works with a JM line detecting a period when the consumption is less than 100w
    LockStatus Is a State of SmartLock 0= Open 1=Close.
    I need this variable, because danalock doesn't work as expected and has trouble detecting its state.
    So I control it with the variable forcing the closed state LockStatus = 1 using timeLoopAct and trueAct with certain conditions.
    These variables would be separated from the others, in another virtual for example.
    I don't know if it is possible from the App to change the state, for example, in case geofending fails, I can change the state since I use it as a condition for the fingerprint door opener to authorize the opening of the door.
    It only opens if GPSStatus of any of us is = 2
    Edited by Benrive
    NO, it won't work. The trigger comes from HC3 when the defined distance breached.
    Regrading all other actions, yes it could be done but since you want to change the status of users' Geofencing I suggest to use system's global variables and not local (to simplify the process)
    I will post QuickApp based on global variables for you
    Edited by cag014
    Hi cag! How can we use in the AOQ the winter/summer time? I have one line, but in the summer time it works it uppside down, because in summer time the timslot end time is before then the start time. In Hungary the sunset hour now 19:06.
    Here is the line:
    {0"`hallMS`",{state="value=true",timeSlot="$sunsetHour~19:00",trueAct={{"`hallLight`","turnOn","","{`hallLight`:value=false}"},{"`hallLight`","turnOff","","={`livingroomMS`:value=true|`hallLight`:value=true|`hallMS`:lastBreached>60|&HallLight:value=Automatic}"}}}},
    Guest Benrive
    Thank you very much @cag014.
    you are a great help and better person
    A bit of my story and my thanks
    20 years ago I started with home automation in my first house.  Back then there were hardly 2 or 3 systems to do something similar.  Simón Vis, KNX and little else.  But they were very closed systems and little variable.  I chose at that time that I was an Omron PLC programmer and did everything with two-wire wiring with a system called Compobus.  Then I designed the house with 3D Home rendered to insert images on a touch screen that I placed at the entrance of the house.  That took a number of hours that today would be priceless.  He managed to do real wonders with that and the wired system was foolproof and terribly fast.  But I can assure you that the comfort that now exists with this system is magnificent, although it is true that the HC3 sometimes hangs and does not respond.  Your All in One utility speeds up everything a lot, and above all, in a matter of a few weeks you master enough to solve the vast majority of issues.  I'm telling you all this because I understand the work and effort involved on your part in a disinterested way.  thank you and thank you
    Guest Benrive
    Here is the line:
    here the really important thing is to know how you want to do it.  You could subtract minutes from sunset time, or delay the shutdown in summer.  But what do you really want to do?
    Edited by Benrive
