On 12/28/2018 at 12:35 AM, jgab said:
eventrunner
Thank you for tour help. Brilliant what can be done with Your Er.
What I am doing wrong?
If one of the two doors is open light >>off
Both doors closed light off
%% value for:
deurHfdSlpkmr
deurGastboven
lightSensorBuVoor
 Rule.eval("deurHfdSlpkmr:isBreached & deurGastboven:isBreached => stekkerTrap:off & stekkerLedOverloop:off ")
   Rule.eval("deurHfdSlpkmr:isSafe & deurGastboven:isSafe => stekkerTrap:on & stekkerLedOverloop:on ")
   Rule.eval("once(lightSensorBuVoor:lux > 201) & deurHfdSlpkmr:isBreached & deurGastboven:isSafe => stekkerTrap:off & stekkerLedOverloop:off ")
   Rule.eval("once(lightSensorBuVoor:lux > 201) & deurGastboven:isBreached & deurHfdSlpkmr:isSafe => stekkerTrap:off & stekkerLedOverloop:off ")
   Rule.eval("once(lightSensorBuVoor:lux < 200) => stekkerTrap:on & stekkerLedOverloop:on ")
Thanks for your support
    %% value for:
    deurHfdSlpkmr
    deurGastboven
    lightSensorBuVoor
    You mean if one door open light on, if both closed light off?
    The functions are :breached and :safe, not :isBreached and :isSafe
    The second set of rules with lux are a bit tricky to understand what you want. Is the "main" trigger the lux or the sensors being breached/safe?
    To be more precise: There are 3 distinct events that trigger the rule; Lux > 201, deurHfdSlpkmr breached, deurGastboven safe
    AND when the rule trigger all of these 3 conditions need to be true for the action to happen.
    So, my interpretation is; The first time when Lux > 201, when deurHfdSlpkmr is breached and deurGastboven is safe do turn off the lights. And don't do that again until Lux has been below 201 and come back over 201 again.
    Then it would be expressed as
    But it's of course still unclear if that is your intention?
    P.S I'm away on a business trip this week and may be a bit slow in responses.
    Thanks,
    the rules with lux I will change in time rules will come back on it
    30 minutes ago, Sjakie said:
    Thanks,
    Actually thinking more about it, do you really need the 'once' statement? If lux>201 and sensors are triggered, turn off the light.
    Otherwise you limit it to the first time lu is over 201
    You will not get a lot of triggers for lux because it varies quite slowly, it's goin to be the motion sensors that most decide if this rule runs. The lux test just tell us to ignore the motion sensor when the lux is less than 201.
    hi jgab,
    I have something else I dont get fully.
    my rules, just for test execute on time
     ----- GastenBoven Nee Beveiliging:
              Rule.eval("dwSensorsGastenKamerBoven = {54, 176, 77, 221} ") --deurhuis--deurGastBoven, raamrechts, raamlinks[ housedoor-doorguestupstairs-windowright-windowleft
              Rule.eval("pirSensorsGastenKamerBoven = {}")
       Rule.eval("@11:47=> dwSensorsGastenKamerBoven:armed & pirSensorsGastenKamerBoven:armed=1;log('Armed')")
    54 house door I can imagine because in the device is a delay of 45 sec
    176 door not armed
    kitchen.motion is???????????????????????? see screenshot number 77 is named different, where I can find kitchen.motion?? I will remove 77 and reinstall.
    -Just 221 is armed according log
    -in device of HC2 nothing is shown as arm
    -in alarm panel view nothing is also listed as arm perhaps because of devices not armed
    if I change rule
    Rule.eval("@12:17 =>  deurHuisVoor:armed=1 & deurGastBoven:armed=1 & sensorRechtsGastBvn:armed=1 & sensorLinksGastBvn:armed=1;log('Armed')")
    12:17:07 armed all?
    In device all are armed
    10 hours ago, Sjakie said:
    hi jgab,
    176 door not armed
    if I change rule
    12:17:07 armed all?
    :armed is an action (like :on) that doesn't return a value. :isOn and :breached are test that return a value (true or false).
    In fact, not returning a value in Lua means returning null which is interpreted as false.
    So it is not correct to do
    "dwSensorsGastenKamerBoven:arme" returns a table of the current "armed" values of the devices but don't arm them. you should do
    okay, thanksss!
    New problem, hehehe
    Hue will not switch off.
    Rule.eval("stekkerCam:isOn => hueAmbiTvLight:off & huePlafondKlokzijde:off & hueSpotKastLinks:off & hueSchilderijRechts:off & hueSchilderijLinks:off & hueBeeldLinks:off & hueBeeldRechts:off & hueSpotArletaStoel:off  & huePlafondTvZijde:off & hueSpotKastRechts:off")
    before restart it also gave once a error message in windows about server connection.
    HC2 and Hue are on the same router
    After restart HC2 and Hue bridge >>ER will not do anything I trigger 5 times and nothing in debug also no report of trigger!
    If I switch all hues on in app I can switch off in HC2 without any error or dis function.
    Still on HC2 4.53 and ER 36
    Please advice
    /monthly_2019_05/image.png.b0bfc36769291f09a57e681e84c001f3.png" alt="image.png.b0bfc36769291f09a57e681e84c001f3.png" />
    On 5/8/2019 at 10:09 AM, Sjakie said:
    okay, thanksss!
    New problem, hehehe
    Please advice
    Ok,
    on the right-hand side you should never use "A & B & C ..." if you don't mean "If A then If B then If C  then ..." because that's the semantic of the AND operator (&).
    In your rule
    "hueAmbiTvLight:off" is an action that always returns null which is the same as false in Lua which makes it not running the other actions after that.
    If you just want to run a number of separate actions on the right-hand side, separate them with a semi-colon.
    SO, instead you should write
    UPDATE:
    I bought my hc2 mid  December
    Started to create block scenes more as 75 pieceswith also a high number of GV's
    When my automation worked I started to smooth the system up.
    Changed several scenes into LUA to combine some stuff and reduced the number of scenes by 50% with the help of you all.
    The WAF is on an acceptable level but must be come on a higher level.
    At the end of April I started the challenge of Event Runner, woowww very difficult but if you are getting some little experience it is in one word great!!!!!!!!!
    Now 14 days later off course with help of you all en especially the "master" jgab I am almost finished.
    All scenes converted into ER  with some messages over Sonos speaker with http rules.
    In ER 8 running scenes is great to have also a good overview of the installation, security, hue, ground floor intern, curtains/light/outside/power, first floor, heater, messages ond not to forget scene supervisor. Still 5 GV's must be reduced to some extra rules but dont no how at the moment.
    Just need to test heating and arm, working on it.
    To solve some annoying problem of one light and fountain who are having there own life.
    If that is done I need to do some more reporting back what ER is executing. Insert Node Red, Telegram and Harmony hub.
    So when I look back at the last two weeks its not bad at all
    @jgab thank you very much for this beautiful tool, patience and your excellent support
    38 minutes ago, Sjakie said:
    UPDATE:
    ...and Thank you!
    The reason I developed ER was to aid myself in my own coding (and I like to code too). I was a bit hesitant in the beginning to release it to the forum because I was not clear why and who I was addressing. Anyway it's now under the Tutorial section and It's goal is to help people code their own scenes. The "coding" part is why it's under Tutorial and not under Download. However, sometimes ready-made scenes may require people to "configure" so much that it's almost like coding...
    I do believe that many, even if they don't think about it as coding, would like to try and express their own sense of "logic" for how their house should behave
    -If this happens and this is true then do this
    -If it's this time of the day and this happens do that
    -etc etc.
    ...and that's my intention with the framework.
    It's easy to express in "english" how you would like the bathroom light to behave, but it often turns out that that description is full of holes and conflicts when trying to translate it to code. That's why many software projects takes much longer and becomes much more expensive than originally specified - and why there are many formally specification languages at hands these days - but I'm digressing.
    I choose a model of temporal based rules and event based rules with inspiration from Erlang, Expert systems, Prolog, etc. including  my favourite language feature, 'patten matching' :-)
    The idea is to have more of a declarative model allowing people to specify sets of "IF this THEN that", so that all these rules together capture the behaviour of the automated house.
    Having said all this, it's still pretty complicated to capture ones intended logic - and that's what you are struggling with now, Sjakie. To comfort you I can say that I also code rules in eventscript now and then that behave strange because I haven't really thought trough what I wanted in the first place (and I can assure you that my wife is not very impressed and don't have very high thoughts of my coding skills :-) )
    So I'm impressed by your perseverance, but I also believe that you find a pleasure in crafting your own rules and see they (eventually) being carried out. And I will do my best to support you.
    I said in the beginning that I was hesitant to release it - partly because I was not particularly enthusiastic to end up in a full-time support job. However I misjudged that. The framework have improved a lot with the help of @jompa68, @petrkl12, @FrankT, @3JL, @domin12 that have tried out the framework and built some pretty complex scenes - the bugs they have discovers and the features they have suggested have made it much better that if I have kept it to myself.  Thank you guys!
    Even when people report problems that are not bugs, It gives my something think about. Could I make it clearer, easier or in another way that would avoid these perceived problems? The only problem I have now is that I know that the people mentioned have build some complex scenes that would break if I start to change the syntax/semantics of rules so I try to avoid that.
    And now you are part of the group that are willing to spend time using the framework and give me feedback - and I'm honoured.
    No question is stupid and I always learn something when someone asks why something doesn't work for them or how something can be accomplished. Something I learned and understood is that there is a need for a better introduction to coding rules with eventscript. I mean, it was originally written for myself by myself, and there are of course better ways to do it as an introduction for newcomers, both to the HC2 and to the ER/EventScript. I also think there is a general introduction to what to think about when writing home automation rules that is beyond any specific framework; presence, personalisation, time-of-day pacing, sensors/events/actuators, formalising states with state-machines, fuzzy states, etc. but maybe that book is already written.
    @jgab, Thanks!!
    Some questions:
    What is better system wise to do:
    -for my heater program I have 8 rules working with one GV  if it is heater season yes or no.
    or
    -Rule.eval("@(0509..0505) => stekkerCam:on")  [if this is the correct notation for 5th of Sept  till the 5th of May]
    Rule.eval("gastBeneden:isOff & deurSerre:armed => dwSensorsGastenKamerBeneden:armed=1 ; pirSensorsGastenKamerBeneden:armed=1;log('Armed')")
    what to use for deurSerre:armed ??
    Please advice
    2 hours ago, Sjakie said:
    @jgab, Thanks!!
    Some questions:
    or
    Please advice
    Test if we are between dates are not well supported, I would like to have 05/06/10:00..09/04/10:00, but the support is lacking at the moment.
    You need to do your own check. Two alternatives. The second alternative makes sure you have a local variable 'heatherSeason' that is true or false and that you can test against.
    If you have other scenes that depend on that variable it can be good to also store it in a GV
    The second rule, use '==' for equality test
    My I have whole goodmorning scene please without mistakes.
    I want to apply also too.
    thanks.
    thanks jgab!!
    Will use GV for it no problem.
    hahaha I used:  deurSerre=armed =>   and I was surprised it was arming the door.
    perhaps instead of  == , isArmed? to be consistent or is this to easy thought?
    thanks again!
    Hi guys,
    Raspberry PI 3 , Model B+ i s this acceptable to use with HC2 and simultaneous as NAS?
    Do you have to program a lot on this PI tinny  3.5" screen that perhaps a bigger one is more appreciate 7">
    Please advice
    Hi guys,
    Please advice
    I connect to the pi remotely with a laptop using VNC. I don't think it's worth buying the screen for this use-case.
    I guess you can connect it to a TV set with HDMI and use a ceap USB keyboard if you need to.
    I mainly use the pi for node-red and when that's setup you access node-red over a web GUI from any browser (and I hidden the pi under the sofa...)
    jgab,
    sorry but it does not work.
    door is listed in header of scene value
    I checked door ID
    scene no error messages
    If I take out     & deurSerre:armed==1 the rule will be executed if gastBeneden:isOff
    what I am doing:
    I arm the deurSerre
    I switch gastBeneden off>>>>>>>>>It will arm gastenkamer beneden
    I  switch off gastBeneden
    and I arm the deurSerre  >>nothing happends
    scene is still running
    Did it several times result still the same
    Now I am lost
    Please advice
    37 minutes ago, Sjakie said:
    jgab,
    I checked door ID
    what I am doing:
    I arm the deurSerre
    Now I am lost
    Please advice
    It should be listed as
    or whatever ID your deurSerre have. Have you done that?
    Most devices carry their main value in their "value" property, but additional properties like 'power', 'battery', 'armed' is separate and need separate trigger declarations.
    When you are testing your scenes you can set _debugFlags.rule=true and you will get a log for each rule that gets triggered and true or false if the rules condition was satisfied. That way you can see if the rule triggers when you expect it to and if the condition computed to true or false and thus executed the actions.
    Thanks, done 54 value instead of 54 armed
    debug also done
    thanks agin will test tomorrow family is present
