it' was a zwave fibaro dual switch (fgs223), driven by slave gateway. I wrote wrong id in js line.  Let me know if you need more info.
On 6/16/2020 at 11:17 PM, cag014 said:
@SmartLifeSystems
Please try line below (since I don't know the thermostat real command, I'm using "setPoint" command as an example)
What do you think? Is it what you need or I'm off target?
Thanks your help!
    10 minutes ago, SmartLifeSystems said:
    Thanks your help!
    So it works...
    You're welcome
    1 minute ago, cag014 said:
    Tehát működik ...
    Szívesen
    Yes!!! :)
    cag014 what you think about this line
    {10, "`tlab`",{state="value>25",timeSlot="09:00~21:00",trueAct={{"`climamod`","setMode,2",""},{"`climafan`","setFanMode,4",""},{"`climaset`","setThermostatSetpoint,2,23",""}},falseAct={"`climamod`","setMode,0","","={$24clock:value=21:00}"}}},
    It's meant to check temp every 15 min from 9 to 21, if temp >25 turn on air conditioner, then turnoff at 9pm
    I believe it doesn't work and you receive time out alert after 10 minutes when tlab>25.
    In addition I don't see where you checking temperature every 10 minutes? If I understand correctly tlab is temperature sensor and he reports the temperature changes regardless 10 minutes loop.
    may I suggest to use as follow:
    What it does:
    tlab>25 trueAct{} executed in time slot 09:00~21:00
    tlab<25 falseAct{} executed in time slot 09:00~21:00
    at 21:05 falseAct{} executed
    For reference Time slot formats are:
    22:00~05:00 defines time slot between 22:00 to 05:00 next day.
    21:05~  if only first half of time slot defined then trueAct{} table executed at 21:05
    ~21:05 if only second half of time slot defined then falseAct{} table executed at 21:05
    Edited by cag014
    i'm trying to avoid air conditioner on/off when tlab reports for example 25 degrees.
    {0,"`tlab`",{state="value>25",timeSlot="09:00~21:00,~21:05",trueAct={{"`climamod`","setMode,2",""},{"`climafan`","setFanMode,4",""},{"`climaset`","setThermostatSetpoint,2,23",""},{"`climamod`","setMode,0","","{`tlab`:value<23}"}},falseAct={"`climamod`","setMode,0",""}}},
    What you think of this modified jm line?
     In time slot air conditioner will be switched off only if tlab report <23 and at 21:05
    edited in
    {0,"`tlab`",{state="value>25",timeSlot="09:00~21:00",trueAct={{"`climamod`","setMode,2",""},{"`climafan`","setFanMode,4",""},{"`climaset`","setThermostatSetpoint,2,23",""},{"`climamod`","setMode,0","","{`tlab`:value<23}"},{"`climamod`","setMode,0","","={$24clock:value=21:01}"}}}}
    I' trying to start my sprinkler system every morning at 04:00.
    {0,"$24clock",{state="value=04:00",trueAct={{"`lineadx`","turnOn",""},{"`lineadx`","turnOff","1800"},{"`lineacx`","turnOn","1799"},{"`lineacx`","turnOff","3599"},{"`lineasxt`","turnOn","3598"},{"`lineasxt`","turnOff","5398"},{"`lineasxb`","turnOn","5397"},{"`lineasxb`","turnOff","7197"}}}},
    {0,"`lineadx`|`lineasxt`|`lineasxb`|`lineacx`",{state="value=true",trueAct={"`pompa`","turnOn",""},falseAct={"`pompa`","turnOff","","={`lineadx`:value=false|`lineasxt`:value=false|`lineasxb`:value=false|`lineacx`:value=false}"}}},
    It's not a starndard system cause i have to start a water pump when a sprinkler start.
    so first line is to start a sequence (single sprinkler for 30.min, then the second one). Start of second, third and fourth sprinkler, is one second before the stop of the previous one to avoid water pump off ( falseact of second jm lines).
    On 6/25/2020 at 12:45 PM, gggizmo said:
    edited in
    May I suggest very simple solution (two jM lines)
    {0,"`tlab`",{state="value>25",timeSlot="09:00~21:00",trueAct={{"`climamod`","setMode,2",""},{"`climafan`","setFanMode,4",""},{"`climaset`","setThermostatSetpoint,2,23",""}}}},
    {0,"`tlab`",{state="value<23",timeSlot="21:01~", trueAct={"`climamod`","setMode,0",""}}},
    When temp>25 turn On
    When temp<23 turnOff and at 21:01 always turnOff
    It should work, but based on my experience sometimes the system (HC2) has delays (up to several seconds) , so I wouldn't trust 1 second delay for proper operation.
    You can simplified as following:
    In this scenario no commands run in the background and it's system delays free.
    exactly what i did  except for second jm line
    mine is
    {0,"$24clock",{state="value=21:05",trueAct={{"`climamod`","setMode,0",""}}}},
    this one works too
    {0,"$24clock",{state="value=04:00",trueAct={{"`lineadx`","turnOn",""},{"`lineadx`","turnOff","1800"},{"`lineacx`","turnOn","1770"},{"`lineacx`","turnOff","3570"},{"`lineasxt`","turnOn","3540"},{"`lineasxt`","turnOff","5340"},{"`lineasxb`","turnOn","5310"},{"`lineasxb`","turnOff","7110"}}}},
    30 sec delay...
    thanks, i think i'm just starting to understand logic and syntax of aos.
    hi cag just a few questions:
    i'm wondering how to control some jm lines manually.
    for example sprinkler system. I heve not humidity control so how to disable time cicle for sprinklers without erasing jmline?
    and same for air conditioning or heating.
    may be a global var ( enabled, disabled), ore some simple trick  like a vd that set global vars to enable or disable a single lines?
    You're correct. Use global variables to control jM{} line.
    To control the entire jM{} line use lineState rule (the format exactly the same as conditions) for example:
    Define global gVar. Follow line is active only if gVar = true.
    If gVar <> true the line deactivated
    Another qustion about hue lights...
    {0,"`isoggiorno`",{state="centralSceneSupport=2.Pressed",trueAct={"`piantanaalta`","turnOff;else;turnOn","","{`piantanaalta`:on=true}"}}},
    how to add a second action after else?
    What i need is: turnon and setbrightness to 255, probably i can't find the correct syntax....
    tnx
    As far as I know brightness command could be sent any time regardless On/Off, right?
    My suggestion is to send the command on every button press.
    {0,"`isoggiorno`",{state="centralSceneSupport=2.Pressed",trueAct={"`piantanaalta`","setbrightness,255,""},{"`piantanaalta`","turnOff;else;turnOn","","{`piantanaalta`:on=true}"}}}},
    /monthly_2020_07/image.png.15d2016ba19eea268a9f34422ebcd036.png" />
    why?, changeBrightness it's an available lua command for fibaro hue plugin...
    Are you sure ID 818 is Hue Light?
    Looks like this is a thermostat, and available actions for devices are
    setMode, setFan, setThermostatSetpoint.
    same behavior with every hue lights in system...on init i get setMode, setFan, setThermostatSetpoint. as permitted actions.
    just to give you more infos
