    Just to clarify - any button pressed on remote should change the light state (if off turn on and vice versa)
    What remote control you have?
    yep.
    This is just th sipmler remote i have at home.
    sorry, i haven't read the second question: it's a popp wall controller
    Edited by gggizmo
    Please add follow line to your jM{} array
    Let me know if it works...
    BTW I suggest not to use device numbers in action lines. If from some reason your device ID has changed, it will be a hard working process to update the numbers in the lines.
    You can define alias names for the devices in jS2n{} table
    For example:
    jS2n={keyFob=911,light=494}
    Now your line will look like (alias names must be included within back apostrophes)
    If your device ID changed , you need to changed the ID in jS2n{} table and that's all.
    Also in the future if you'll decide to switch to HC3, you will need redefine IDs in jS2n{} table only, everything else will work.
    yep, It's working. And yes i'm popolating js line with readable name. I'm just starting with aos and it's not totally clear to me the logic of conditional statement, concatenation.
    ex. {0, "`mingresso`|`pingresso`",{state="value=true",timeSlot="16:00~08:00",trueAct={{"`corridoio`","turnOn",""},{"`corridoio`","turnOff","40"}}} means that if mingresso or pingresso are breached lights turn on?
    But reading manual or lurking the forum | means "and", "or" state of two or more devices is {},{}., so i'm really confused
    Yes, if mingresso or pingresso breached (any one of them) then state="value=true" is TRUE and  trueAct{} array executed . in your case turnOn and turnOff after 40 seconds.
    This line will be broke down into two lines, please see the table in debug window.
    You can see in the table every command and when/how it will be executed
    Hi cag!
    I have a question for you. Can you help me?
    How can i add this state?: the temp sensor value > radiator thermostat, trueAct...
    Thanks!
    The format to use any property of any device as follow:
    @"devID">"propertyName"
    For example:
    Temp Sensor ID= 400,  temp. property name is value
    Radiator thermostat = 500,  thermostat property name is value
    state="@400>value>@500>value"
    Of course you can use alias names also
    state="@`tSensor`>value>@`radiator`>value"
    By the way if you need any calibration/compensation you can use formula too.
    state="@400>value+1>@500>value"
    Edited by cag014
    Nice! Thank you!
    I have got an another question. I have got Fibaro FGT-001 thermostathead. How can i programing, if i want set up a scedule. Example, the head seting up 22 C degree, and i want this device set up 24 C degres for 15 mins, and after set up the original value.
    sorry cag i can't get this lua scene working. I can't get state of hue light via hue plugin to switch on-off a lamp.
    %% autostart
    %% properties
    %% weather
    %% events
    926 CentralSceneEvent 2 Pressed
    %% globals
    if (
     ( (startSource["type"] == "event" and startSource["event"]["type"] == "CentralSceneEvent") )
    or
    then
        local deviceValue1 = tonumber(fibaro:getValue(818, "on"));
        if (deviceValue1 > 0) then
            fibaro:call(818, "turnOff");
        else
        fibaro:call(818, "changeBrightness", 254);
        fibaro:call(818, "turnOn");
    @gggizmo
    Try above..
    11 hours ago, SmartLifeSystems said:
    Nice! Thank you!
    Set 24 C for 15 minutes at any specific timeslot?
    I mean when to set for 15 minutes?
    nope.../opt/fibaro/scenes/103.lua.447: attempt to index a nil value....
    i'm going crazy trying simply to turn off and on hue lights.
    42 minutes ago, cag014 said:
    @gggizmo
    Próbálja ki fent ..
    Állítsa be a 24 C-ot 15 percre bármilyen meghatározott időrésben?
    Úgy értem, mikor kell beállítani 15 percet?
    When the temp sensor < thermostat head.
    Please  post line 447
    @gggizmo
    Please try line below
    I don't have Hue lights, but have installed Hue plugin and I don't see changeBrightness action in device property!?
    Available actions are:
    3 hours ago, cag014 said:
    @gggizmo
    Try above..
    My plan is that: When the temp sens value less then the thermostat head, the boiler turn on, and the thermostat head set ex. 24 C for 15 min. After the thermostat head set the original value. My values only examples.
    Do you understand, what i want?
    Why 15 minutes? just keep boiler on till temp sense value equal or greater to thermostat head.
    Any how I'll post the solution.
    Because i want a little boost the hot water circulation. The radiators earlier warming up, and sooner get the set temperature.
    What do you think about this?
    I think It depends how cold it is and how fast you want to reach desire temperature.
    For example if temp sense drop several degrees below, is 15 minutes is enough for your needs?
    The 15 min is an example. But while the desire temperature not true, the 15 min  will restart.
    Or have you got a better idea this?
