20 hours ago, cag014 said:
@SmartLifeSystems
I'm curious, is it works?
{0, "108",{state="value=true#4",timeSlot="21:30~?$sunriseHour+1800?",trueAct={{"91","turnOn","{138:value=0}"},{"91","turnOff","90"}}}},
Hi cag,
I tried, but unfortunately don't working. :(
    What exactly doesn't work?
    Don't turn on the lamp. I tried without #4, and don't work absolute.
    Thanks, will fix it
    Did you do it in correct time-slot between 21:30~?$sunriseHour+1800?"
    TO debug it, please try that:
    {0, "108",{state="value=true#4",trueAct={{"91","turnOn","{138:value=0}"},{"91","turnOff","90"}}}},
    Edited by cag014
    Hi cag,
    I tried without the timslot, but don't working.
    I tried without the timeslot and the state delay too, and nothing. The lamp don't turn on.
    hi cag014,
    {0,"&consdoor",{state="value=open",trueAct={"`stat`","setTargetLevel,&mintemp","600"}}},
    {0,"&consdoor",{state="value=closed",trueAct={"`stat`","setTargetLevel,&settemp",""}}},
    consdoor is a global variable in which i store the conservatory door state if this door is open for ten minutes i wish to turn the heating thermostat down to a global called mintemp
    when the door is closed i return the thermostat to what it was set to before the door was opened (settemp)
    would the lines above work? and i am sure you have a much better way of achieving this :)
    second question:-
    if the conservatory door is closed during the ten minute wait time will it just cancel the timer?
    Len
    8 hours ago, SmartLifeSystems said:
    Hi cag,
    Do you use this exact line?
    {0, "108",{state="value=true#4",trueAct={{"91","turnOn","{138:value=true}"},{"91","turnOff","90"}}}},
    There is format error (my bad)
    Please try
    {0, "108",{state="value=true#4",trueAct={{"91","turnOn","","{138:value=true}"},{"91","turnOff","90"}}}},
    Sorry
    4 hours ago, magicman said:
    hi cag014,
    second question:-
    Len
    1. Yes,it should work.
    2. No, it won't cancel the timer. May I suggest as follow
    {0,"&consdoor",{state="value=open",trueAct={"`stat`","setTargetLevel,&mintemp","600"},falseAct={"`stat`","setTargetLevel,&settemp",""}}},
    Now if the door closed, truAct{} cancelled and falseAct{} executed
    Edited by cag014
    wonderful thanks cag014
    Please try
    Sorry
    Hi cag!
    I tried, but unfortunatley don't working. :(
    Looks like an issue with Home Theater  status!?
    Try without
    {0, "108",{state="value=true#4",trueAct={{"91","turnOn",""},{"91","turnOff","90"}}}},
    Try without
    That's working fine.
    Currently i use it this way:
    {0, "108",{state="value=true#4",timeSlot="21:30~?$sunriseHour+1800?",trueAct={"91","turnOn",""},falseAct={"91","turnOff","90"}}},
    OK,
    Now can you tell me what Home Theater value when it is off?
    Or post the device data  http://hc2/api/devices/<HT-ID> when it's OFF and when it's ON.
    23 minutes ago, cag014 said:
    OK,
    This device is a wall plug.
    Another scene, where is use, the value parameters when turn off = 0, when turn on = true.
    Here is the device link:
    Looks like when value=true the switch is ON.
    My question, do you actually using switch to turn ON/OFF Home Theater ? The reason I'm asking, because in my case the switch is constantly ON and Home Theater activated by remote control. I use energy value as condition.
    By the way try follow:
    {0, "108",{state="value=true#4",trueAct={{"91","turnOn","","{138:value=false}"},{"91","turnOff","90"}}}},
    OMG. That's working fine!
    Thank you very much!!!!
    I add the time slot too, and working too.
    Great...
    Great...
    Thank you again your help!!!
