20 minutes ago, cag014 said:
But if your sensor configured go to safe after breach in 30 seconds, it means the sensor will stay breached for 30 seconds always! So the light will turn ON anyway.
Could you check and post your configuration?
Something like that
You're the king! Very good work!
Thanks!
{0, "108",{state="value=true#15",timeSlot="21:30~06:00",trueAct={"91","setValue,50",""},falseAct={"91","setValue,0","10"}}},
Working very well! Thank you!
    OK.. so it is Fibaro sensor. (As an example I posted Aeon Lab sensor)
    Please post parameter 6
    In my case is set to 30 seconds.
    Edited by cag014
    @SmartLifeSystems
    You're welcome...
    hi cag014
    i know the third condition is the delay time as in {"`light`","turnOn","50"} but how do i set a global variable after 30 seconds as in                 {0,"`frontdoor`",{state="value=true",trueAct={"housestatus","setGlobal",armed"}     but i dont want the global (housestatus)  to be set for 30 seconds so the area is clear before arming. hope that makes sense
     {"housestatus","setGlobal","~30~armed"}
    for commands where third parameter uses for data add number in seconds within ~XX~ as prefix
    wonderful thank you again
    hi cag014,
    Can i use two properties at the beginning of a JM{} line e.g.    {0,"`frontdoor`"="value=true" and "&housestatus"=value=armed",trueAct={...............}
    is it simply  {0,"`frontdoor`"="value=true"|"&housestatus"=value=armed",trueAct={...............}  ?
    Len
    No.
    you can use one of them as condition in trueAct()
    {0,"`frontdoor`",{state="value=true",trueAct={"xx","xxx","x","{&housestatus:value=armed}"}}},
    To all users:
    Please download
    to enjoy "big" screen view.
    Going forward this application will serve as UI for All-in-One Scene on HC3.  (No HTML support on HC3)
    I hope to release All-in-One Scene version for HC3. It will make migration from HC2  less painful  and will speed up HC3 opertaion.
    hi cag014,
    the JM{} line below:
    {0,"`frontdoor`",{state="value=true",trueAct={{"`strobe`","turnOn",""},"housestatus","setGlobal","armed",{`strobe`","turnOff","30","{&alarmstatus:value=armed}"}}}},
    does the condition &alarmstatus:value=armed relate to just the {`strobe`","turnOff","30"} ? or the whole line, it appears that the first actions happen regardless of the condition?
    thanks Len
    hi cag014,
    {0,"`frontdoor`",{state="value=true",trueAct={{"`strobe`","turnOn",""},{"housestatus","setGlobal","armed",{`strobe`","turnOff","30","{&alarmstatus:value=armed}"}}}},
    thanks Len
    **** corrected typo ****
    Yes, each condition related to the command where it is defined.In your case the condition is for {`strobe`","turnOff","30"} only
    If you want to set condition for entire line (for all action trueAct, falseAct,....) define lineState as follow:
    {0,"`frontdoor`",{state="value=true", lineState = {"{&alarmstatus:value=armed}"},trueAct={{"`strobe`","turnOn",""},{"housestatus","setGlobal","armed"},{`strobe`","turnOff","30"}}}},
    In this case any action will be done only if lineState is true (and off course state ="value=true" is true also)
    Note:
     lineState syntax is the same as in conditions
    As always perfect answer. Also using webeye to display , looks very good
    thank you cag014
    You're welcome.
    By the way in webEye to refresh the table press "Start".
    "Reload" button just reloads the debug window, while "Start" acts like Refresh button in scene.
    hi Cag014
    spoke to soon ..cant get webeye to work again now :(
    keeps giving me the message
    cross origin request blocked , im using firefox and have the extension added?
    Len
    Yes, probably you have updated to version 74.xxx
    Please refer to
    hi Cag014,
    is it possible to change the value of a local variable within AOS from outside of the AOS scene itself?
    eg if i have a local variable within AOS scene called housestatus can its value be changed using another scene?
    Thanks Len
    No... HC2 scenes doesn't support that, but you can set housestatus as system global variable in no time.
    Define global variable housestatus and delete it from AOS local variable.
    No other changes required and it should work as usual.
    Thank you cag014 i had already tried that and found it to work but just wondered if it was possible so as to keep even more inside the AOS, but thank you for answering
    Len
    Hi cag014!
    Can you help me? I have got a keyfob. Example if i press the first button 3 times, the keyfob doing the first and secound action too.
    What is the correctly settings?
    Here is my parameters:
    {0, "140",{state="centralSceneSupport==1.Pressed",trueAct={{"142","pressButton,3",""},{"138","turnOn",""},{"TV:","sendPush","A TV bekapcsolva."}}}},
    {0, "140",{state="centralSceneSupport==1.Pressed2",trueAct={{"138","turnOff","2"},{"TV:","sendPush","A TV kikapcsolva."}}}},
    {0, "140",{state="centralSceneSupport==1.Pressed3",timeSlot="$sunsetHour~$sunriseHour",trueAct={{"142","pressButton,37",""},{"91","setValue,30",""}}}},
    Thanks!
    What type of keyfob you have?
    Keyfob should send how many times button pressed and not to send every press...
    Might be some configuration required....
