Thank you Cag04 works perfectly, i had tried trueAct=("26","startProgram","5","") and now see why it did not work.
hi cag014,
How can i monitor the state of my alarm system (Armed /disarmed?). i have to check the state of a door i know that as in `side`:value=armed but how do i get AOS to check this for me ? do i set a global variable ?
thanks Len
    like this
    See an example in
    Let me know if it helps
    Edited by cag014
    yes i got that but that involves the front door being opened to check dosent it? can it be monitored without opening any doors?
    Thanks Len
    Yes, but do you need to perform any action when it armed/disarmed or as a condition to other action?
    If you need to monitor the state and perform actions then it just a standard jM line:
    {0,"`fronDoor`",{state="armed=true",trueAct={....},falseAct={....}}},
    when i am away from home i used to check whether the alarm was armed or disarmed with a scene then a popup would tell me what the state of the alarm was. If i had not armed it i could arm it using a fibaro widget on my phone.
    hope that makes sense?
    Len
    Yes,
    So the jM line I posted suits your needs, right?
    hi cag014,
    me again :)
    i wish to set a global variable TOD at sunrise to light and at (sunset - one hour) to dark how do i do that?
    Len
    It could be done in several option.
    I suggest to create blank keyword name "$timer" and use it for any time-based actions executions.
    So,
    define new keyword in
    userKeyWord={{"$timer","$HC2onLine","$dayTime"},
    {"",function() return tostring(api.get("/settings/info")["online"]) end,
     function() return  os.date("*t",os_time()).hour<6 and "Good night," or os.date("*t",os_time()).hour<12 and "Good morning," or os.date("*t",os_time()).hour<18 and "Good afternoon," or os.date("*t",os_time()).hour<=23 and "Good evening," end }}
    Now add new line to jM{}
     {0,"$timer",{timeSlot="$sunriseHour~,?$sunsetHour-3600?~",
          trueAct={{"TOD","setGlobal","Light","{$24clock:value=$sunriseHour}"},{"TOD","setGlobal","Dark","{$24clock:value=?$sunsetHour-3600?}"}}}},
    in future just add more and more actions
    So,
    as always perfect!
    thanks a lot
    hi CAG014,
    how do i add a line to JM{} to interrogate the contents of a global variable TOD and act on its value? the result will be a string
    thanks
    Len
    (0,"&TOD",{state="value=<str_vallue>",trueAct={..},falseAct={...}, tirgAct={..}}},
    add any needed action...
    hi Cag014,
    trying to use the global TOD in the line below get an error message
    [DEBUG] 20:10:07: 2020-02-21 20:10:07.516380 [ fatal] Unknown exception: /opt/fibaro/scenes/405.lua:54: unexpected symbol near '}'
    the line i used is:-
    0,"&TOD",{state="value=<dark>",trueAct={"message","setGlobal","Global variable is dark ",}}},
    if i remove the line all is ok so know its my fault somewhere on this line!
    i checked the TOD global and it is set to dark
    sorry CAG014 i have sorted it out it was my typo thank you for your time
    hi Cag014
    just writing my house alarm scene to add to AOS, how do i reproduce sleep(50) in a JM{} line.
    eg
    fibaro:call(50,"turnOn")
    fibaro:sleep(50)
    fibaro:call(50,"turnOff)
    Len
    this is the 3rd parameter in commands.
    By the way the value should be in seconds.
    Edited by cag014
    fantastic thanks
    hi cag014,
    i want to set a global variable when (a= true and b=true and c= false) how do i code that please?
    the scenario is needed to check that door a is shut,door b is shut , and roller shutter door c is in correct position before arming alarm,
    Len
    Like that
    In addition if you're using this condition a lot, you can set them as a group in
    Edited by cag014
    hi cag014,
    does this equate to a= true,b=true,c=false? or does this say a,b,c are all false?
    Len
