    3 hours ago, magicman said:
    hi cag014,
    does this equate to a= true,b=true,c=false? or does this say a,b,c are all false?
    Len
    All =false
    4 hours ago, magicman said:
    he scenario is needed to check that door a is shut,door b is shut , and roller shutter door c is in correct position before arming alarm,
    door shut/close value=false (for sensors true is breached)
    In any case you can set every condition combination you need
    conditions separated by "I" means and
    trueAct={"gName","setGlobal","gValue","{`a`,`b`:value=true|`c`:value=false}"}, -- if a==true and b==true and c==false then  setGloabl....
    any condition in separated curled brackets means or
    trueAct={"gName","setGlobal","gValue","{`a`,`b`:value=true}{`c`:value=false}"}, -- if a==true and b==true or c==false  then setGlobal...
    Edited by cag014
    Thanks cag014 as always well explained
    Hi!
    Can somebody help me?
    How can i set up this?:
    When my Sony TV (VD, ID=67) press button on, then the living room lights (ID86, ID91) turn off, and reverse. When TV press button off, then the light turn on 40%.
    Thank you!
    First of all as I understand you're probably using Sony plugin, is it correct? Since On/Off is toggle action,  how do you know if TV is ON or OFF?
    Could be that someone turned TV ON or OFF by remote control.
    Yes, i using the Sony plug in, but not problem, if the scene only play, when i use the plugin.
    Unfortunately, Sony plugin doesn't report any activity  when button pressed.
    It could be done by connecting TV using Z-wave wall plug . Actions could be executed according to power consumption
    Thanks!
    hi Cag014,
    hi how can i trigger JM{} when the fibaro alarm is activated as in an alarmed door is breached .
    thanks
    Len
    Fibaro alarm is not a device and actions taken in the system, but there are some workarounds:
    1. You can define to turn on/off some device in case of alarm and monitor it.
    2. Every sensor has "fibaroAlarm" property and if alarm activated it set to true and could be monitored as well
    On second thought, you gave an excellent idea. To monitor events which not related to devices/scenes/VD.
    Will be ready in next  release... so if you can await a while, you'll have an option to do it.
    Edited by cag014
    Hi cag014!
    How can i set up, when the motion sensor is breached more than ex. 15sec., then the lamp is turn on, and less then 15sec. no.?
    Thanks! This scene is very good, nice job. Only i need learning use. :)
    thanks cag014 but did need to do it now. i will see if i can come up with a workaround, but do look forward to a new release ;)
    Len
    How many sensor are part of your Alarm?
    just the four doors in this instance `frontdoor` , `sidedoor`,consdoor`,`garagedoor` the motions sensor are not armed due to dogs being in the house but in full arm they could be, but just for now the doors
    thanks
    Len
    13 minutes ago, SmartLifeSystems said:
    Hi cag014!
    Interesting situation, may I ask what is delay time of your sensor to go back to safe after breach? ( Usually it has a range of 30-60 seconds).
    In case you sensor
    As I understand you need to turn lamp ON after 15 sec. when sensor breached.
    In case you sensor
    No. Only turn on, if the breached it goes on for 15sec. This sensor is in bedroom, and now, if i turn back in the bed, the lamp is turn on. But i want ex. drink something in the kitchen, it turns the lights on only if the sensor is breached for 15sec.
    Do you understand what i want?
    If the sensor breached for only (example) 5 sec., not turns on the light. :)
    Another question, are they already embedded in jM{} table, where state  is value=true.
    In this case you can on the same line add an action with condition of fibaroAlarm=true.
    If not you can add this line
    It will cost extra 4 lines in jM{} that's all.
    But I'm working on HTML interface that you will see the table in browser and not in small debug window only, so going further quantity of lines doesn't matter.
    thanks cag014 will try it later and let you know the results
    But if your sensor configured go to safe after breach in 30 seconds, it means the sensor will stay breached for 30 seconds always! So the light will turn ON anyway.
    Could you check and post your configuration?
    Something like that
    Anyhow, here is the line. Please change 300 (sensor) and 400 (lamp) to your real device ID
    You've provided condition when to turn lamp On, but what is the  condition to turn the lamp Off?
    I mean in case sensor breached over 15 seconds, lamp turned ON, when to turn it OFF?
    Edited by cag014
    Something like that
