On 4/7/2020 at 11:29 PM, cag014 said:
Yes... but the format slightly different.. without OR
lineState={"{&housestatus:value=safe}{&notifications:value=on}"}
If you need AND condition separate statements by |
lineState={"{&housestatus:value=safe|&notifications:value=on}"}
Hi Cag!
Can you help me?
What do you think? This is correct?
{0, "148|193",{lineState={"{148:value>0}{193:value>0}"},trueAct={"199","turnOn",""}}},
{0, "148|193",{lineState={"{148:value=0|193:value=0}"},trueAct={"199","turnOff",""}}},
Because don't working and i don't know what is the problem.
Thanks your answer!
Edited by SmartLifeSystems
    You're missing the state to determine when the status is true in order to verify the conditions and to take true-action?
    There are several options to trigger the line, here two of them:
    1. Replace trueAct by trigAct. Means every change on value of device the line is triggered and if conditions are true, trigAct executed.
      • {0, "148|193",{lineState={"{148:value>0}{193:value>0}"},trigAct={"199","turnOn",""}}},
      • {0, "148|193",{lineState={"{148:value=0|193:value=0}"},trigAct={"199","turnOff",""}}},
    2. Define state and use trueAct and falseAct commands (with conditions):
      • {0, "148|193",{state="value>0", trueAct={"199","turnOn",""}, falseAct("199","turnOff","","{148,149:value=0}"}}},
    I suggest to use second option (more readable and less lines in table view). Let me know if it works for you?
    BTW:
    Devices with same condition statement could be concatenated, separated by comma ‘ , ’
    {0, "148|193",{lineState={"{148,193:value=0}"},trigAct={"199","turnOff",""}}},
    BTW:
    Thanks for your help!
    This combo working fine.
    But it's interesting at the turnOff function that i had to write 0 to false.
    hi cag014,
    i have a line:
    {0,"`frontdoor`",{state="value=true",lineState={"{&housestatus:value=safe|&notifications:value=on}"},initOnStartup=false,trueAct={{"doorstate","setGlobal","open"},{"Front door accessed. ","sendPopup","Front"},{"keydata","setGlobal","d99761eacfdf4276b5f39146a7fb5641"},{"`strobe`","turnOn",""},{"`strobe`","turnOff","5"}},falseAct={"`strobe`","turnOff",""}}},--front door opened
    works perfectly but would like to add the time and date onto "Front door accessed. ", i tried "Front door accessed. "..date(), but not working can you help please?
    thanks Len
    Attached file shows all time-date available keywords. (marked by red line)
    Please use one of them as you need (below an example to set full time-date format use $osDate)
    {0,"`frontdoor`",{state="value=true",lineState={"{&housestatus:value=safe|&notifications:value=on}"},initOnStartup=false,trueAct={{"doorstate","setGlobal","open"},{"Front door accessed $osDate","sendPopup","Front"},{"keydata","setGlobal","d99761eacfdf4276b5f39146a7fb5641"},{"`strobe`","turnOn",""},{"`strobe`","turnOff","5"}},falseAct={"`strobe`","turnOff",""}}},--front door opened
    You can use any other keyword or combination of keywords to create needed time-date format.
    For example:
    $day $month $24clock - 11 4 22:16
    $day $mName $12clock - 11 Apr 11:16pm
    Edited by cag014
    ty cag014
    perfect as always
    Hi cag!
    Can you help me again? :)
    How can i set up this?
    If 108 value=true#4 and 138=0 and timeslot=21:30~sunrisehour then 91 turn on, and tur off after 90 sec.
    I tried this, but doesn't work.
    {0, "108|138",{lineState={"{108:value=true#4|138:value=0}"},timeSlot="21:30~?$sunriseHour+1800?",trueAct={"91","turnOn",""},falseAct={"91","turnOff","90"}}}
    Thank you!
    The lineState sets condition for all actions in line therefore is doesn't make sense that trueAct and falseAct will have same condition.
    So in this case trueAct should execute both actions trueAct={{"91","turnOn",""},{"91","turnOff","90"}}
    Since state is not defined there is no trigger to execute the line and you should use trigAct (means on every value change trigger the line)
    At the end...
    {0, "108|138",{lineState={"{108:value=true#4|138:value=0}"},timeSlot="21:30~?$sunriseHour+1800?",trigAct={{"91","turnOn",""},{"91","turnOff","90"}}}},
    At the end...
    Hi cag,
    I tried without #4, and working. Have you got any idea?
    Ops, my bad... the hash sign # sets state delay.
    Will try to provide workaround if you must have #4
    let me know
    Edited by cag014
    No no no. Not your bad, i want use the state delay, but only at 108 device.
    To use delay, you must to define state.
    Break it into two lines:
    {0, "108",{state="value=true#4",timeSlot="21:30~?$sunriseHour+1800?",trueAct={"91","turnOn",""},falseAct={"91","turnOff","90","{138:value=1}"}}}
    {0, "138",{state="value=0",timeSlot="21:30~?$sunriseHour+1800?",trueAct={"91","turnOn",""},falseAct={"91","turnOff","90","{108:value=false}"}}}
    Please verify if the condition for falseAct{} is correct?
    Edited by cag014
    Hi @cag014,
    How to deal with HUE? Could not find in the text here.
    Is this okay?
    --========================== USER CONFIGURABLE PARAMETERS ===============================
    jS2n={deur=233, doucheDeur=235, doucheDeurTemp=236, dakraam=239, dakraamtemp=240, bewegingssensor=243,bewegingssensortemp=244,luxsensor=245, humidity=246,}
    jS2n={badkamer="233|,|235|,|236|,|239|,|240|,|243|,|244|,|245|,|246|'deur'|'doucheDeur'|'doucheDeurTemp'|'dakraam'|'dakraamtemp'|'bewegingssensor'|'bewegingssensortemp'|'luxsensor'|'humidity'"}
    Or should it be one ine, if I do that it will generate error.
    How much ram/cpu usage if house is complete on AIO scene? Around 130 devices I gues.
    Please advice,
    //Sjakie
    sorry ine read as line
    What do you mean exactly? How can I do that?
    @Sjakie
    Define as follow:
    S2n={deur=233, doucheDeur=235, doucheDeurTemp=236, dakraam=239, dakraamtemp=240, bewegingssensor=243, bewegingssensortemp=244, luxsensor=245, humidity=246, badkamer="'deur'|'doucheDeur'|'doucheDeurTemp'|'dakraam'|'dakraamtemp'|'bewegingssensor'|'bewegingssensortemp'|'luxsensor'|'humidity'"}
    Pay attention, you can use badkamer definition as devices list only. It cannot be used in conditions.
    (0,"`badkamer`",(state="...", trueAct={"`badkamer`",...} and so on..
    No issues with RAM or CPU.
    Edited by cag014
    Hi @cag014,
    Yep no problem
    S2n={deur=233, ...........
    badkamer="'deur'|'........
    J2Sn={deur=250......
    woonkamer=deur.........................
    and so one
    Can it be done on this way?
    What about HUE? Must we use Sankotronics VD?
    Please advice,
    //Sjakie
    No,
    jS2n={deur=233, ...........
    At this point you're defining j2Sn again, so all previous data is gone.
    J2Sn={deur=250......,
    woonkamer=deur.........................}
    It must be same line.
    S2n={deur=233, ...........,
    badkamer="'deur'|'........,
    deur=250......
    Like that: (one line)
    Edited by cag014
    Ok
    Hue please?
    All my rooms are equiped with He
    4 minutes ago, Sjakie said:
    Ok
    Hue please?
    Do you use HUE plugin?
    How you're currently using this in your HC2? Is it VD?
    Can you post an example of HUE commands that you're using?
    In general you should be able to use same commands in All-in-One also, but let see...
    Edited by cag014
    Nope I have VD Sankotronic
    Should be VD on or Off
    Problem now is fa
    toiletDoor= Open + Hue= on >>>fan: on
    can that be done in AIOS?
    Please advice,
    //Sjakie
    sorry I can off course install HUE pluggin
