    Glade to hear it
    Is it works for you?
    let me know if you need any help
    hi Cag014,
    Not sure if this possible in AOS, I work away from home a lot and link remotely via fibaro remote to my HC2, if the HC2 has lost connection to the internet for any reason I have no control.
    what i was hoping is there was some way the HC2 could be rebooted if AOS senses this connection is lost?
    Len (MagicMan)
    Yes it could be done
    I believe you've kept $HC2onLine default action-line  from download, so please add state delay and reboot command in this line
    {0, "$HC2onLine",{state="value=true#15",trueAct={"","tts","$dayTime, Home center is on line"},falseAct={{"","reboot","","{$internet:value=online}",false},{"","tts","$dayTime, Home center is off line"})}},
    The idea is when HC2 is off line, wait 15 sec.  (to prevent spikes in connection)  and if HC2 is still off line and Internet connection is OK (no sense to reboot if no internet) then reboot the system.
    You can change/remove the delay or internet connection condition. See example below w/o delay and internet condition:
    {0, "$HC2onLine",{state="value=true",trueAct={"","tts","$dayTime, Home center is on line"},falseAct={{"","reboot","",false},{"","tts","$dayTime, Home center is off line"})}},
    The false statement in reboot command is to prevent reboot on scene startup (to avoid reboot loop in case HC2 needs few seconds to be connected to fibaro remote at startup and scene is already activated)
    Edited by cag014
    sorry Cag014 am i looking at this wrongly? If the hc2 is offline how can it run the AOS scene to complete this action?
    Len (MagicMan)
    What do you mean? All-in-One Scene runs on HC2, it doesn't need internet to perform reboot.
    It runs internally on HC2 always....
    $HC2onLine is a keyword value that gets from HC2 internal status.
    Just to clarify it a little bit more:
    For example if you have a scene that turns lights ON when motion sensor breached.
    You agree that the scene will run when you don't have internet or fibaro remotes access.
    Same for All-in-One Scene...
    Edited by cag014
    yes Cag014 i see that but i am talking about when my HC2 "freezes" for a choice of a better word and i have to physically reset it.
    can it still reboot then using the scene ?
    OK. so it's not an internet, your system freeze!
    When the system freeze the reboot action could take a very long time...
    I suggest to investigate and to try to fix it... is doable.
    As a first step, please download
      to check if your devices "bombarding" zwave communication (in many cases this is the root cause) and to set better configuration of the devices .
    Please refer to
    Edited by cag014
    hi Cag014.
    i am asking about the vacation function,
    {0,"$timer",{timeSlot="6:00~9:00""},trueAct={{"`stat`","setTargetLevel,&maxtemp",""},{"settemp","setGlobal","22"}}}},
    In the above line i would like to setTargetLevel,&mintemp when vacation mode selected but setTargetLevel,&maxtemp when not
    Len
    Please use keyword $homeMode
    $homeMode has two value Home or Vacation
    There are two options to use it as condition
    1. Set same command with different condition
    2. Use ;else; statement for condition
    I recommend to use second option. Easier to "read" and to modify.
    Let me know if you've any issue with that
    hi cag014,
    {0,"$timer",{timeSlot="6:00~9:00"},trueAct={{"`stat`","setTargetLevel,&maxtemp;else;setTargetLevel,&mintemp","","{$homeMode:value=Home}"},{"settemp","setGlobal","22"}}}},
    get an error message  with line as is but if i remove } at end of this line {0,"$timer",{timeSlot="6:00~9:00"} < and put this it runs is that ok?
    {0,"$timer",{timeSlot="6:00~9:00",trueAct={{"`stat`","setTargetLevel,&maxtemp;else;setTargetLevel,&mintemp","","{$homeMode:value=Home}"},{"settemp","setGlobal","22"}}}},
    Also how to i set keyword $homeMode to home or away?
    Yes, this is OK...  looks like too much }}}..
    To set $homeMode to "Vacation" - use command  {"","vacOn","<delay>") set back to "Home" use {"","vacOff","<delay>")
    But please pay attention that:
    By default, at vacation mode time span ignored. All line with Z-wave devices, global and keyword variables are converted to Activities (to keep your home running, without timeout alerts). Triggered scenes and Virtual devices monitoring is suspended. No changes on auto scenes.
    To override default mode, you can define vacation parameter as following:
    a) normal - keeps line's normal behavior during vacation. 20,”435|678”,{state=”power>5”,vacation=”normal”} }
    b) stop – suspend/disable the entire line.
    If you need to just to change the line that we working on, I suggest to use scene's variable.
    hi cag014,
    {"","vacOn","<delay>"}
    what is the <delay> for?
    thanks
    Len
    Almost in all commands the third field is delay to execute (same as in block scene)
    For example:
    trueAct=("400","turnOn","20"}  -  turnOn device 400 after 20 seconds
    Same for vacation mode
    trueAct={"","vacOn","20"} - set vacation after 20 seconds (in case you need to arm sensors and to get out from home)
    If you don't need any delay leave it blank
    trueAct={"",vacOn",""}
    • 3 weeks later...
    Hi!
    Sorry for the beginners question, but I just can't figure out, how to set an action that is executed every 10 minutes, without any criteria.
    Basically I would like to press a virtual device's button every 10 minutes:
    {"170","pressButton,9",""}
    but can not figure out the hows...
    Thanks in advance for the help!
    Since there is no device state involved, the solution is to use $timeLoop "dummy" keyword and timeLoopAct{} action.
    Please add follow line to yours jM{} array
    jM={
    {10,"$timeLoop",{timeLoopAct={"170","pressButton,9",""}}},
    jM={
    Thanks, works as expected! :)
    Will AOS work on a HC3?
    Yes it will.
    Working on new alarm concept in HC3...
    I believe first version will be released next week
    Hi, i'm new on the forum, and i'm tring to move a lot of lua and magic scenes to aos. Maybe you can help me:
    I'tring to transfer on aos a scene:
    %% autostart
    %% properties
    %% weather
    %% events
    911 CentralSceneEvent 1 Pressed
    911 CentralSceneEvent 2 Pressed
    911 CentralSceneEvent 3 Pressed
    911 CentralSceneEvent 4 Pressed
    %% globals
    if (
     ( (startSource["type"] == "event" and startSource["event"]["type"] == "CentralSceneEvent")  or  (startSource["type"] == "event" and startSource["event"]["type"] == "CentralSceneEvent")  or  (startSource["type"] == "event" and startSource["event"]["type"] == "CentralSceneEvent")  or  (startSource["type"] == "event" and startSource["event"]["type"] == "CentralSceneEvent") )
    or
    then
        local deviceValue1 = tonumber(fibaro:getValue(494, "value"));
        if (deviceValue1 > 0) then
            fibaro:call(494, "turnOff");
        else
            fibaro:call(494, "setValue", "100");
    I't used to control hue light by a wall remote...any hint?
