17 minutes ago, cag014 said:
No,
jS2n={deur=233, ...........
badkamer="'deur'|'........
At this point you're defining j2Sn again, so all previous data is gone.
J2Sn={deur=250......,
woonkamer=deur.........................}
It must be same line.
S2n={deur=233, ...........,
badkamer="'deur'|'........,
deur=250......
{0, "108",{state="value=true#4",timeSlot="21:30~?$sunriseHour+1800?",trueAct={"91","turnOn",""},falseAct={"91","turnOff","90","{138:value=1}"}}}
{0, "138",{state="value=0",timeSlot="21:30~?$sunriseHour+1800?",trueAct={"91","turnOn",""},falseAct={"91","turnOff","90","{108:value=false}"}}}
Please verify if the condition for falseAct{} is correct?
I tried, but doesn't work correctly.
That i want: the 108=MS in the bedroom. The 138=Home Theater. The 91=Lamp. If the HT is off and the MS breaching for 4 sec, the Lamp should turn on, and turn off after 90 sec. But if the HT is on, it shouldn't turn On the Lamp.
Do you understand? :)
Edited by SmartLifeSystems
    13 minutes ago, Sjakie said:
    Nope I have VD Sankotronic
    Should be VD on or Off
    Problem now is fa
    toiletDoor= Open + Hue= on >>>fan: on
    can that be done in AIOS?
    Please advice,
    //Sjakie
    sorry I can off course install HUE pluggin
    HUE plugin has default acions:
    setMute - have no idea what it does
    setVolume - same, no idea
    turnOn
    turnOff
    Actions above could be used as is in AOS (as Zwave device)
    for example:
    trueAct={"234","turnOn",""}, falseAct={"234",trunOff",""}...
    Regarding setMute and setVolume, do you know what they used for? Maybe dim level and color?
    OK, I guess HT is off when "value=0".
    {0, "108",{state="value=true#4",timeSlot="21:30~?$sunriseHour+1800?",trueAct={{"91","turnOn","{138:value=0}"},{"91","turnOff","90"}}}},
    Ok Thanks
    Never used HUE plugin most comment was its limmited
    Should install HUE plugin   to see
    But if I want to use VD its not a problem either I guess
    //Sjakie
    30 minutes ago, Sjakie said:
    Ok Thanks
    //Sjakie
    Yes, if currently you control VD by pressing buttons and slider, you able to do it by AOS also
    Use following commands
    pressButton,buttonNumber - press virtual device's button.
    setSlider, <sliderNum>, value – set value of specific slider
    setProperty, <ui.labelID.value>, value – set value of specific label
    trueAct={"<VD-ID>","pressButton,3",""}
    trueAct={"<VD-ID>","setSlider,4,200",""}
    trueAct={"<VD-ID>","setProperty,<label-ID>,text",""}
    Edited by cag014
    @SmartLifeSystems
    I'm curious, is it works?
    What is wrong?
    {{0,"'bewegingssensor'|'deur'", {state="value=true",trueAct={"14","turnOn",""}}}},
    //Sjakie
    10 minutes ago, Sjakie said:
    What is wrong?
    //Sjakie
    Use back apostrophes ( ` ), not apostrophes( ' )
    Same key is also used for typing the tilde ( ~ ) character
    {{0,"`bewegingssensor`|`deur`", {state="value=true",trueAct={"14","turnOn",""}}}},
    hehe after getting all kind of errors its accepting it now.
    But I entered the bathroom AIOS show door open didt show motionsensor breached
    perhaps for better understanding:
    {{0,"`motionSensor`|`door`", {state="value=true",trueAct={"14","turnOn",""}}}},
    Please advice,
    //Sjakie
    Do you see motion breached on HC2 UI?
    By the way AOS  executes actions in real time, but doesn't display real time changes, you need to refresh the scene to see changes.
    Yes motion breached a few seconds ago.
    Will do again
    Sorry to bother you :)
    jM={{0,"`bewegingssensor`|`deur`", {state="value=true",trueAct={"14","turnOn",""}}},
    How to add next line I get errors.
    jM= {0,"` humSensor `",{state="value>max(@`humSensor `>value+4,55)", trueAct={{"`venta`","turnOn",""}, {“”,”tts”, "$room $name over $stateValue percent. Turning ventilation on."}}, falseAct={{"`venta`","turnOff",""}, {“”,”tts”, "$room $name below $stateValue percent. Turning ventilation off."}}, trigAct={"$lineId","setStateValue","max(@`humSensor `>value+4,55)", "{`mSensor`:lastBreached>1800}"}}}
    Can I change 55 into 44? I dont know why you said no lower than 55?
    Please advice,
    //Sjakie
    Could you please post an error?
    Regarding no lower than 55, it's just my opinion that humidity below 55 not required to turn ON ventilation. Of course you can change it to any value you need.
    Thanks! Will change switch on 40+5 switch off < 55
    First this one please
    /monthly_2020_04/image.png.f9456bf3b4100b38aafbb7f43ee15340.png" />
    jS2n={deur=233, doucheDeur=235, doucheDeurTemp=236, dakraam=239, dakraamtemp=240, bewegingssensor=243, bewegingssensortemp=244, luxsensor=245, humidity=246, spotbadk1=14,
    badkamer="'deur'|'doucheDeur'|'doucheDeurTemp'|'dakraam'|'dakraamtemp'|'bewegingssensor'|'bewegingssensortemp'|'luxsensor'|'humidity'|'spotbadk1'"
    luik=261, dakraam=263, dakraamtemp=264, verlichting=267, turbo=293, middenstand=294, verWarming=345,
    zolder = 'luik'|'dakraam'|'dakraamtemp'|'verlichting'|'turbo'|'middenstand'|'verWarming'"}
    Please advice,
    //Sjakie
    You're missing comma before luik=261
    otbadk1'"  ,
    Hehe, Thanks!
    Cag what is smart to do with the table?
    In my case I only add badkamer, zolder to know what I am doing.
    In case of arming scene door devices start with door and than explanation witch door?
    Please advice,
    //Sjakie
    Hi Cag,
    jM= {{0,"`humSensor`",{state="value>max(@`humSensor `>value+4,55)", trueAct={{"`venta`","turnOn",""}, {“”,”tts”, "$room $name over $stateValue percent. Turning ventilation on."}}, falseAct={{"`venta`","turnOff",""}, {“”,”tts”, "$room $name below $stateValue percent. Turning ventilation off."}}, trigAct={"$lineId","setStateValue","max(@`humSensor `>value+4,55)", "{`mSensor`:lastBreached>1800}"}}},
    unexpected symbol near character 226 in th esecond line of jM (copied the whole line from pdf) I see a difference in " but if I change same errror.
    Please advice,
    //Sjakie
    jM should be one array, in your case the first part of jM is ignored.
    in PDF for each example jM defined specific for the example.
    Try below.
    jM={
    Sorry but I get same error.
    //Sjakie
    //Sjakie
    Unbelievable, the parentheses some how corrupted in ("","tts","..."} command.
    please copy below
    jM={
    {0,"`humSensor`",{state="value>max(@`humSensor`>value+4,55)", trueAct={{"`venta`","turnOn",""}, {"","tts", "$room $name over $stateValue percent. Turning ventilation on."}}, falseAct={{"`venta`","turnOff",""}, {"","tts", "$room $name below $stateValue percent. Turning ventilation off."}}, trigAct={"$lineId","setStateValue","max(@`humSensor`>value+4,55)", "{`mSensor`:lastBreached>1800}"}}},
    Please verify that devices `humSensor` , `venta` , `mSensor` are properly defined in j2Sn{} array.
    Hi Cag,
    Thanks.
    Got some nice errors after correction all okay
    in your Quick start guide .pdf on my end see image
    I noticed that by TTS the parenthesis where different but thought it should be so.
    /monthly_2020_04/image.png.928e4fc5e849f70b3809a80b1e787e9f.png" />
