3 minutes ago, SmartLifeSystems said:
The 15 min is an example. But while the desire temperature not true, the 15 min  will restart.
Or have you got a better idea this?
But if we take no notice of the schedule time, you can do the next option? The termostat head setlevel example 24 C, while the temperature reach the original value, and the thermostat head stand back the original value.
    So it looks like you'll restart 15 minutes till desired temperature has reached.
    My suggestion is when desired temperature has reached turnOff the boiler. Looks simpler solution.
    In any case both scenarios could be supported.
    I am curious.
    8 hours ago, cag014 said:
    {0,"926",{state="centralSceneSupport=2.Pressed",trueAct={ {"818","turnOff;else;turnOn","","{818:on=true}"}}}},
    even without changebrightness action i get same erroe.
    I tried every combination of "on" property: true, 1, and result always the same. Line works only if i don't use any condition.
    line 447 is  if rCmd then cRes=fibaro:getValue(devId,rCmd):gsub(" ","") end
    check this link please about device properties on fibaro hue plugin
    Wow... on startup Hue device returns null value!?
    Any how, please replace line 447 with that one
    Tested and works.
    perfect.
    Time to AIO 2.01?
    Any news about hc3 version?
    Yes... will be release soon with HC3 version.
    Actually HC3 version is ready beside alarm functionality. Fibaro has changed the concept and I trying to keep smooth transition from HC2 to HC3.
    just another question
    {0,"|`lineadx`|`lineasxt`|`lineasxb`",{state="value=true",trueAct={"`pozzo`","turnOn",""},falseAct={"`pozzo`","turnOff","","={`lineadx`:value=false|`lineasxt`:value=false|`lineasxb`:value=false|"}}},
    why during validation:
    /monthly_2020_06/image.png.4cc6b666320c85971df76640cee8f59e.png" />
    [DEBUG] 16:19:36
    Edited by gggizmo
    Means device ID 967 is a master device.
    Master doesn't support sending commands or reading values!
    in your example
    967:value=false
    value property is unavailable for master device.
    please check it by API (  http://hc2/api/devices/967  )
    Use slave devices
    @SmartLifeSystems
    I'm trying to understand the sequence of events between temp sensor and thermostat
    What I understand is
    If tempSense<thermostat then set thermostat to 24 C and turn on boiler in loop of 15 minutes till tempSense>= thermostat, turonOff boiler and set thermostat to original value, which is ?
    Could you post the command for thermostat temp setup
    For example: thermostat is seted 22C. If temp sens < thermostat head, turn on the boiler, and set up the thermostat head 24C for 15 min and after set back the original value. The bioler only if turn off, then the temp sens >= thermostat head original value.
    But if solvable, would be best this: thermostat head 22C If temp sens < thermostat head, turn on the boiler, and set level 24C the thermostat head. If the thermostat head has reached the desired temp (temp sens >= thermostat head original value) turn off the boiler, and set the thermostat head level the original value.
    What do you think about this?
    boiler ID = 37
    temp sens ID = 11
    thermostat head ID = 12
    so with aio it's not possible to control devices via secondary gateway.
    Let me explain:
    this devices are on one hcl linked as slave gateway to primary hc2. It's in garden too far to control sprinklers with primary hc2. So in primary hc2 for these devices i see only one id not master and child
    Let me explain:
    You're the first user trying to use slave gateway.
    Could you please post device API data from primary gateway (  http://hc2/api/devices/967  )
    I'll see what I can do. I believe it could be solved
    Edited by cag014
    3 hours ago, gggizmo said:
    Let's try it...
    please change line (somewhere around line number 1008 )
         if j.parentId>1 then jDlist["numDev"]=jDlist["numDev"]+1;jDlist[j.id]=j.properties.nodeId;jDlist["nId"..jDlist[j.id]]=os_time()
    to
         if j.parentId>1 or j.remoteGatewayId>0 then jDlist["numDev"]=jDlist["numDev"]+1;jDlist[j.id]=j.properties.nodeId;jDlist["nId"..jDlist[j.id]]=os_time()
    Let me know if it works
    11 minutes ago, cag014 said:
    Let's try it...
    to
    attemtp to index field'?' (a nil value)
    in line 905
    local idF={jDid[dId].name.." @ "..jDid[dId].room, jDid[dId].name..":"..realId(dId)..":"..jDid[dId].room, "", jDid[dId].name.."<sup>"..realId(dId).."</sup>"..jDid[dId].room, jDid[dId].room..":"..realId(dId)..":"..jDid[dId].name}
    in line 905
    Sorry, my fault...wrong device id
    Works perfectly thanks
    Great.
    Since I'm trying to avoid Lua errors and to provide human readable error messages, could you please elaborate what was wrong with the device that caused the error?
    I mean is it z_wave device? If so, could you please post device data to understand why the code didn't find the error.
    @SmartLifeSystems
    Please try line below (since I don't know the thermostat real command, I'm using "setPoint" command as an example)
    What do you think? Is it what you need or I'm off target?
    Edited by cag014
