    Like that?
    OK... it should be easy...
    Did you set 1st button (square) as follow?
     In this case keyfob will wait for a sequence and then send it.
    You can do it for any button...
    Let me know if it works... thanks
    This setting i did every button. This problem true is every button. But the first working correctly. If i press the first button, the blue led pulzing one times every button pressing, and the green one times, when the data is sending. Any buttons don't do this, only the green led pulzing one times, when the data is sending.
    Interesting... I have the same and all buttons are working fine, but I don't see any blue light on every press!!
    What about other configurations... are they default?
    Edited by cag014
    Everythings default, only the buttons pressing times not.
    keyfob included in normal mode? I mean not secured mode...
    I havegot a fibaro button too. The problem just the same.
    Very interesting.
    Where can i set this?
    During inclusion process
    This is correct.
    In the event panel I see example the secound button 1 I pressed three times. But doing the fist and secoud action too. :(
    Confusing...
    Did you see on device icon number of presses? Here an example pressing 3 times "+" button
    Hi cag!
    I think my problem in my AllInOne settings, because I maked Block scene, and the keyfob working fine.
    What do you think? What did i wrong?
    Here is my examples:
    {0, "140",{state="centralSceneSupport==3.Pressed3",timeSlot="$sunsetHour~$sunriseHour",trueAct={{"86|91","setValue,10",""},{"138","turnOff",""},{"TV:","sendPush","A TV kikapcsolva. Fekvéshez készülődő fényt kapcsolatm."}}}},
    {0, "140",{state="centralSceneSupport==3.Pressed",timeSlot="$sunsetHour~$sunriseHour",trueAct={"91","setValue,40",""}}},
    {0, "140",{state="centralSceneSupport==3.Pressed2",timeSlot="$sunsetHour~$sunriseHour",trueAct={"91","setValue,0",""}}},
    OK, the problem has been solved. The problam was the double =.
    Yes...
    That's exactly what I found....
    The double equal sign searches the criteria state value in value.
    So "3.Pressed" defiantly found in "3.Pressed2" or "3.Pressed3"....
    • 3 weeks later...
    hi Cag014
    can a lineState have an AND or an OR within it
    for example lineState={"{&housestatus:value=safe} or {&notifications:value=on}"}?
    thanks Len
    Yes... but the format slightly different.. without OR
    lineState={"{&housestatus:value=safe}{&notifications:value=on}"}
    If you need AND condition separate statements by |
    lineState={"{&housestatus:value=safe|&notifications:value=on}"}
