it is ok Cag014 i found the setColor command and sent setColor 0,0,0,255 which achieves the same result .
slowly converting as many scenes as i can onto the All in one scene ;)
    Great.. let me know if you have any issues or questions
    By the way if you need to set variable levels, you can include formula in any value. Have used your global variable as an example.
    Edited by cag014
    Lua math library supported as well. like math.max() math.floor() and etc.
    To use math library, just type the math name only . like max()  floor().
    hi cag014,
    me again ! ;)
          when `frontdoor` is opened and `frontdoor` is NOT armed do this...............
    but when `frontdoor` is opened AND is armed do this ........
    how do i apply this in all in one scene please?
    also i wish to have my kitchen under unit leds come on whenever anyone enters kitchen but my kitchen light and pelmet lights on if someone enters one hour before sunset and till sunrise, hopefully stay on for ten minutes when kitchen empties
    hope you understand what i mean?
    thanks for your help
    OK.. for frontdoor you can use conditions parameter with property armed (armed=true or armed=false):
    Please replace <devList> and <action> according to your needs.
    Now regarding kitchen lights, if I understand correctly you want to turn ON kitchen and pelmet lights for 10 minutes (if no one presents) during one hour before sunset till sunrise. If so, then use :
    Please defined ktnMS as kitchen sensor, ktnLights as kitchen light, pltLights as pelmet lights
    Edited by cag014
    On 2/2/2020 at 2:14 AM, cag014 said:
    @vmation.virgin sorry for late response, was on vacation.
    Here is the configuration for you:
    1. Define your wall-plug ID to make jM line more readable.
    (replace number 424 to your device ID and name to whatever suit you)
    jS2n={wPlug=424}
    2. Define/add follow line in you jM hash table:
    /monthly_2020_02/image.png.bfdca279a265e41f611826b56ef8d45a.png" />
    it's working?,   now to control the duration of on/off , have to adjust  valueModified>5390 ""valueModified>1785"?.  and whats the no "30" for in the beginning?.
    It means, the line runs in loop of 30 minutes. Every 30 minutes timeLoopAct{} array executed.
    hi cag014,
    The line below announces through my alexa that the front door has been opened:-
    {0,"`front`",{state="value=true",trueAct={"&keydata","setGlobal","8b38308d7188445fa4c55f3b1b9e464e"}}}
    `front¬ being the front door sensor
    the global value keydata is set to a token key and alexa speaks the announcement the key dictates,this works fine. my question is can i have the system check if the door sensor is armed and if so not announce the message and send a different token key
    Thanks for your time
    hi cag014
    i am not sure how to add my global into the example you sent me.im missing something i know?
    Here below an example to set global keydata with token when front door is open and armed.
    Set the second command with token when frontdoor is not armed
    works so well thank you !
    i put & in front of the keydata to show its a global variable did i have to do that?
    It works with and without
    hi Cag01,
    still busy converting scenes :)
    i have another question
    i have to set a global value then 10 minutes later , reset it
    set global value to turn alexa speech off........wait ten minutes......turn alexa speech back on this is done using a global variable , its just the timing i dont now how to do (sleep 3600) etc?
    thanks again
    5 hours ago, cag014 said:
    Is it in the same line? What your reset value? When you need to reset, I mean if front door open and armed?
    Example below resets global value always.
    keydata will be set to value "speak" after front door has opened  in 10 minutes.
    Is it what you mean?
    Edited by cag014
    hi Cag014
    at times i need alexa not to make announcements so i change a global variable from "speak" to "quiet", but after 10 minutes i need the reverse to happen the variable changed from "quiet" back to "speak". i use a fibaro button at present ID is 44.
    the global variable is alexaspeak
    Thank you for your help
    everytime is a light bulb moment ;)
    hi cag014,
    have transferred nearly all my scenes into AOS and all working well. would like to set my RGBW led to run a predefined program in a scene this would be …. fibaro:call(26."startProgram",5), can this be done in AOS cant see a command for it?
    Thanks Len
    Just start to use the command. AOS will verify if the action is valid and will execute it.
    Please note, parameter(s) should be part of command string separated by comma.
    Edited by cag014
